Date/Time: Fri, 13 Nov 2026 21:24:51 +0000
Guideline don't mach
View Count: 687
[2022-11-29 15:06:51]
Hopeman - Posts: 166
Hello!
There is a problem when drawing a guideline to create a channel on the price, I draw this guideline in a day time of 4 hours and an hour but in less times 15 minutes 5 and three minutes is not the same, there is a difference very noticeable, which is a big problem to exercise my strategy.
I am writing to see if you can help me since I have been trying to find a solution and it has not been possible, thanks in advance
[2022-11-30 16:11:48]
We are not exactly sure what you are trying to tell us, but refer to the following which we think gives you the answer to your issue:
Lines/Rays or Other Chart Drawings Move After Drawing Them: Chart Drawings Are Misaligned After Changing the Period / Timeframe Per Bar
[2022-12-01 14:56:41]
Thank you helped me.
I wanted to comment on another matter, the issue is that I am trying to build an auditory signal similar to tikstrike. Do you think it would be possible to combine predetermined bid and ask orders with the tape? Thank you
[2022-12-01 17:59:41]
We are not familiar with tikstrike and we are not sure exactly what you want to do with regards to "combine predetermined bid and ask orders with the tape".
Can you give us additional information with what you want to accomplish.
[2022-12-01 18:56:40]
Hello !
I found a thread on sierra referring to those who are looking for a sound edition of bid and ask.
I think so and I found it! Thanks a lot.
Pricesquawk not working on version 2362
