Date/Time: Mon, 09 Nov 2026 05:39:10 +0000
DOM
View Count: 685
| [2022-11-22 16:42:36] |
| Said9000 - Posts: 2 |
Hello, I am new on Sierra Chart and i'm still using the free trial version. How can I see the DOM (the columns blue and red) of any ticker/ value I want? When I search it I only can see the Trading DOM but not a real simulation of bid/ask and demand... Hope you can help me. Thanks |
| [2022-11-22 18:36:58] |
| John - SC Support - Posts: 48459 |
We do no know exactly what the particular issue is. Please give us some additional information. Here are some questions we have to help: - Are you able to open a Trading DOM? - Are you wanting to learn how to change the colors of the Trading DOM? - Are you wanting to learn how to see the DOM on a Chart instead of a separate Trading DOM? - Are you wanting to learn how to customize the Chart DOM? - Are you not getting the expected Market Depth data in the DOM? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-22 19:35:07] |
Hi John, i am not able to see the data on the DOM chart, I open the DOM but there is no data and orders filled in it, it is static without any data there. And I have connection by the way... How can I open the DOM of a stock value and see it in real (10 min delayed) time? Thanks- |
| [2022-11-22 22:28:13] |
Start by following the instructions at the following link for how to open a chart: Getting Started, Opening Charts and Basic Trading: Open A Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
