Date/Time: Sat, 04 May 2024 03:15:10 +0000
Rithmic Data feed
View Count: 253
[2022-11-22 16:26:22] |
Maris Voitins - Posts: 1 |
Hi,Im trying to connect to Rithmic,but its not connecting,there is written Reconnect Wait for a long time without some action,I activated service package 11 today. I was following instruction,but I think the problem is,that I dont have an activ trading accout,only funded Rithmic Direct - DTC | Using server connection: | 2022-11-22 10:47:47.610 Rithmic Direct - DTC | Remote address is not set. | 2022-11-22 10:47:47.613 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-11-22 10:47:47.613 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:47:47.613 DTC Client socket (0) | CloseSocket call. | 2022-11-22 10:47:47.627 Rithmic Direct - DTC | Disconnected. | 2022-11-22 10:47:47.627 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:47:47.627 Rithmic Direct - DTC | Using server connection: | 2022-11-22 10:47:51.623 Rithmic Direct - DTC | Remote address is not set. | 2022-11-22 10:47:51.635 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-11-22 10:47:51.635 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:47:51.635 DTC Client socket (0) | CloseSocket call. | 2022-11-22 10:47:51.638 Rithmic Direct - DTC | Disconnected. | 2022-11-22 10:47:51.638 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:47:51.638 Rithmic Direct - DTC | Using server connection: | 2022-11-22 10:47:55.653 Rithmic Direct - DTC | Remote address is not set. | 2022-11-22 10:47:55.657 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-11-22 10:47:55.657 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:47:55.657 DTC Client socket (0) | CloseSocket call. | 2022-11-22 10:47:55.672 Rithmic Direct - DTC | Disconnected. | 2022-11-22 10:47:55.672 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:47:55.672 Rithmic Direct - DTC | Using server connection: | 2022-11-22 10:47:59.654 Rithmic Direct - DTC | Remote address is not set. | 2022-11-22 10:47:59.664 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-11-22 10:47:59.664 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:47:59.664 DTC Client socket (0) | CloseSocket call. | 2022-11-22 10:47:59.672 Rithmic Direct - DTC | Disconnected. | 2022-11-22 10:47:59.672 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:47:59.672 Rithmic Direct - DTC | Using server connection: | 2022-11-22 10:48:03.679 Rithmic Direct - DTC | Remote address is not set. | 2022-11-22 10:48:03.688 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-11-22 10:48:03.688 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:48:03.688 DTC Client socket (0) | CloseSocket call. | 2022-11-22 10:48:03.695 Rithmic Direct - DTC | Disconnected. | 2022-11-22 10:48:03.695 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:48:03.695 Rithmic Direct - DTC | Using server connection: | 2022-11-22 10:48:07.694 Rithmic Direct - DTC | Remote address is not set. | 2022-11-22 10:48:07.698 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-11-22 10:48:07.698 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:48:07.698 DTC Client socket (0) | CloseSocket call. | 2022-11-22 10:48:07.711 Rithmic Direct - DTC | Disconnected. | 2022-11-22 10:48:07.711 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:48:07.711 Rithmic Direct - DTC | Using server connection: | 2022-11-22 10:48:11.709 Rithmic Direct - DTC | Remote address is not set. | 2022-11-22 10:48:11.718 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-11-22 10:48:11.718 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:48:11.718 DTC Client socket (0) | CloseSocket call. | 2022-11-22 10:48:11.728 Rithmic Direct - DTC | Disconnected. | 2022-11-22 10:48:11.728 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:48:11.728 Rithmic Direct - DTC | Using server connection: | 2022-11-22 10:48:15.721 Rithmic Direct - DTC | Remote address is not set. | 2022-11-22 10:48:15.728 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-11-22 10:48:15.728 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:48:15.728 DTC Client socket (0) | CloseSocket call. | 2022-11-22 10:48:15.738 Rithmic Direct - DTC | Disconnected. | 2022-11-22 10:48:15.738 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-11-22 10:48:15.738 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2022-11-22 10:48:35.729 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 32768 | 2022-11-22 10:48:35.730 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 38.79.0.89. | 2022-11-22 10:48:35.730 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2022-11-22 10:48:36.327 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | CloseSocket call. | 2022-11-22 10:48:36.328 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-11-22 10:48:36.328 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Closed. | 2022-11-22 10:48:36.328 Date Time Of Last Edit: 2022-11-22 17:46:46
[2022-11-22 17:46:05] |
Sierra_Chart Engineering - Posts: 14207 |
Follow through the step-by-step instructions here to connect to Rithmic: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
