Date/Time: Mon, 14 Jul 2025 20:55:35 +0000
Not connect to T4
View Count: 1215
[2014-05-27 16:23:19]
nick762 - Posts: 11
Software version: 1074 | 2014-05-27 20:12:13
Usage end date: 2014-09-28 | 2014-05-27 20:12:13
Enabled for: Sierra Chart Historical Data Service. | 2014-05-27 20:12:13
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-05-27 20:12:13
Active service: CTS T4 | 2014-05-27 20:12:13
Time Zone: +04:00:00 (MSK+04) | 2014-05-27 20:12:13
2014-05-27 20:12:13 Local computer clock time | 2014-05-27 20:12:13
2014-05-27 16:12:13 GMT time | 2014-05-27 20:12:13
2014-05-27 20:12:13 Time zone adjusted time | 2014-05-27 20:12:13
Time difference to server time: 2 seconds. | 2014-05-27 20:12:13
Program path: C:\SierraChart\ | 2014-05-27 20:12:13
Data Files path: C:\SierraChart\Data\ | 2014-05-27 20:12:13
OS Version Number: 6.1 | 2014-05-27 20:12:13
Checking for new symbol settings for cts | 2014-05-27 20:12:13
CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-05-27 20:12:19
CTS FIX - Firm: Dorman | 2014-05-27 20:12:19
Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-05-27 20:12:19
The network socket is connected. | 2014-05-27 20:12:19
The socket starting SSL connection. | 2014-05-27 20:12:19
SSL socket is now connected. | 2014-05-27 20:12:20
CTS FIX: Sending the Logon message. | 2014-05-27 20:12:20
CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-05-27 20:12:20
CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-05-27 20:12:20
The SSL socket was shut down successfully. | 2014-05-27 20:12:20
CTS FIX: Logged out and disconnected. | 2014-05-27 20:12:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-27 20:12:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-27 20:12:20
CTS FIX: Disconnected. | 2014-05-27 20:12:20
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-27 20:12:20
CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-05-27 20:12:25
CTS FIX - Firm: Dorman | 2014-05-27 20:12:25
Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-05-27 20:12:25
The network socket is connected. | 2014-05-27 20:12:26
The socket starting SSL connection. | 2014-05-27 20:12:26
SSL socket is now connected. | 2014-05-27 20:12:26
CTS FIX: Sending the Logon message. | 2014-05-27 20:12:26
CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-05-27 20:12:26
CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-05-27 20:12:26
The SSL socket was shut down successfully. | 2014-05-27 20:12:26
CTS FIX: Logged out and disconnected. | 2014-05-27 20:12:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-27 20:12:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-27 20:12:26
CTS FIX: Disconnected. | 2014-05-27 20:12:26
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-27 20:12:26
[2014-05-27 17:32:50]
Sierra Chart - Max - Posts: 5841
You are getting the following Error:
So you should login to www.t4login.com and complete the setup page.
Sierra Chart Support
