Date/Time: Fri, 13 Mar 2026 20:18:52 +0000
Volume by price - Multiple profiles fixed by time - volume bars based on the same constant
View Count: 1306
| [2014-05-27 14:12:13] |
| Davidside - Posts: 16 |
Is it possible at study "volume by price", when I use "Multiple profiles fixed by time" to set all volume bars width of every day fixed to the same constant to be comparable individual days between themselves? Now I am not able to compare individual day volume profile with another day volume profile because there are different absolute values. The width of the volume bars could be set only to window width or period length? I would like to compare values of each volume profiles visually between themselves. Is it possible? Thank you. |
| [2014-05-27 22:30:52] |
What is the timeframe of the chart bars in the chart?
| [2014-05-28 12:35:02] |
Timeframe is 30 minutes. But it doesn't affect horizontal volume bars. Point of control of the profile fixed by time has the same lenght as point of control for others profiles.
| [2014-05-29 05:11:36] |
OK, we see what you mean, there is no way to control this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-29 05:12:45
