Date/Time: Fri, 13 Nov 2026 21:24:47 +0000
SC/EUREX data
View Count: 790
| [2022-11-30 12:11:27] |
| User266447 - Posts: 280 |
I will swap taking data from AMP/CQG/EUREX to SC/EUREX. To avoid delays could you remain me how can I swap my charts from CQG to SC data, please? For instance, right now my DAX chart symbol is F.US.DDZ22. After I stop receiving data from CQG and start taking from you I remember I need to do something with my charts but do not remember what. Please support me on this one.
| [2022-11-30 14:34:36] |
| Sierra_Chart Engineering - Posts: 25422 |
You just need to follow through the setup instructions here: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-30 16:56:26] |
Do I need to sign anything? I think I signed already. Could you confirm it, please? (Tomorrow I will apply for EUREX data). If I signed everything for EUREX how can I apply for the data? It should cost me $25 p/m. And SC is $46 p/m. Do I need to pay for anything else (package 11). The first time can be the most complicated... |
| [2022-11-30 23:39:03] |
| John - SC Support - Posts: 48527 |
You have already filled out the Exchange Agreements for EUREX and they have been accepted. You just need to activate the exchange tomorrow (December 1, 2022) which costs $25.00 per month. If this is the only data you need then you should be good with the exchange and your monthly Sierra Chart package cost ($46.00 per month). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-01 10:34:24] |
I have activated 'EUREX EOBI'. Is it the correct one?
| [2022-12-01 12:47:51] |
Everything works :-)
