Date/Time: Thu, 02 May 2024 04:55:42 +0000
Trend Line Auto Buy
View Count: 1151
[2014-05-27 12:55:45] |
User43916 - Posts: 9 |
Hi, I did some research here on the support board and found a post where someone asked this question a year or two back. At the time you had to program a custom study to have a trend line initiate a specific buy or sell order. Is this still the case? Is there any possibility of adding a feature where a trader could simply highlight the trend line and create a "hot line" sort of speak, where the trader then selects the type of entry if the order touches the trend line? I would think this would be largely beneficial to overnight trades or at times when you can't be at your trading desk. It seems it would be much easier than adding a code with chart #, etc; every time one wants to set this format up. Thanks! TraderY |
[2014-05-27 23:20:07] |
This is not something that is planned.
