Date/Time: Mon, 05 Oct 2026 06:37:22 +0000
ALl work wiped
View Count: 720
| [2022-11-22 16:42:27] |
| EddieRokit - Posts: 13 |
Hi there I have had to update Windows 10 and when I have logged back into Sierra Chart all of my work and connections have been wiped? What can I do about this? Greg |
| [2022-11-22 18:34:07] |
| John - SC Support - Posts: 48095 |
There are backups, of everything. There are backup Chartbooks: Chartbooks (Workspaces): Accessing a Backup Chartbook File And there are also backups of the main configuration file: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
