Date/Time: Tue, 07 May 2024 14:51:06 +0000
The state of the Spreadsheet_System_for_Tradin table.
View Count: 317
[2022-11-29 10:10:45] |
2garin - Posts: 184 |
Good day. Opened a new chartbook, added four charts to it. I added one and the same table _Spreadsheet_System_for_Tradin for each chart. For each chart, I set up a separate algorithm for placing trade orders (on separate sheets of the table). When automatic trading is enabled, the table on all charts correctly displays trade orders and stop orders. Tell me please: How can I temporarily limit the automatic placement of orders on one/several charts without making changes to the sheets of the table and without turning off automatic trading of the entire chartbook. As a way to implement: you can create/add an indicator to a chart that would allow, by a combination of keys or by pressing a certain button, to stop the automatic trading on one of the charts and would visually display the current state of the mode. |
[2022-11-29 18:43:20] |
John - SC Support - Posts: 31427 |
There is the following option - Trade >> Auto-Trading Enabled - Chart. So you would want to turn this off/on for each chart and leave the global Auto-Trading option enabled. Refer to the following: Trade Menu: Auto Trading Enabled - Chart (Trade menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-07 03:53:10] |
How to visually determine the disabled state of Trade >> Auto-Trading Enabled - Chart (without looking into the menu each time)?
[2022-12-07 15:45:31] |
You can Add a Control Bar button for the option and it will change state (pressed in/out) based on whether the option is On/Off. Refer to the following: Control Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
