Date/Time: Fri, 13 Nov 2026 21:24:40 +0000
Changed my PC and can see MBO on package 12
View Count: 867
| [2022-11-30 16:14:28] |
| User798442 - Posts: 7 |
Hello, I just got a new PC and installed Sierra Chart on it. I deleted previous Sierra Chart on old PC. Checked market depth levels settings, symbol settings for MBO, data/trade service settings, but still can't see market depth quantities and also MBO quantities. Could you please take a look into my acc setttings and check if all is in order? Thank you. |
| Attachment Deleted. |
| [2022-11-30 18:11:33] |
I manage to fix some of the issues with the chart DOM. However MBO are still missing. Here is updated screenshot. Thank you |
| [2022-11-30 23:47:10] |
| John - SC Support - Posts: 48527 |
What is the symbol of those charts? We ask the above, as you only have Market Depth data setup for the CME exchange. If those charts are for a symbol that trades on one of the other CME Group exchanges, then you will not get the data since you are not setup for it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-01 05:33:57] |
Symbol is ESZ22-CME
| [2022-12-01 15:58:46] |
Have you gone through the setup instructions for the MBO data at the following link: Market By Order Data: Step-by-Step Instructions The main item in the above instructions is step #1. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-01 16:03:22] |
Much appreciated. It worked right away. Thank you very much :) |
