Date/Time: Fri, 03 May 2024 20:02:52 +0000
No Replay function
View Count: 249
[2022-11-23 04:14:55] |
nicktrader - Posts: 665 |
I work with two PCs. A long time ago I copied the entire SC folder from one PC to the other. A few days ago I wanted to synchronize both PC so I transferred the "Sierra4.config" from one PC to the other. Now I noticed that I can't do a replay on the PC with the "new" "Sierra4". If I take the original previous "Sierra4" again, the replay function works fine. |
[2022-11-23 15:43:48] |
John - SC Support - Posts: 31360 |
If you are not able to see the Replay window, then refer to the following: Replaying Charts: Chart Replay Window Not Visible If it is something else, then let us know what exactly is (or is not) occurring. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
