Date/Time: Fri, 13 Nov 2026 21:24:54 +0000
Errors in trade log time entries
View Count: 785
| [2022-11-21 23:35:34] |
| aroymukherjee - Posts: 23 |
When doing backtests the trade log sometimes does not print the actual time of entry or exit although does show a duration for the trade. The attached file shows a couple of these highlighted from my backtest trade log. What is the cause for this error and how can I fix it to be able to view the correct times?
| [2022-11-23 00:28:45] |
| Sierra_Chart Engineering - Posts: 25422 |
That definitely should not occur. We do not think we have ever seen this before. When you see this case, go to the Trade Activity tab. And then export the data: Trade Activity Log: Importing and Exporting Data And then attach that export file here and we will check on this. Instructions: Support Board Posting Information: Attaching a File (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-23 03:59:34] |
Trade Activity Log (Fills) enclosed. I noticed the the print errors in the actual trade log
| [2022-11-28 20:41:23] |
We will get to this as soon as we can.
| [2022-12-02 03:20:33] |
Examining that fill file and generating Trades, we do not see any Entry/Exit Date-Time with just a time. We did optimize the importing of fill Activity. So that is good. It is now dramatically faster. Symbol Exit Price Entry DateTime Exit DateTime Trade Type Entry Price Trade Quantity Max Open Quantity Max Closed Quantity Profit/Loss (C) Cumulative Profit/Loss (C) FlatToFlat Profit/Loss (C) FlatToFlat Max Open Profit (C) FlatToFlat Max Open Loss (C) Max Open Profit (C) Max Open Loss (C) Entry Efficiency Exit Efficiency Total Efficiency Commission (C) Duration High Price While Open Low Price While Open Note Open Position Quantity Close Position Quantity
[Sim]MGCZ22-COMEX (Sim5) 1321.80 2018-01-04 18:01:59.000 BP 2018-01-05 08:31:00.000 EP Short 1322.94 5 3 3 5.70 5.70 5.70 F 6.20 -0.30 0.00 0.00 39.9% -80.3% -100.3% 0.00 14:29:01 1324.50 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1319.50 2018-01-05 09:07:18.261 BP 2018-01-05 09:08:00.000 EP Short 1319.00 1 1 1 -0.50 5.20 -0.50 F 0.00 0.00 0.00 0.00 7.5% 0.0% 0.0% 0.00 00:00:41 1319.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1319.84 2018-01-05 09:08:00.000 BP 2018-01-05 11:45:59.000 EP Short 1318.78 5 4 4 -5.30 -0.10 -5.30 F 0.00 -0.10 0.00 0.00 70.7% -1100.0% -1160.0% 0.00 02:37:59 1323.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1315.70 2018-01-08 00:37:00.000 BP 2018-01-10 05:38:21.000 EP Short 1315.89 14 8 8 2.60 2.50 2.60 F 16.70 -5.90 1.00 -4.00 84.9% 101.4% 42.9% 0.00 53:01:21 1323.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1324.60 2018-01-10 05:38:21.000 BP 2018-01-10 06:13:00.000 EP Long 1321.65 4 3 3 11.80 14.30 11.80 F 17.60 -3966.80 7.70 -1323.50 0.0% 99.4% 6.9% 0.00 00:34:39 1327.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1320.47 2018-01-10 06:13:00.000 BP 2018-01-11 08:13:25.020 EP Short 1321.10 7 4 4 4.40 18.70 4.40 F 12.00 0.00 0.00 0.00 87.1% -8.9% -8.9% 0.00 26:00:25 1326.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1324.90 2018-01-11 08:32:00.000 BP 2018-01-11 19:38:58.075 EP Short 1321.30 1 1 1 -3.60 15.10 -3.60 F 1.00 -4.00 1.00 -4.00 100.0% 8.0% -72.0% 0.00 11:06:58 1325.30 1320.30 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1329.20 2018-01-11 23:00:02.015 BP 2018-01-11 23:21:00.000 EP Short 1327.90 1 1 1 -1.30 13.80 -1.30 F 0.00 0.00 0.00 0.00 97.7% 0.0% 0.0% 0.00 00:20:57 1329.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1331.46 2018-01-12 02:49:00.000 BP 2018-01-12 04:03:00.000 EP Short 1328.44 5 4 4 -15.10 -1.30 -15.10 F 0.00 -3.40 0.00 0.00 41.7% 18.8% -1.2% 0.00 01:14:00 1331.70 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1327.72 2018-01-12 08:30:01.328 BP 2018-01-12 08:33:00.000 EP Short 1327.33 6 6 6 -2.30 -3.60 -2.30 F 0.00 0.00 0.00 0.00 65.3% 0.0% 0.0% 0.00 00:02:58 1333.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1325.50 2018-01-12 08:33:00.000 BP 2018-01-12 09:01:00.000 EP Long 1329.14 5 5 5 -18.20 -21.80 -18.20 F 0.00 -5320.30 0.00 -1329.40 0.0% 99.9% -0.1% 0.00 00:28:00 1329.40 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1330.80 2018-01-12 09:01:00.000 BP 2018-01-12 10:40:19.037 EP Short 1325.50 2 2 2 -10.60 -32.40 -10.60 F 0.00 0.00 0.00 0.00 4.0% 0.0% 0.0% 0.00 01:39:19 1331.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1338.10 2018-01-12 13:30:00.000 BP 2018-01-12 13:56:39.009 EP Long 1334.90 1 1 1 3.20 -29.20 3.20 F 3.30 -0.20 3.30 -0.20 0.0% 97.1% 91.4% 0.00 00:26:39 1338.20 1334.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1341.13 2018-01-12 14:06:05.048 BP 2018-01-15 00:21:00.000 EP Short 1337.83 3 2 2 -9.90 -39.10 -9.90 F 1.10 0.00 0.00 0.00 80.9% -197.0% -197.0% 0.00 58:14:54 1344.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1335.12 2018-01-15 10:00:35.057 BP 2018-01-18 09:47:00.000 EP Short 1336.11 27 6 6 26.60 -12.50 26.60 F 33.80 -1.60 0.00 0.00 86.9% 21.0% 13.6% 0.00 71:46:24 1345.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1333.34 2018-01-18 10:40:00.000 BP 2018-01-23 06:16:00.000 EP Short 1330.90 10 4 4 -24.40 -36.90 -24.40 F 0.00 -15.20 0.00 0.00 88.6% 48.4% -31.6% 0.00 115:36:00 1338.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1338.47 2018-01-23 09:03:29.036 BP 2018-01-24 03:02:00.000 EP Short 1335.64 7 5 5 -19.80 -56.70 -19.80 F 4.30 -14.10 4.30 -0.60 48.1% 11.3% -13.9% 0.00 17:58:30 1344.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1351.20 2018-01-24 03:02:00.000 BP 2018-01-24 07:54:17.002 EP Long 1343.80 1 1 1 7.40 -49.30 7.40 F 7.50 -0.30 7.50 -0.30 4.1% 98.7% 94.9% 0.00 04:52:17 1351.30 1343.50 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1355.50 2018-01-24 07:54:17.002 BP 2018-01-24 13:30:00.000 EP Short 1352.45 4 3 3 -12.20 -61.50 -12.20 F 0.00 -1.30 0.00 0.00 99.3% -57.7% -107.7% 0.00 05:35:42 1356.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1357.20 2018-01-24 13:51:59.000 BP 2018-01-24 14:57:59.006 EP Long 1358.10 1 1 1 -0.90 -62.40 -0.90 F 3.50 -1.10 3.50 -1.10 0.0% 4.3% -19.6% 0.00 01:06:00 1361.60 1357.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1361.10 2018-01-24 14:57:59.006 BP 2018-01-24 22:31:00.000 EP Short 1358.40 4 3 3 -10.80 -73.20 -10.80 F 0.20 -4.40 0.20 -4.40 35.7% 38.0% -58.7% 0.00 07:33:00 1362.10 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1362.70 2018-01-24 22:34:00.000 BP 2018-01-25 01:53:00.000 EP Long 1362.60 1 1 1 0.10 -73.10 0.10 F 0.10 -1362.60 0.10 -1362.60 0.0% 100.0% 0.0% 0.00 03:19:00 1362.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1351.99 2018-01-25 01:55:00.000 BP 2018-01-26 02:38:46.009 EP Short 1353.84 27 7 7 49.90 -23.20 49.90 F 64.30 -6.80 0.00 0.00 94.4% 91.5% 69.3% 0.00 24:43:46 1362.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1345.02 2018-01-26 04:10:00.000 BP 2018-01-29 18:13:59.000 EP Short 1345.98 16 4 4 15.30 -7.90 15.30 F 27.30 0.00 0.00 0.00 99.4% 35.2% 35.2% 0.00 86:03:59 1354.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1340.00 2018-01-29 19:14:00.000 BP 2018-01-29 21:26:00.000 EP Short 1342.77 3 3 3 8.30 0.40 8.30 F 0.00 0.00 0.00 0.00 0.9% 0.0% 0.0% 0.00 02:12:00 1345.30 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1342.42 2018-01-29 21:26:00.000 BP 2018-01-30 04:48:24.017 EP Short 1340.22 4 4 4 -8.80 -8.40 -8.80 F 0.00 0.00 0.00 0.00 100.0% 0.0% 0.0% 0.00 07:22:24 1343.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1346.80 2018-01-30 05:31:00.000 BP 2018-01-30 07:29:00.000 EP Long 1349.30 1 1 1 -2.50 -10.90 -2.50 F 0.00 -1349.30 0.00 -1349.30 0.0% 99.8% -0.2% 0.00 01:58:00 1349.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1350.80 2018-01-30 09:01:52.021 BP 2018-01-30 09:12:55.008 EP Short 1349.80 1 1 1 -1.00 -11.90 -1.00 F 4.10 -1.00 4.10 -1.00 95.3% 0.0% -19.6% 0.00 00:11:02 1350.80 1345.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1344.13 2018-01-30 09:41:00.000 BP 2018-01-31 01:01:00.000 EP Short 1346.50 6 4 4 14.20 2.30 14.20 F 17.10 0.00 0.00 0.00 99.7% -6.8% -6.8% 0.00 15:20:00 1350.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1341.65 2018-01-31 11:51:00.000 BP 2018-01-31 14:37:10.006 EP Short 1342.11 14 7 7 6.50 8.80 6.50 F 7.40 -7.80 0.70 -4.20 72.5% 62.3% -6.0% 0.00 02:46:10 1348.50 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1344.77 2018-01-31 14:37:10.006 BP 2018-01-31 18:05:00.000 EP Long 1343.50 4 2 2 5.10 13.90 5.10 F 13.70 -2683.90 8.80 -1342.20 1.4% 97.2% 1.2% 0.00 03:27:49 1351.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1349.96 2018-01-31 18:05:00.000 BP 2018-02-01 16:06:57.000 EP Short 1348.13 7 3 3 -12.80 1.10 -12.80 F 1.30 -6.00 0.00 0.00 69.4% -547.3% -590.1% 0.00 22:01:57 1354.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1351.60 2018-02-01 16:09:00.000 BP 2018-02-01 18:00:58.000 EP Long 1354.30 1 1 1 -2.70 -1.60 -2.70 F 0.00 -2.70 0.00 -2.70 0.0% 0.0% -100.0% 0.00 01:51:58 1354.30 1351.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1338.50 2018-02-01 18:00:58.000 BP 2018-02-02 16:50:00.000 EP Short 1342.86 13 5 5 56.70 55.10 56.70 F 61.70 -1.30 0.00 0.00 74.2% 427.0% 419.3% 0.00 22:49:02 1354.30 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1335.32 2018-02-02 16:51:00.000 BP 2018-02-05 07:31:00.000 EP Short 1334.28 9 4 4 -9.40 45.70 -9.40 F 4.40 0.00 0.00 0.00 86.3% -60.0% -60.0% 0.00 62:40:00 1338.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1340.93 2018-02-05 07:31:00.000 BP 2018-02-05 15:06:00.000 EP Short 1339.15 4 3 3 -7.10 38.60 -7.10 F 3.10 -3.50 3.10 -3.50 99.9% 48.4% -28.1% 0.00 07:35:00 1343.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1340.70 2018-02-05 15:06:00.000 BP 2018-02-05 15:28:00.000 EP Long 1341.20 3 3 3 -1.50 37.10 -1.50 F 9.60 -2683.50 3.50 -1340.90 19.7% 99.7% -0.0% 0.00 00:22:00 1344.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1347.29 2018-02-05 15:28:00.000 BP 2018-02-05 21:08:00.000 EP Short 1344.94 8 5 5 -18.80 18.30 -18.80 F 0.00 -16.20 0.00 0.00 87.7% 40.7% -21.8% 0.00 05:40:00 1348.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1345.47 2018-02-05 21:09:00.000 BP 2018-02-05 23:56:00.000 EP Long 1348.03 3 3 3 -7.70 10.60 -7.70 F 1.70 -4044.10 1.70 -1348.70 0.0% 99.9% -0.1% 0.00 02:47:00 1348.70 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1332.10 2018-02-05 23:56:00.000 BP 2018-02-07 10:19:59.019 EP Short 1334.37 19 4 4 43.20 53.80 43.20 F 46.20 -0.80 0.00 0.00 93.8% 112.0% 106.8% 0.00 34:23:59 1348.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1317.97 2018-02-07 10:19:59.019 BP 2018-02-07 16:25:52.000 EP Short 1319.16 7 4 4 8.30 62.10 8.30 F 19.70 0.00 0.00 0.00 99.5% -7.0% -7.0% 0.00 06:05:52 1326.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1316.50 2018-02-07 19:21:00.000 BP 2018-02-08 12:23:00.000 EP Short 1315.64 10 3 3 -8.60 53.50 -8.60 F 10.10 -0.70 0.00 0.00 77.4% -48.9% -68.9% 0.00 17:02:00 1322.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1319.96 2018-02-08 12:42:00.000 BP 2018-02-09 12:23:00.000 EP Short 1318.56 11 4 4 -15.40 38.10 -15.40 F 0.00 -6.50 0.00 0.00 99.6% 62.6% -10.2% 0.00 23:41:00 1324.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1320.76 2018-02-09 12:23:00.000 BP 2018-02-11 20:35:00.000 EP Short 1318.80 7 3 3 -13.70 24.40 -13.70 F 3.90 -0.50 0.00 0.00 99.9% -161.8% -190.3% 0.00 56:12:00 1330.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1322.90 2018-02-11 20:35:00.000 BP 2018-02-12 09:46:33.028 EP Short 1325.12 5 4 4 11.10 35.50 11.10 F 3.90 0.00 0.00 0.00 99.9% -19.0% -19.0% 0.00 13:11:33 1328.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1323.80 2018-02-12 10:36:58.002 BP 2018-02-12 15:58:00.000 EP Long 1326.20 1 1 1 -2.40 33.10 -2.40 F 2.10 -2.40 2.10 -2.40 0.0% 0.0% -53.3% 0.00 05:21:01 1328.30 1323.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1330.18 2018-02-12 15:58:00.000 BP 2018-02-13 21:22:59.006 EP Short 1327.73 10 3 3 -24.50 8.60 -24.50 F 0.00 -16.60 0.00 0.00 88.7% 67.2% -12.8% 0.00 29:24:59 1336.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1328.54 2018-02-13 22:56:32.009 BP 2018-02-14 09:05:00.000 EP Short 1332.86 5 3 3 21.60 30.20 21.60 F 39.70 -0.90 20.10 -0.70 65.8% 15.0% 13.4% 0.00 10:08:27 1339.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1337.00 2018-02-14 09:37:49.101 BP 2018-02-14 09:38:00.000 EP Short 1336.60 1 1 1 -0.40 29.80 -0.40 F 0.00 0.00 0.00 0.00 89.1% 0.0% 0.0% 0.00 00:00:10 1337.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1343.50 2018-02-14 10:06:47.394 BP 2018-02-14 10:10:00.000 EP Short 1339.20 1 1 1 -4.30 25.50 -4.30 F 0.00 0.00 0.00 0.00 69.5% 0.0% 0.0% 0.00 00:03:12 1343.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1348.20 2018-02-14 10:21:59.071 BP 2018-02-14 10:22:00.000 EP Short 1347.20 1 1 1 -1.00 24.50 -1.00 F 0.00 0.00 0.00 0.00 92.7% 0.0% 0.0% 0.00 00:00:00 1348.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1357.00 2018-02-14 12:51:17.056 BP 2018-02-15 03:17:11.062 EP Short 1353.67 3 3 3 -10.00 14.50 -10.00 F 0.00 0.00 0.00 0.00 98.3% 0.0% 0.0% 0.00 14:25:54 1358.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1355.30 2018-02-15 03:18:00.000 BP 2018-02-15 06:14:52.000 EP Long 1358.70 1 1 1 -3.40 11.10 -3.40 F 1.10 -3.40 1.10 -3.40 0.0% 0.0% -75.6% 0.00 02:56:52 1359.80 1355.30 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1355.13 2018-02-15 06:14:52.000 BP 2018-02-15 21:46:05.024 EP Short 1354.32 8 3 3 -6.40 4.70 -6.40 F 3.60 -4.70 0.00 0.00 71.1% 30.8% 5.8% 0.00 15:31:13 1359.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1359.80 2018-02-15 23:19:00.000 BP 2018-02-16 07:14:00.000 EP Long 1361.90 1 1 1 -2.10 2.60 -2.10 F 2.50 -2.30 2.50 -2.30 0.0% 4.2% -43.8% 0.00 07:55:00 1364.40 1359.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1348.97 2018-02-16 07:14:00.000 BP 2018-02-20 09:20:21.002 EP Short 1352.54 10 4 4 35.70 38.30 35.70 F 28.80 0.00 0.00 0.00 70.1% 61.9% 61.9% 0.00 98:06:21 1364.40 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1331.13 2018-02-20 09:49:00.000 BP 2018-02-22 08:54:00.000 EP Short 1331.70 24 5 5 13.60 51.90 13.60 F 22.50 0.00 0.00 0.00 99.1% 9.2% 9.2% 0.00 47:05:00 1343.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1333.95 2018-02-22 10:13:39.111 BP 2018-02-22 18:00:00.000 EP Short 1331.15 2 2 2 -5.60 46.30 -5.60 F 0.00 0.00 0.00 0.00 97.7% 0.0% 0.0% 0.00 07:46:20 1334.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1334.22 2018-02-22 19:53:00.000 BP 2018-02-26 03:37:59.000 EP Short 1331.02 5 3 3 -16.00 30.30 -16.00 F 1.40 0.00 0.00 0.00 52.6% -225.7% -225.7% 0.00 79:44:59 1340.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1332.37 2018-02-26 03:37:59.000 BP 2018-02-27 08:38:03.032 EP Short 1333.36 10 4 4 9.90 40.20 9.90 F 17.60 0.00 0.00 0.00 99.3% 12.7% 12.7% 0.00 29:00:04 1342.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1317.32 2018-02-27 08:38:03.041 BP 2018-03-01 09:00:04.038 EP Short 1319.13 23 6 6 41.60 81.80 41.60 F 30.10 -5.60 0.60 -5.60 98.8% 18.2% 17.5% 0.00 48:22:00 1332.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1313.21 2018-03-01 09:13:00.000 BP 2018-03-02 06:13:00.000 EP Short 1310.98 18 4 4 -40.10 41.70 -40.10 F 4.00 -27.70 4.00 -0.70 99.8% 42.6% -31.3% 0.00 21:00:00 1324.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1324.35 2018-03-02 10:37:00.000 BP 2018-03-04 19:44:27.000 EP Short 1321.00 6 5 5 -20.10 21.60 -20.10 F 0.00 -10.10 0.00 0.00 69.8% 10.1% -6.6% 0.00 57:07:27 1326.60 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1324.35 2018-03-05 03:46:58.008 BP 2018-03-06 08:37:00.000 EP Short 1323.26 8 4 4 -8.70 12.90 -8.70 F 6.80 0.00 0.00 0.00 99.7% -31.6% -31.6% 0.00 28:50:01 1331.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1338.60 2018-03-06 10:05:00.000 BP 2018-03-06 11:04:44.016 EP Long 1334.90 1 1 1 3.70 16.60 3.70 F 3.90 -0.80 3.90 -0.80 0.0% 95.7% 78.7% 0.00 00:59:44 1338.80 1334.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1337.00 2018-03-06 11:05:00.022 BP 2018-03-06 11:36:00.000 EP Short 1338.70 1 1 1 1.70 18.30 1.70 F 0.00 0.00 0.00 0.00 95.8% 0.0% 0.0% 0.00 00:30:59 1338.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1340.13 2018-03-06 11:36:00.000 BP 2018-03-06 18:02:00.000 EP Short 1335.07 3 3 3 -15.20 3.10 -15.20 F 0.00 0.00 0.00 0.00 99.7% 0.0% 0.0% 0.00 06:26:00 1341.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1328.29 2018-03-06 20:00:51.000 BP 2018-03-08 01:42:31.063 EP Short 1330.14 8 5 5 14.80 17.90 14.80 F 21.50 0.00 0.00 0.00 74.6% -3.0% -3.0% 0.00 29:41:40 1337.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1318.83 2018-03-08 04:01:59.001 BP 2018-03-09 08:31:00.000 EP Short 1320.94 9 4 4 19.00 36.90 19.00 F 17.40 0.00 0.00 0.00 99.5% 13.6% 13.6% 0.00 28:29:00 1327.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1320.29 2018-03-09 08:31:00.000 BP 2018-03-13 08:32:00.000 EP Short 1319.61 16 5 5 -11.00 25.90 -11.00 F 0.00 -16.20 0.00 0.00 99.7% 75.6% 0.6% 0.00 95:01:00 1325.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1321.80 2018-03-13 08:32:00.000 BP 2018-03-13 08:32:00.000 EP Long 1321.90 1 1 1 -0.10 25.80 -0.10 F 0.00 -1321.90 0.00 -1321.90 0.0% 100.0% -0.0% 0.00 00:00:00 1321.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1323.10 2018-03-13 08:42:43.049 BP 2018-03-13 10:13:00.000 EP Long 1326.20 2 2 2 -6.20 19.60 -6.20 F 4.00 -1330.20 2.40 -1325.80 0.0% 99.5% -0.2% 0.00 01:30:16 1328.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1322.58 2018-03-13 10:13:00.000 BP 2018-03-16 05:25:01.021 EP Short 1323.05 16 6 6 7.50 27.10 7.50 F 0.00 -15.90 0.00 0.00 93.2% 75.1% 0.1% 0.00 67:12:01 1330.50 0.00 20-40 S3.twconfig 3 0 [Sim]MGCZ22-COMEX 1313.40 2018-03-16 08:58:00.000 BP 2018-03-19 11:36:00.000 EP Short 1313.16 7 4 4 -1.70 25.40 -1.70 F 10.30 0.00 0.00 0.00 99.6% -20.4% -20.4% 0.00 74:38:00 1318.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1312.39 2018-03-19 11:50:32.006 BP 2018-03-21 03:44:56.000 EP Short 1313.51 7 4 4 7.90 33.30 7.90 F 18.40 0.00 0.00 0.00 99.3% 6.8% 6.8% 0.00 39:54:23 1318.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1321.90 2018-03-21 09:17:50.098 BP 2018-03-21 09:23:00.000 EP Short 1319.50 1 1 1 -2.40 30.90 -2.40 F 0.00 0.00 0.00 0.00 98.3% 0.0% 0.0% 0.00 00:05:09 1321.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1324.07 2018-03-21 09:55:00.000 BP 2018-03-21 14:15:14.060 EP Short 1322.53 12 4 4 -18.60 12.30 -18.60 F 3.00 -17.60 3.00 -3.50 99.7% 41.6% -50.7% 0.00 04:20:14 1328.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1325.18 2018-03-21 14:23:00.000 BP 2018-03-21 14:47:00.000 EP Short 1323.70 5 4 4 -7.40 4.90 -7.40 F 4.00 -0.50 4.00 -0.50 99.8% -34.9% -39.4% 0.00 00:24:00 1327.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1329.60 2018-03-21 14:50:08.012 BP 2018-03-21 14:52:00.000 EP Short 1329.20 2 2 2 -0.80 4.10 -0.80 F 0.00 0.00 0.00 0.00 94.3% 0.0% 0.0% 0.00 00:01:51 1329.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1335.10 2018-03-21 15:11:01.017 BP 2018-03-21 15:34:00.000 EP Short 1333.50 1 1 1 -1.60 2.50 -1.60 F 0.00 0.00 0.00 0.00 98.2% 0.0% 0.0% 0.00 00:22:58 1335.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1330.58 2018-03-21 16:04:00.000 BP 2018-03-22 18:38:56.007 EP Short 1329.40 10 4 4 -11.80 -9.30 -11.80 F 1.20 -3.00 0.00 0.00 70.0% -13.2% -53.2% 0.00 26:34:56 1336.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1335.60 2018-03-22 20:31:00.045 BP 2018-03-22 20:31:58.000 EP Short 1334.60 1 1 1 -1.00 -10.30 -1.00 F 0.00 0.00 0.00 0.00 91.3% 0.0% 0.0% 0.00 00:00:57 1335.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1347.53 2018-03-23 02:20:32.000 BP 2018-03-26 09:31:00.000 EP Short 1344.75 12 3 3 -33.30 -43.60 -33.30 F 0.00 -24.30 0.00 0.00 99.6% 64.7% -18.6% 0.00 79:10:28 1351.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1354.30 2018-03-26 10:06:35.091 BP 2018-03-26 10:07:00.000 EP Short 1353.80 1 1 1 -0.50 -44.10 -0.50 F 0.00 0.00 0.00 0.00 92.7% 0.0% 0.0% 0.00 00:00:24 1354.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1359.30 2018-03-26 18:00:00.000 BP 2018-03-26 18:00:00.000 EP Short 1359.30 1 1 1 0.00 -44.10 0.00 F 7.50 0.00 7.50 0.00 100.0% 0.0% 0.0% 0.00 00:00:00 1359.30 1351.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1357.40 2018-03-26 18:00:00.000 BP 2018-03-27 04:41:00.000 EP Long 1359.00 2 2 2 -3.20 -47.30 -3.20 F 7.20 -1361.40 3.90 -1359.30 0.0% 99.5% -0.1% 0.00 10:41:00 1362.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1349.89 2018-03-27 04:41:00.000 BP 2018-03-27 21:29:00.000 EP Short 1354.81 7 6 6 34.50 -12.80 34.50 F 33.40 0.00 0.00 0.00 37.0% -0.1% -0.1% 0.00 16:48:00 1362.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1335.79 2018-03-28 00:33:00.000 BP 2018-04-02 11:40:00.000 EP Short 1339.58 11 4 4 41.70 28.90 41.70 F 60.80 0.00 0.00 0.00 72.5% 132.6% 132.6% 0.00 131:07:00 1352.20 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1344.00 2018-04-02 11:40:00.000 BP 2018-04-02 12:03:23.018 EP Short 1340.10 1 1 1 -3.90 25.00 -3.90 F 0.10 -4.00 0.10 -4.00 100.0% 2.4% -95.1% 0.00 00:23:23 1344.10 1340.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1348.90 2018-04-02 13:19:00.000 BP 2018-04-02 14:00:17.000 EP Long 1345.10 1 1 1 3.80 28.80 3.80 F 4.00 0.00 4.00 0.00 0.0% 95.0% 95.0% 0.00 00:41:17 1349.10 1345.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1340.28 2018-04-02 14:51:00.000 BP 2018-04-04 03:10:00.000 EP Short 1340.83 12 4 4 6.70 35.50 6.70 F 17.80 0.00 0.00 0.00 99.6% 47.5% 47.5% 0.00 36:19:00 1346.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1347.20 2018-04-04 03:54:53.000 BP 2018-04-04 04:20:00.000 EP Short 1343.60 1 1 1 -3.60 31.90 -3.60 F 0.00 0.00 0.00 0.00 97.9% 0.0% 0.0% 0.00 00:25:07 1347.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1348.70 2018-04-04 04:40:00.000 BP 2018-04-04 07:52:30.270 EP Short 1345.80 1 1 1 -2.90 29.00 -2.90 F 0.60 -4.00 0.60 -4.00 100.0% 23.9% -63.0% 0.00 03:12:30 1349.80 1345.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1347.40 2018-04-04 07:53:00.000 BP 2018-04-04 08:16:00.000 EP Long 1350.70 1 1 1 -3.30 25.70 -3.30 F 0.70 -3.80 0.70 -3.80 0.0% 11.1% -73.3% 0.00 00:23:00 1351.40 1346.90 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1331.08 2018-04-04 08:16:00.000 BP 2018-04-06 05:34:35.000 EP Short 1334.10 24 7 7 72.40 98.10 72.40 F 86.90 0.00 0.00 0.00 87.1% 16.6% 16.6% 0.00 45:18:35 1352.50 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1325.40 2018-04-06 05:34:35.000 BP 2018-04-06 08:29:58.053 EP Long 1328.90 2 2 2 -7.00 91.10 -7.00 F 0.30 -2657.80 0.30 -1328.90 0.0% 99.8% -0.2% 0.00 02:55:23 1329.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1332.52 2018-04-06 08:30:00.000 BP 2018-04-06 09:24:00.000 EP Short 1328.09 8 4 4 -35.50 55.60 -35.50 F 1.20 -31.30 1.20 -5.50 81.2% 39.1% -51.9% 0.00 00:54:00 1335.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1336.27 2018-04-06 09:28:24.082 BP 2018-04-09 14:38:06.000 EP Short 1335.48 6 4 4 -4.70 50.90 -4.70 F 3.30 -0.90 0.00 0.00 82.2% -56.4% -73.1% 0.00 77:09:41 1340.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1348.81 2018-04-09 21:27:00.000 BP 2018-04-12 22:13:31.000 EP Short 1348.22 30 4 4 -17.80 33.10 -17.80 F 3.90 -54.20 0.00 0.00 99.3% 60.7% -25.9% 0.00 72:46:31 1366.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1347.00 2018-04-13 02:00:00.000 BP 2018-04-18 06:53:00.000 EP Short 1345.78 27 4 4 -32.90 0.20 -32.90 F 0.00 -24.00 0.00 0.00 99.7% 77.4% -15.2% 0.00 124:53:00 1352.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1357.00 2018-04-18 07:24:00.000 BP 2018-04-18 09:26:40.080 EP Long 1353.10 1 1 1 3.90 4.10 3.90 F 4.00 -0.60 4.00 -0.60 0.0% 97.8% 84.8% 0.00 02:02:40 1357.10 1352.50 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1354.40 2018-04-18 09:36:00.000 BP 2018-04-18 09:47:45.059 EP Long 1358.40 1 1 1 -4.00 0.10 -4.00 F 0.60 -4.00 0.60 -4.00 0.0% 0.0% -87.0% 0.00 00:11:45 1359.00 1354.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1351.18 2018-04-18 09:48:00.000 BP 2018-04-19 12:21:17.025 EP Short 1349.88 17 6 6 -22.10 -22.00 -22.10 F 3.00 -23.20 1.00 -4.50 87.2% 62.6% -6.4% 0.00 26:33:17 1359.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1346.90 2018-04-19 12:21:17.025 BP 2018-04-19 14:41:59.005 EP Long 1348.10 1 1 1 -1.20 -23.20 -1.20 F 0.00 -1348.10 0.00 -1348.10 2.0% 99.9% -0.1% 0.00 02:20:41 1348.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1335.96 2018-04-19 20:20:00.000 BP 2018-04-24 02:22:47.011 EP Short 1339.47 10 4 4 35.10 11.90 35.10 F 12.70 0.00 0.00 0.00 88.5% 39.7% 39.7% 0.00 102:02:47 1349.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1323.79 2018-04-24 02:54:59.000 BP 2018-04-27 09:37:00.000 EP Short 1324.52 15 5 5 10.90 22.80 10.90 F 21.30 -10.80 1.90 -4.00 99.4% 56.5% 7.4% 0.00 78:42:01 1333.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1316.42 2018-04-30 00:00:00.000 BP 2018-04-30 12:52:22.006 EP Short 1317.47 6 5 5 6.30 29.10 6.30 F 17.30 -4.00 1.30 -4.00 54.1% 0.0% -3.1% 0.00 12:52:22 1326.40 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1309.13 2018-04-30 13:33:00.000 BP 2018-05-01 12:52:08.001 EP Short 1311.59 9 5 5 22.10 51.20 22.10 F 21.50 0.00 0.00 0.00 99.4% 11.8% 11.8% 0.00 23:19:08 1320.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1310.45 2018-05-01 16:06:00.000 BP 2018-05-01 23:41:00.000 EP Short 1304.80 2 2 2 -11.30 39.90 -11.30 F 0.70 -4.00 0.70 -4.00 100.0% -35.1% -120.2% 0.00 07:35:00 1312.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1309.53 2018-05-02 01:18:00.000 BP 2018-05-03 00:00:59.000 EP Short 1308.99 7 4 4 -3.80 36.10 -3.80 F 0.00 -5.20 0.00 0.00 66.4% 151.4% 94.2% 0.00 22:42:59 1314.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1314.17 2018-05-03 02:21:00.000 BP 2018-05-04 09:05:41.004 EP Short 1312.99 9 4 4 -10.60 25.50 -10.60 F 2.70 -14.50 2.70 -3.50 99.7% 68.4% -21.9% 0.00 30:44:41 1319.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1313.00 2018-05-04 09:06:00.000 BP 2018-05-04 11:07:00.000 EP Short 1310.56 5 5 5 -12.20 13.30 -12.20 F 0.00 0.00 0.00 0.00 99.7% 0.0% 0.0% 0.00 02:01:00 1316.20 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1314.90 2018-05-04 11:07:00.000 BP 2018-05-04 13:26:40.022 EP Short 1311.00 1 1 1 -3.90 9.40 -3.90 F 0.60 -4.00 0.60 -4.00 100.0% 2.2% -84.8% 0.00 02:19:40 1315.00 1310.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1316.10 2018-05-06 20:11:00.000 BP 2018-05-07 01:07:00.000 EP Long 1317.00 1 1 1 -0.90 8.50 -0.90 F 3.10 -1.00 3.10 -1.00 0.0% 2.4% -22.0% 0.00 04:56:00 1320.10 1316.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1313.83 2018-05-07 01:07:00.000 BP 2018-05-08 12:45:00.000 EP Short 1312.94 9 4 4 -8.00 0.50 -8.00 F 3.60 0.00 0.00 0.00 77.8% -249.0% -249.0% 0.00 35:38:00 1320.10 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1310.66 2018-05-08 12:45:00.000 BP 2018-05-09 10:14:28.150 EP Short 1310.08 10 4 4 -5.80 -5.30 -5.80 F 14.20 -4.00 2.30 -4.00 99.4% 50.4% -2.3% 0.00 21:29:28 1318.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1316.07 2018-05-09 11:19:00.000 BP 2018-05-10 06:39:08.020 EP Short 1313.27 3 3 3 -8.40 -13.70 -8.40 F 0.00 0.00 0.00 0.00 99.9% 0.0% 0.0% 0.00 19:20:08 1317.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1318.90 2018-05-10 07:15:00.000 BP 2018-05-10 08:30:01.185 EP Short 1315.90 1 1 1 -3.00 -16.70 -3.00 F 0.00 -4.00 0.00 -4.00 100.0% 25.0% -75.0% 0.00 01:15:01 1319.90 1315.90 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1319.20 2018-05-10 08:31:00.000 BP 2018-05-10 09:45:00.000 EP Long 1321.20 3 3 3 -6.00 -22.70 -6.00 F 6.50 -12.70 2.20 -5.30 0.1% 52.4% -16.8% 0.00 01:14:00 1323.40 1315.90 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1302.99 2018-05-10 09:45:00.000 BP 2018-05-18 14:35:00.000 EP Short 1304.35 35 7 7 47.70 25.00 47.70 F 64.50 -26.70 0.00 0.00 95.6% 50.8% 25.1% 0.00 196:50:00 1324.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1286.32 2018-05-20 20:14:49.022 BP 2018-05-21 09:54:00.000 EP Short 1288.64 5 4 4 11.60 36.60 11.60 F 11.60 0.00 0.00 0.00 48.4% 1.2% 1.2% 0.00 13:39:10 1293.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1290.80 2018-05-21 09:54:00.000 BP 2018-05-21 13:13:54.000 EP Short 1286.80 1 1 1 -4.00 32.60 -4.00 F 0.50 -4.00 0.50 -4.00 100.0% 0.0% -88.9% 0.00 03:19:54 1290.80 1286.30 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1293.30 2018-05-21 21:48:00.000 BP 2018-05-22 04:02:00.000 EP Short 1289.90 2 2 2 -6.80 25.80 -6.80 F 5.40 -10.10 2.70 -6.10 99.9% 28.2% -34.2% 0.00 06:14:00 1296.00 1287.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1293.40 2018-05-22 04:02:00.000 BP 2018-05-22 04:05:00.000 EP Long 1293.80 1 1 1 -0.40 25.40 -0.40 F 0.00 -1293.80 0.00 -1293.80 25.0% 100.0% -0.0% 0.00 00:03:00 1293.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1292.54 2018-05-22 09:50:59.002 BP 2018-05-23 11:56:00.000 EP Short 1292.24 11 4 4 -3.30 22.10 -3.30 F 1.00 -7.50 0.00 0.00 91.2% 64.7% 10.2% 0.00 26:05:00 1296.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1294.28 2018-05-23 11:56:00.000 BP 2018-05-23 20:05:00.000 EP Short 1291.73 4 3 3 -10.20 11.90 -10.20 F 0.00 -2.80 0.00 0.00 99.9% 10.7% -14.3% 0.00 08:09:00 1295.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1298.60 2018-05-24 08:38:22.429 BP 2018-05-24 08:39:00.000 EP Short 1297.90 1 1 1 -0.70 11.20 -0.70 F 0.00 0.00 0.00 0.00 83.8% 0.0% 0.0% 0.00 00:00:37 1298.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1302.60 2018-05-24 09:50:02.442 BP 2018-05-24 09:51:00.000 EP Short 1300.90 1 1 1 -1.70 9.50 -1.70 F 0.00 0.00 0.00 0.00 66.7% 0.0% 0.0% 0.00 00:00:57 1302.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1305.33 2018-05-24 20:19:00.000 BP 2018-05-25 08:00:00.000 EP Short 1303.80 3 3 3 -4.60 4.90 -4.60 F 0.00 0.00 0.00 0.00 46.6% 0.0% 0.0% 0.00 11:41:00 1306.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1300.33 2018-05-25 08:00:00.000 BP 2018-05-29 04:47:57.011 EP Short 1300.83 8 4 4 4.00 8.90 4.00 F 12.30 -3.50 4.00 -3.50 99.5% 41.6% 29.9% 0.00 92:47:57 1307.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1296.88 2018-05-29 04:47:57.011 BP 2018-05-29 10:21:35.002 EP Short 1298.14 8 6 6 10.10 19.00 10.10 F 5.60 0.00 0.00 0.00 99.5% 2.0% 2.0% 0.00 05:33:37 1304.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1303.55 2018-05-29 10:47:29.031 BP 2018-05-29 18:02:53.000 EP Short 1299.38 4 3 3 -16.70 2.30 -16.70 F 0.00 -5.10 0.00 0.00 97.5% 8.3% -41.7% 0.00 07:15:23 1304.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1306.65 2018-05-30 00:00:56.000 BP 2018-05-30 12:01:00.000 EP Short 1303.35 4 3 3 -13.20 -10.90 -13.20 F 0.00 -4.60 0.00 0.00 34.0% 16.8% -8.2% 0.00 12:00:04 1308.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1306.00 2018-05-30 12:01:00.000 BP 2018-05-30 18:00:00.000 EP Long 1308.50 1 1 1 -2.50 -13.40 -2.50 F 0.00 -3.90 0.00 -3.90 3.7% 35.9% -64.1% 0.00 05:59:00 1308.50 1304.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1302.29 2018-05-30 18:00:00.000 BP 2018-06-04 07:58:59.002 EP Short 1302.56 21 5 5 5.70 -7.70 5.70 F 17.50 -6.50 0.00 0.00 96.3% 101.9% 59.0% 0.00 109:58:59 1311.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1299.43 2018-06-04 11:10:00.000 BP 2018-06-05 12:24:00.000 EP Short 1297.27 6 4 4 -13.00 -20.70 -13.00 F 0.00 -4.20 0.00 0.00 59.8% 18.6% -21.4% 0.00 25:14:00 1303.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1302.20 2018-06-05 14:59:00.000 BP 2018-06-08 03:56:00.000 EP Short 1301.08 18 4 4 -20.10 -40.80 -20.10 F 0.00 -11.20 0.00 0.00 99.7% 64.0% -19.3% 0.00 60:57:00 1305.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1303.65 2018-06-11 02:27:00.000 BP 2018-06-11 11:20:00.000 EP Short 1302.23 6 3 3 -8.50 -49.30 -8.50 F 0.60 -3.80 0.00 0.00 52.7% -51.1% -84.4% 0.00 08:53:00 1306.10 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1302.00 2018-06-11 19:12:56.127 BP 2018-06-12 12:02:00.000 EP Short 1302.20 7 4 4 1.40 -47.90 1.40 F 4.30 -0.30 0.00 0.00 80.5% 202.7% 145.5% 0.00 16:49:03 1306.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1301.51 2018-06-12 12:02:00.000 BP 2018-06-14 05:27:00.000 EP Short 1298.88 8 4 4 -21.10 -69.00 -21.10 F 4.00 -6.10 4.00 -0.80 99.8% -268.0% -284.6% 0.00 41:25:00 1308.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1307.90 2018-06-14 08:21:00.000 BP 2018-06-14 09:03:00.000 EP Long 1310.80 1 1 1 -2.90 -71.90 -2.90 F 2.20 -3.00 2.20 -3.00 0.0% 1.9% -55.8% 0.00 00:42:00 1313.00 1307.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1293.87 2018-06-14 09:03:00.000 BP 2018-06-17 19:21:58.000 EP Short 1298.30 13 4 4 57.60 -14.30 57.60 F 55.20 -4.70 0.00 0.00 82.4% 134.6% 103.8% 0.00 82:18:58 1313.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1279.09 2018-06-18 02:36:00.000 BP 2018-06-19 09:58:00.000 EP Short 1280.76 7 5 5 11.70 -2.60 11.70 F 0.00 -4.20 0.00 0.00 83.4% 93.2% 36.1% 0.00 31:22:00 1286.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1270.48 2018-06-19 20:07:56.002 BP 2018-06-25 04:16:00.000 EP Short 1270.17 16 4 4 -4.90 -7.50 -4.90 F 17.70 -4.90 0.00 0.00 87.8% 25.1% 5.1% 0.00 128:08:03 1279.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1258.91 2018-06-25 04:16:00.000 BP 2018-06-28 08:55:00.000 EP Short 1260.88 19 5 5 37.40 29.90 37.40 F 48.50 -0.90 4.00 -0.90 99.1% 57.9% 56.0% 0.00 76:39:00 1272.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1247.64 2018-06-28 10:58:58.044 BP 2018-07-03 08:40:00.000 EP Short 1248.91 14 5 5 17.90 47.80 17.90 F 29.50 -6.50 0.00 0.00 85.8% 339.0% 303.3% 0.00 117:41:01 1255.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1257.54 2018-07-03 08:46:53.061 BP 2018-07-05 13:05:00.000 EP Short 1255.93 10 4 4 -16.10 31.70 -16.10 F 0.00 -11.20 0.00 0.00 97.8% 59.7% -20.3% 0.00 52:18:06 1262.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1260.14 2018-07-05 13:05:00.000 BP 2018-07-09 08:54:00.000 EP Short 1259.13 10 3 3 -10.10 21.60 -10.10 F 4.10 -6.30 0.00 0.00 99.9% -97.6% -117.6% 0.00 91:49:00 1266.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1252.15 2018-07-09 08:54:00.000 BP 2018-07-12 09:10:00.000 EP Short 1255.40 15 4 4 48.70 70.30 48.70 F 35.30 0.00 0.00 0.00 99.2% 35.6% 35.6% 0.00 72:16:00 1265.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1229.85 2018-07-13 00:55:59.001 BP 2018-07-19 13:20:00.000 EP Short 1232.07 25 5 5 55.60 125.90 55.60 F 74.40 -1.10 0.00 0.00 90.4% 3518437209006.9% 3518437208986.9% 0.00 156:24:00 1248.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1227.90 2018-07-19 13:26:00.000 BP 2018-07-19 13:36:43.001 EP Short 1223.90 1 1 1 -4.00 121.90 -4.00 F 0.20 -4.00 0.20 -4.00 100.0% 0.0% -95.2% 0.00 00:10:43 1227.90 1223.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1222.38 2018-07-19 13:50:00.000 BP 2018-07-20 09:18:59.001 EP Short 1223.90 10 5 5 15.20 137.10 15.20 F 28.60 0.00 0.00 0.00 79.6% -8.4% -8.4% 0.00 19:28:59 1229.60 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1225.92 2018-07-20 09:18:59.001 BP 2018-07-27 09:08:00.000 EP Short 1226.20 23 5 5 6.30 143.40 6.30 F 14.50 -17.40 2.10 -4.00 99.3% 54.3% -7.9% 0.00 167:49:00 1235.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1231.57 2018-07-27 15:00:00.000 BP 2018-07-29 18:04:38.000 EP Short 1225.23 3 3 3 -19.00 124.40 -19.00 F 0.00 0.00 0.00 0.00 36.1% 0.0% 0.0% 0.00 51:04:38 1232.50 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1229.70 2018-07-29 22:54:16.000 BP 2018-07-30 03:54:00.000 EP Short 1228.40 2 2 2 -2.60 121.80 -2.60 F 0.00 0.00 0.00 0.00 49.8% 0.0% 0.0% 0.00 04:59:44 1230.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1230.50 2018-07-30 07:29:17.070 BP 2018-07-30 18:00:00.000 EP Long 1232.85 2 2 2 -4.70 117.10 -4.70 F 2.50 -1235.60 1.80 -1232.30 0.0% 99.6% -0.2% 0.00 10:30:42 1234.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1229.29 2018-07-30 18:00:00.000 BP 2018-07-31 09:28:00.000 EP Short 1230.06 7 4 4 5.40 122.50 5.40 F 0.00 -2.80 0.00 0.00 68.4% 67.0% 24.1% 0.00 15:28:00 1235.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1232.15 2018-07-31 09:33:52.188 BP 2018-07-31 12:31:57.019 EP Short 1230.20 2 2 2 -3.90 118.60 -3.90 F 0.00 0.00 0.00 0.00 86.6% 0.0% 0.0% 0.00 02:58:04 1234.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1224.04 2018-07-31 13:02:00.000 BP 2018-08-03 08:30:01.280 EP Short 1225.61 16 5 5 25.10 143.70 25.10 F 27.00 -0.20 4.00 -0.20 99.2% 33.2% 32.6% 0.00 67:28:01 1234.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1224.20 2018-08-03 08:31:00.000 BP 2018-08-03 10:00:00.160 EP Long 1222.50 1 1 1 1.70 145.40 1.70 F 3.10 -1.50 3.10 -1.50 0.0% 69.6% 37.0% 0.00 01:29:00 1225.60 1221.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1227.10 2018-08-03 10:26:03.033 BP 2018-08-03 10:29:00.000 EP Short 1226.30 1 1 1 -0.80 144.60 -0.80 F 0.00 0.00 0.00 0.00 96.4% 0.0% 0.0% 0.00 00:02:56 1227.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1220.17 2018-08-03 12:21:00.000 BP 2018-08-08 22:40:00.000 EP Short 1219.90 21 4 4 -5.60 139.00 -5.60 F 10.00 0.00 0.00 0.00 99.5% 44.6% 44.6% 0.00 130:19:00 1226.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1219.37 2018-08-09 03:05:50.264 BP 2018-08-10 08:08:00.000 EP Short 1219.72 9 5 5 3.20 142.20 3.20 F 7.50 -4.70 0.00 0.00 72.9% 191.6% 147.1% 0.00 29:02:09 1225.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1222.70 2018-08-10 08:08:00.000 BP 2018-08-10 09:36:22.003 EP Short 1218.70 1 1 1 -4.00 138.20 -4.00 F 0.00 -4.00 0.00 -4.00 100.0% 0.0% -100.0% 0.00 01:28:22 1222.70 1218.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1195.42 2018-08-10 11:26:59.002 BP 2018-08-15 21:01:00.000 EP Short 1201.30 24 5 5 141.10 279.30 141.10 F 94.90 0.00 0.00 0.00 98.3% 53.5% 53.5% 0.00 129:34:00 1222.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1175.10 2018-08-15 21:11:00.000 BP 2018-08-15 21:36:59.061 EP Short 1171.30 1 1 1 -3.80 275.50 -3.80 F 0.80 -4.00 0.80 -4.00 100.0% 4.2% -79.2% 0.00 00:25:59 1175.30 1170.50 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1180.00 2018-08-15 22:10:00.000 BP 2018-08-15 22:29:32.046 EP Long 1178.40 1 1 1 1.60 277.10 1.60 F 1.90 -0.30 1.90 -0.30 0.0% 86.4% 72.7% 0.00 00:19:32 1180.30 1178.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1182.20 2018-08-16 01:28:14.002 BP 2018-08-16 02:23:00.000 EP Short 1182.30 1 1 1 0.10 277.20 0.10 F 0.00 0.00 0.00 0.00 97.9% 0.0% 0.0% 0.00 00:54:45 1182.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1185.97 2018-08-16 02:23:00.000 BP 2018-08-16 12:05:00.000 EP Short 1184.03 7 3 3 -13.60 263.60 -13.60 F 1.20 -7.60 1.20 -4.00 99.8% 47.7% -45.7% 0.00 09:42:00 1188.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1187.26 2018-08-16 12:05:00.000 BP 2018-08-21 02:07:00.000 EP Short 1184.35 12 4 4 -34.90 228.70 -34.90 F 5.50 -18.00 0.00 0.00 99.7% -145.8% -179.2% 0.00 110:02:00 1202.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1200.28 2018-08-21 07:48:26.074 BP 2018-08-21 16:47:00.000 EP Short 1197.17 4 4 4 -12.40 216.30 -12.40 F 0.00 0.00 0.00 0.00 50.7% 0.0% 0.0% 0.00 08:58:33 1201.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1205.37 2018-08-22 00:18:58.001 BP 2018-08-22 09:16:00.000 EP Short 1202.93 3 3 3 -7.30 209.00 -7.30 F 0.00 0.00 0.00 0.00 50.8% 0.0% 0.0% 0.00 08:57:01 1205.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1196.88 2018-08-22 09:16:00.000 BP 2018-08-24 01:36:21.000 EP Short 1199.60 10 5 5 27.20 236.20 27.20 F 28.50 0.00 0.00 0.00 99.5% 46.0% 46.0% 0.00 40:20:21 1205.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1202.60 2018-08-24 07:41:00.000 BP 2018-08-24 09:23:59.015 EP Long 1199.60 1 1 1 3.00 239.20 3.00 F 3.20 -1.50 3.20 -1.50 0.0% 95.7% 63.8% 0.00 01:42:59 1202.80 1198.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1204.60 2018-08-24 09:24:12.016 BP 2018-08-24 10:02:00.000 EP Short 1203.50 1 1 1 -1.10 238.10 -1.10 F 0.00 0.00 0.00 0.00 98.2% 0.0% 0.0% 0.00 00:37:47 1204.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1212.00 2018-08-24 10:46:00.000 BP 2018-08-24 10:48:19.046 EP Long 1211.10 1 1 1 0.90 239.00 0.90 F 1.00 -0.10 1.00 -0.10 0.0% 90.9% 81.8% 0.00 00:02:19 1212.10 1211.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1216.63 2018-08-24 11:58:52.001 BP 2018-08-28 04:12:52.031 EP Short 1213.25 4 3 3 -13.50 225.50 -13.50 F 0.00 -1.00 0.00 0.00 99.2% -72.5% -97.5% 0.00 88:14:00 1219.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1207.23 2018-08-28 07:41:00.000 BP 2018-09-05 03:03:25.059 EP Short 1208.26 31 5 5 31.90 257.40 31.90 F 32.90 0.00 0.00 0.00 99.0% 15.2% 15.2% 0.00 187:22:25 1220.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1206.32 2018-09-05 09:06:11.135 BP 2018-09-06 04:21:00.000 EP Short 1202.65 4 2 2 -14.70 242.70 -14.70 F 0.00 -7.60 0.00 0.00 99.2% 3.5% -46.5% 0.00 19:14:48 1208.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1202.17 2018-09-06 08:10:00.000 BP 2018-09-12 13:03:00.000 EP Short 1201.91 23 4 4 -5.80 236.90 -5.80 F 17.40 0.00 0.00 0.00 99.1% 0.8% 0.8% 0.00 148:53:00 1212.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1212.36 2018-09-12 13:28:20.053 BP 2018-09-13 08:32:00.000 EP Short 1210.44 5 4 4 -9.60 227.30 -9.60 F 0.80 0.00 0.00 0.00 80.2% -130.0% -130.0% 0.00 19:03:39 1214.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1215.70 2018-09-13 08:33:00.000 BP 2018-09-13 09:00:35.114 EP Long 1212.70 1 1 1 3.00 230.30 3.00 F 3.50 -1.00 3.50 -1.00 0.0% 88.9% 66.7% 0.00 00:27:35 1216.20 1211.70 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1215.10 2018-09-13 10:03:00.000 BP 2018-09-13 10:03:00.000 EP Long 1215.20 1 1 1 -0.10 230.20 -0.10 F 0.00 -1215.20 0.00 -1215.20 0.0% 100.0% -0.0% 0.00 00:00:00 1215.20 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1209.86 2018-09-13 10:08:00.000 BP 2018-09-13 23:40:16.000 EP Short 1211.34 5 4 4 7.40 237.60 7.40 F 2.60 -1.90 2.60 -1.90 81.4% 48.8% 32.0% 0.00 13:32:16 1215.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1209.20 2018-09-14 03:32:00.000 BP 2018-09-14 08:35:00.000 EP Long 1212.60 1 1 1 -3.40 234.20 -3.40 F 1.20 -3.50 1.20 -3.50 0.0% 2.1% -72.3% 0.00 05:03:00 1213.80 1209.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1201.76 2018-09-14 08:35:00.000 BP 2018-09-17 06:46:00.112 EP Short 1206.10 5 4 4 21.70 255.90 21.70 F 9.40 0.00 0.00 0.00 51.0% -7.0% -7.0% 0.00 70:11:00 1213.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1207.90 2018-09-17 08:57:00.000 BP 2018-09-17 10:11:10.125 EP Long 1204.40 1 1 1 3.50 259.40 3.50 F 4.00 -1.00 4.00 -1.00 0.0% 90.0% 70.0% 0.00 01:14:10 1208.40 1203.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1206.40 2018-09-17 10:33:00.000 BP 2018-09-17 13:13:58.001 EP Long 1209.40 1 1 1 -3.00 256.40 -3.00 F 0.00 -1209.40 0.00 -1209.40 0.0% 99.8% -0.2% 0.00 02:40:58 1209.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1204.89 2018-09-17 13:30:00.000 BP 2018-09-18 09:35:07.023 EP Short 1204.80 7 3 3 -0.60 255.80 -0.60 F 4.40 0.00 0.00 0.00 84.5% -567.6% -567.6% 0.00 20:05:07 1208.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1204.20 2018-09-18 09:36:00.000 BP 2018-09-18 10:04:00.000 EP Long 1207.70 1 1 1 -3.50 252.30 -3.50 F 0.20 -3.90 0.20 -3.90 0.0% 9.8% -85.4% 0.00 00:28:00 1207.90 1203.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1205.06 2018-09-18 10:04:00.000 BP 2018-09-21 10:21:14.014 EP Short 1205.32 18 6 6 4.80 257.10 4.80 F 0.00 -21.90 0.00 0.00 84.0% -66.1% -143.9% 0.00 72:17:14 1213.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1203.42 2018-09-21 11:03:00.000 BP 2018-09-24 09:30:52.102 EP Short 1202.37 6 3 3 -6.30 250.80 -6.30 F 3.90 -2.00 0.30 -1.30 99.9% -26.8% -41.3% 0.00 70:27:52 1206.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1203.40 2018-09-24 11:15:00.000 BP 2018-09-26 14:04:00.000 EP Short 1203.17 9 5 5 -2.10 248.70 -2.10 F 4.50 -1.80 0.00 0.00 99.7% 21.3% -23.1% 0.00 50:49:00 1207.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1194.31 2018-09-26 14:28:20.099 BP 2018-10-01 23:04:17.016 EP Short 1194.18 21 4 4 -2.70 246.00 -2.70 F 16.30 -3.60 0.00 0.00 85.6% 39.6% 20.5% 0.00 128:35:56 1204.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1203.20 2018-10-02 03:09:00.000 BP 2018-10-02 09:57:00.000 EP Short 1194.50 2 2 2 -17.40 228.60 -17.40 F 2.70 -3.10 2.70 -3.10 99.8% -96.6% -150.0% 0.00 06:48:00 1208.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1206.10 2018-10-02 11:26:00.007 BP 2018-10-04 07:53:37.007 EP Short 1205.39 15 6 6 -10.70 217.90 -10.70 F 7.50 -6.10 0.00 -3.80 99.3% -22.5% -29.2% 0.00 44:27:37 1212.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1204.30 2018-10-04 07:53:45.014 BP 2018-10-04 08:23:00.000 EP Long 1205.70 1 1 1 -1.40 216.50 -1.40 F 0.00 -1205.70 0.00 -1205.70 0.0% 99.9% -0.1% 0.00 00:29:14 1205.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1206.30 2018-10-04 09:34:01.054 BP 2018-10-04 11:23:00.000 EP Long 1208.35 2 2 2 -4.10 212.40 -4.10 F 4.70 -1210.50 2.40 -1208.30 0.0% 99.5% -0.2% 0.00 01:48:58 1210.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1205.36 2018-10-04 11:23:00.000 BP 2018-10-05 08:30:07.016 EP Short 1205.80 5 3 3 2.20 214.60 2.20 F 3.20 0.00 0.00 0.00 50.4% -6.4% -6.4% 0.00 21:07:07 1210.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1205.10 2018-10-05 08:31:00.000 BP 2018-10-05 08:38:00.000 EP Long 1208.20 1 1 1 -3.10 211.50 -3.10 F 0.30 -3.70 0.30 -3.70 0.0% 15.0% -77.5% 0.00 00:07:00 1208.50 1204.50 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1193.88 2018-10-05 08:38:00.000 BP 2018-10-09 13:21:58.000 EP Short 1196.33 18 5 5 44.10 255.60 44.10 F 48.50 -5.30 0.00 0.00 84.0% 225.3% 203.1% 0.00 100:43:58 1209.80 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1194.50 2018-10-09 13:21:58.000 BP 2018-10-09 21:04:05.024 EP Short 1190.60 1 1 1 -3.90 251.70 -3.90 F 0.20 -4.00 0.20 -4.00 100.0% 2.4% -92.9% 0.00 07:42:07 1194.60 1190.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1196.40 2018-10-10 03:31:00.000 BP 2018-10-10 16:37:58.011 EP Short 1191.30 2 2 2 -10.20 241.50 -10.20 F 3.50 -2.90 3.50 -2.90 99.9% -34.4% -79.7% 0.00 13:06:58 1198.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1205.10 2018-10-10 21:03:00.000 BP 2018-10-11 06:12:00.000 EP Short 1200.13 4 3 3 -19.90 221.60 -19.90 F 0.00 -5.20 0.00 0.00 66.7% 34.6% -15.4% 0.00 09:09:00 1208.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1207.30 2018-10-11 06:12:00.000 BP 2018-10-11 08:30:01.178 EP Short 1205.60 1 1 1 -1.70 219.90 -1.70 F 0.00 -4.00 0.00 -4.00 100.0% 57.5% -42.5% 0.00 02:18:01 1209.60 1205.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1213.00 2018-10-11 08:31:00.000 BP 2018-10-11 08:44:14.048 EP Long 1209.10 1 1 1 3.90 223.80 3.90 F 4.00 -0.40 4.00 -0.40 0.0% 97.7% 88.6% 0.00 00:13:14 1213.10 1208.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1221.20 2018-10-11 09:24:00.000 BP 2018-10-11 13:05:00.000 EP Short 1213.47 3 2 2 -23.20 200.60 -23.20 F 1.60 -4.00 1.60 -4.00 100.0% -67.3% -148.2% 0.00 03:41:00 1224.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1229.60 2018-10-11 13:56:20.068 BP 2018-10-11 14:02:00.000 EP Short 1228.50 1 1 1 -1.10 199.50 -1.10 F 0.00 0.00 0.00 0.00 95.6% 0.0% 0.0% 0.00 00:05:39 1229.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1226.59 2018-10-11 15:16:00.000 BP 2018-10-15 05:14:00.000 EP Short 1224.66 13 4 4 -25.10 174.40 -25.10 F 0.30 -8.00 0.00 0.00 83.1% -245.4% -306.9% 0.00 85:58:00 1235.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1232.47 2018-10-15 07:42:00.000 BP 2018-10-16 08:04:19.087 EP Short 1231.49 7 3 3 -6.90 167.50 -6.90 F 1.80 -0.30 0.00 0.00 57.5% -23.8% -38.1% 0.00 24:22:19 1236.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1228.12 2018-10-16 09:02:00.000 BP 2018-10-18 07:39:29.040 EP Short 1228.33 8 3 3 1.60 169.10 1.60 F 6.50 -0.40 0.00 0.00 99.4% 47.0% 22.0% 0.00 46:37:29 1235.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1225.40 2018-10-18 08:48:00.000 BP 2018-10-18 09:05:06.001 EP Long 1229.40 1 1 1 -4.00 165.10 -4.00 F 0.00 -4.00 0.00 -4.00 0.0% 0.0% -100.0% 0.00 00:17:06 1229.40 1225.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1231.42 2018-10-18 09:07:00.000 BP 2018-10-24 09:35:30.019 EP Short 1229.95 23 4 4 -33.90 131.20 -33.90 F 0.00 -42.80 0.00 0.00 96.5% 80.1% -6.8% 0.00 144:28:30 1243.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1237.13 2018-10-24 10:20:00.000 BP 2018-10-24 21:14:00.000 EP Short 1232.33 3 3 3 -14.40 116.80 -14.40 F 0.00 0.00 0.00 0.00 99.8% 0.0% 0.0% 0.00 10:54:00 1240.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1235.72 2018-10-25 02:59:00.000 BP 2018-10-26 06:38:00.000 EP Short 1235.63 6 4 4 -0.50 116.30 -0.50 F 9.00 0.00 0.00 0.00 61.0% -67.4% -67.4% 0.00 27:39:00 1242.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1239.78 2018-10-26 06:38:00.000 BP 2018-10-26 10:54:55.211 EP Short 1236.70 4 4 4 -12.30 104.00 -12.30 F 0.00 0.00 0.00 0.00 77.5% 0.0% 0.0% 0.00 04:16:55 1241.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1243.25 2018-10-26 10:55:00.000 BP 2018-10-26 11:32:00.000 EP Long 1242.70 2 2 2 1.10 105.10 1.10 F 6.00 -2485.40 3.30 -1242.70 24.3% 99.8% 0.0% 0.00 00:37:00 1246.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1233.78 2018-10-26 11:32:00.000 BP 2018-10-29 15:42:48.140 EP Short 1235.44 14 6 6 23.30 128.40 23.30 F 30.60 -5.80 2.90 -5.80 93.5% 70.2% 61.5% 0.00 76:10:48 1246.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1229.40 2018-10-29 15:42:48.140 BP 2018-10-29 21:19:59.002 EP Long 1232.70 1 1 1 -3.30 125.10 -3.30 F 0.00 -1232.70 0.00 -1232.70 0.0% 99.7% -0.3% 0.00 05:37:10 1232.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1221.02 2018-10-29 21:22:00.000 BP 2018-10-31 12:05:00.000 EP Short 1222.15 10 4 4 11.30 136.40 11.30 F 15.10 0.00 0.00 0.00 88.2% 20.3% 20.3% 0.00 38:43:00 1230.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1220.37 2018-10-31 13:28:00.000 BP 2018-11-01 04:34:00.000 EP Short 1215.43 3 2 2 -14.80 121.60 -14.80 F 1.20 -4.80 0.70 -4.80 100.0% -31.2% -87.0% 0.00 15:06:00 1227.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1233.35 2018-11-01 06:31:00.000 BP 2018-11-06 19:41:00.000 EP Short 1231.90 22 4 4 -32.00 89.60 -32.00 F 0.90 -42.40 0.90 -4.00 99.6% 78.5% -19.9% 0.00 134:10:00 1238.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1229.12 2018-11-06 20:03:00.000 BP 2018-11-06 22:59:06.003 EP Short 1228.38 5 4 4 -3.70 85.90 -3.70 F 3.80 0.00 0.00 0.00 99.8% -40.0% -40.0% 0.00 02:56:06 1231.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1229.70 2018-11-06 23:04:56.059 BP 2018-11-07 00:39:00.000 EP Short 1231.00 1 1 1 1.30 87.20 1.30 F 0.00 0.00 0.00 0.00 89.2% 0.0% 0.0% 0.00 01:34:03 1231.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1233.60 2018-11-07 00:39:00.000 BP 2018-11-07 03:14:56.003 EP Short 1229.60 1 1 1 -4.00 83.20 -4.00 F 0.60 -4.00 0.60 -4.00 100.0% 0.0% -87.0% 0.00 02:35:56 1233.60 1229.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1237.20 2018-11-07 06:34:26.174 BP 2018-11-07 06:35:00.000 EP Short 1237.10 1 1 1 -0.10 83.10 -0.10 F 0.00 0.00 0.00 0.00 83.9% 0.0% 0.0% 0.00 00:00:33 1237.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1212.32 2018-11-07 07:00:00.000 BP 2018-11-14 11:25:00.022 EP Short 1214.46 25 5 5 53.60 136.70 53.60 F 66.80 0.00 0.00 0.00 89.9% 8.4% 8.4% 0.00 172:25:00 1237.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1210.60 2018-11-14 12:53:00.000 BP 2018-11-14 13:36:40.036 EP Long 1207.70 1 1 1 2.90 139.60 2.90 F 3.10 -0.10 3.10 -0.10 0.0% 93.7% 90.6% 0.00 00:43:40 1210.80 1207.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1212.30 2018-11-14 13:37:55.061 BP 2018-11-14 13:38:00.000 EP Short 1211.40 1 1 1 -0.90 138.70 -0.90 F 3.80 -0.90 3.80 -0.90 92.7% 0.0% -19.1% 0.00 00:00:04 1212.30 1207.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1212.80 2018-11-14 13:38:00.000 BP 2018-11-14 14:18:00.000 EP Long 1214.35 2 2 2 -3.10 135.60 -3.10 F 5.70 -1216.10 4.90 -1212.30 0.0% 99.4% -0.1% 0.00 00:40:00 1217.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1214.82 2018-11-14 14:18:00.000 BP 2018-11-15 04:23:59.000 EP Short 1212.80 5 3 3 -10.10 125.50 -10.10 F 0.00 -1.40 0.00 0.00 51.4% -80.0% -120.0% 0.00 14:05:59 1217.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1215.26 2018-11-15 04:49:36.001 BP 2018-11-16 08:51:00.000 EP Short 1211.76 9 6 6 -31.50 94.00 -31.50 F 0.00 -18.80 0.00 0.00 77.7% 15.0% -18.3% 0.00 28:01:23 1223.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1223.80 2018-11-16 10:04:00.000 BP 2018-11-19 13:08:58.002 EP Short 1220.90 4 4 4 -11.60 82.40 -11.60 F 0.00 0.00 0.00 0.00 99.8% 0.0% 0.0% 0.00 75:04:58 1224.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1222.30 2018-11-19 20:23:57.000 BP 2018-11-28 12:09:00.000 EP Short 1222.04 28 4 4 -7.40 75.00 -7.40 F 15.40 -14.60 0.00 0.00 95.7% 72.0% 0.5% 0.00 207:45:03 1230.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1223.10 2018-11-28 12:11:00.000 BP 2018-11-28 12:18:00.000 EP Long 1226.20 1 1 1 -3.10 71.90 -3.10 F 0.20 -3.10 0.20 -3.10 0.0% 0.0% -93.9% 0.00 00:07:00 1226.40 1223.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1225.64 2018-11-28 12:18:00.000 BP 2018-11-28 20:01:58.010 EP Short 1222.96 5 4 4 -13.40 58.50 -13.40 F 0.70 0.00 0.00 0.00 20.0% -40.0% -40.0% 0.00 07:43:58 1228.50 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1230.10 2018-11-29 02:33:20.009 BP 2018-11-29 07:00:59.000 EP Short 1232.30 1 1 1 2.20 60.70 2.20 F 0.00 0.00 0.00 0.00 96.1% 0.0% 0.0% 0.00 04:27:38 1232.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1233.30 2018-11-29 07:00:59.000 BP 2018-11-29 07:30:01.131 EP Short 1230.00 1 1 1 -3.30 57.40 -3.30 F 0.10 -4.00 0.10 -4.00 100.0% 17.1% -80.5% 0.00 00:29:02 1234.00 1229.90 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1230.90 2018-11-29 07:31:00.000 BP 2018-11-29 11:29:00.000 EP Long 1233.50 1 1 1 -2.60 54.80 -2.60 F 1.40 -3.40 1.40 -3.40 0.0% 16.7% -54.2% 0.00 03:58:00 1234.90 1230.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1227.78 2018-11-29 11:29:00.000 BP 2018-12-02 18:00:00.076 EP Short 1228.88 5 4 4 5.50 60.30 5.50 F 0.40 0.00 0.00 0.00 49.3% -225.0% -225.0% 0.00 78:31:00 1234.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1231.16 2018-12-02 18:01:00.000 BP 2018-12-03 02:05:58.010 EP Short 1228.87 7 5 5 -16.00 44.30 -16.00 F 0.00 -6.70 0.00 0.00 87.3% -2003.2% -2069.9% 0.00 08:04:58 1233.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1234.20 2018-12-03 02:13:00.000 BP 2018-12-03 06:01:00.000 EP Long 1235.10 1 1 1 -0.90 43.40 -0.90 F 0.00 -1235.10 0.00 -1235.10 0.0% 99.9% -0.1% 0.00 03:48:00 1235.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1239.50 2018-12-03 07:30:58.003 BP 2018-12-03 21:35:15.007 EP Short 1234.95 4 3 3 -18.20 25.20 -18.20 F 0.50 -4.60 0.50 -4.60 56.7% -3.2% -98.2% 0.00 14:04:17 1241.00 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1246.60 2018-12-04 00:00:00.035 BP 2018-12-04 04:52:00.000 EP Short 1242.50 1 1 1 -4.10 21.10 -4.10 F 0.00 0.00 0.00 0.00 96.3% 0.0% 0.0% 0.00 04:51:59 1246.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1244.06 2018-12-04 10:50:00.000 BP 2018-12-05 20:09:01.000 EP Short 1242.23 7 5 5 -12.80 8.30 -12.80 F 0.00 -3.80 0.00 0.00 69.0% -50.2% -107.3% 0.00 33:19:01 1247.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1249.41 2018-12-06 01:30:00.000 BP 2018-12-11 04:02:59.000 EP Short 1247.48 16 4 4 -30.80 -22.50 -30.80 F 0.00 -23.80 0.00 0.00 99.8% 68.2% -13.0% 0.00 122:32:59 1255.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1251.00 2018-12-11 09:21:17.072 BP 2018-12-12 10:35:51.000 EP Short 1249.77 3 3 3 -3.70 -26.20 -3.70 F 0.00 0.00 0.00 0.00 35.7% 0.0% 0.0% 0.00 25:14:33 1255.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1242.00 2018-12-12 12:34:00.000 BP 2018-12-14 11:14:13.061 EP Short 1245.80 5 3 3 19.00 -7.20 19.00 F 12.00 0.00 0.00 0.00 99.5% 10.4% 10.4% 0.00 46:40:13 1252.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1244.05 2018-12-14 13:30:00.000 BP 2018-12-17 08:34:41.147 EP Short 1240.40 2 2 2 -7.30 -14.50 -7.30 F 0.00 0.00 0.00 0.00 99.9% 0.0% 0.0% 0.00 67:04:41 1245.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1251.20 2018-12-17 11:21:00.000 BP 2018-12-17 13:00:51.003 EP Long 1247.90 1 1 1 3.30 -11.20 3.30 F 3.40 -1.70 3.40 -1.70 0.0% 98.0% 64.7% 0.00 01:39:51 1251.30 1246.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1253.55 2018-12-17 13:02:44.022 BP 2018-12-20 04:47:00.000 EP Short 1251.81 17 5 5 -29.50 -40.70 -29.50 F 0.00 -24.80 0.00 0.00 96.8% -139.9% -228.2% 0.00 63:44:15 1260.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1261.80 2018-12-20 05:35:00.000 BP 2018-12-20 09:07:32.031 EP Short 1257.90 1 1 1 -3.90 -44.60 -3.90 F 1.20 -4.00 1.20 -4.00 100.0% 1.9% -75.0% 0.00 03:32:32 1261.90 1256.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1266.25 2018-12-20 09:32:00.000 BP 2018-12-20 14:04:00.000 EP Short 1262.32 4 3 3 -15.70 -60.30 -15.70 F 0.00 -5.10 0.00 0.00 99.8% 5.9% -19.1% 0.00 04:32:00 1269.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1265.03 2018-12-20 14:37:00.000 BP 2018-12-24 09:56:00.000 EP Short 1263.60 13 4 4 -18.60 -78.90 -18.60 F 5.90 -7.10 0.00 0.00 83.2% -128.4% -161.7% 0.00 91:19:00 1270.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1273.00 2018-12-24 13:32:31.004 BP 2018-12-24 13:33:59.000 EP Short 1273.30 1 1 1 0.30 -78.60 0.30 F 0.00 0.00 0.00 0.00 92.6% 0.0% 0.0% 0.00 00:01:27 1273.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1277.56 2018-12-25 18:42:00.000 BP 2018-12-26 12:00:00.000 EP Short 1274.64 7 3 3 -20.40 -99.00 -20.40 F 0.00 -14.80 0.00 0.00 66.6% 44.0% -13.2% 0.00 17:18:00 1281.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1273.49 2018-12-26 12:00:00.000 BP 2018-12-27 07:29:00.000 EP Short 1274.38 9 4 4 8.00 -91.00 8.00 F 17.60 -0.70 4.00 -0.70 99.6% 40.9% 37.6% 0.00 19:29:00 1280.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1278.22 2018-12-27 10:04:00.000 BP 2018-12-27 12:20:00.000 EP Short 1275.30 4 3 3 -11.70 -102.70 -11.70 F 0.00 -0.10 0.00 0.00 40.6% 25.0% 0.0% 0.00 02:16:00 1280.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1282.95 2018-12-27 14:54:00.000 BP 2018-12-31 03:13:51.025 EP Short 1279.00 4 3 3 -15.80 -118.50 -15.80 F 2.00 -3.50 2.00 -3.50 99.9% -16.4% -98.2% 0.00 84:19:51 1284.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1282.20 2018-12-31 06:13:55.007 BP 2018-12-31 08:37:33.001 EP Long 1286.20 1 1 1 -4.00 -122.50 -4.00 F 0.30 -4.00 0.30 -4.00 0.0% 0.0% -93.0% 0.00 02:23:37 1286.50 1282.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1286.63 2018-12-31 08:47:00.000 BP 2019-01-02 03:44:00.000 EP Short 1283.48 6 3 3 -18.90 -141.40 -18.90 F 0.00 -7.80 0.00 0.00 83.0% -29.4% -79.4% 0.00 42:57:00 1290.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1287.19 2019-01-02 07:00:30.219 BP 2019-01-02 18:31:00.000 EP Short 1285.86 10 4 4 -13.30 -154.70 -13.30 F 2.20 -4.70 0.00 0.00 92.8% -12.0% -52.0% 0.00 11:30:29 1289.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1290.79 2019-01-02 18:31:00.000 BP 2019-01-03 09:14:00.000 EP Short 1288.64 8 5 5 -17.20 -171.90 -17.20 F 2.30 -4.30 2.30 -3.70 99.7% 39.9% -50.5% 0.00 14:43:00 1292.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1292.00 2019-01-03 09:14:00.000 BP 2019-01-03 10:00:06.083 EP Short 1288.90 1 1 1 -3.10 -175.00 -3.10 F 0.00 -4.00 0.00 -4.00 100.0% 22.5% -77.5% 0.00 00:46:06 1292.90 1288.90 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1296.40 2019-01-03 10:01:00.000 BP 2019-01-03 15:59:33.043 EP Long 1292.60 1 1 1 3.80 -171.20 3.80 F 4.00 -3.30 4.00 -3.30 0.0% 97.3% 52.1% 0.00 05:58:33 1296.60 1289.30 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1296.00 2019-01-03 19:06:00.000 BP 2019-01-03 23:58:00.000 EP Long 1297.90 1 1 1 -1.90 -173.10 -1.90 F 2.50 -1.90 2.50 -1.90 0.0% 0.0% -43.2% 0.00 04:52:00 1300.40 1296.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1285.14 2019-01-03 23:58:00.000 BP 2019-01-04 11:42:00.000 EP Short 1289.85 8 5 5 37.70 -135.40 37.70 F 39.30 0.00 0.00 0.00 62.0% 4.9% 4.9% 0.00 11:44:00 1300.40 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1293.27 2019-01-06 19:25:59.022 BP 2019-01-07 08:20:00.000 EP Short 1288.38 4 2 2 -19.60 -155.00 -19.60 F 4.40 -15.80 4.40 -2.50 51.2% 16.1% -28.4% 0.00 12:54:00 1297.00 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1286.56 2019-01-07 08:46:00.000 BP 2019-01-08 10:12:00.000 EP Short 1288.39 9 4 4 16.50 -138.50 16.50 F 20.70 0.00 0.00 0.00 99.5% 16.8% 16.8% 0.00 25:26:00 1294.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1287.10 2019-01-08 10:12:00.000 BP 2019-01-08 12:36:04.304 EP Short 1284.40 1 1 1 -2.70 -141.20 -2.70 F 0.90 -4.00 0.90 -4.00 100.0% 26.5% -55.1% 0.00 02:24:04 1288.40 1283.50 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1285.10 2019-01-08 12:37:00.000 BP 2019-01-08 21:58:56.000 EP Long 1287.60 1 1 1 -2.50 -143.70 -2.50 F 0.50 -2.50 0.50 -2.50 0.0% 0.0% -83.3% 0.00 09:21:56 1288.10 1285.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1286.17 2019-01-08 21:58:56.000 BP 2019-01-09 09:36:00.000 EP Short 1283.67 4 4 4 -10.00 -153.70 -10.00 F 0.00 0.00 0.00 0.00 24.9% 0.0% 0.0% 0.00 11:37:04 1288.20 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1295.60 2019-01-09 10:15:00.000 BP 2019-01-09 21:49:21.016 EP Long 1292.00 1 1 1 3.60 -150.10 3.60 F 3.70 -3.20 3.70 -3.20 0.0% 98.6% 52.2% 0.00 11:34:21 1295.70 1288.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1297.90 2019-01-09 22:03:05.022 BP 2019-01-09 22:42:00.000 EP Short 1295.80 1 1 1 -2.10 -152.20 -2.10 F 0.00 0.00 0.00 0.00 97.2% 0.0% 0.0% 0.00 00:38:54 1297.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1291.75 2019-01-10 03:58:59.002 BP 2019-01-13 20:52:53.000 EP Short 1291.67 14 5 5 -1.10 -153.30 -1.10 F 11.80 0.00 0.00 0.00 99.7% 1.0% 1.0% 0.00 88:53:53 1295.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1292.10 2019-01-14 02:51:00.000 BP 2019-01-14 08:36:00.000 EP Long 1293.20 1 1 1 -1.10 -154.40 -1.10 F 3.40 -1.50 3.40 -1.50 0.0% 8.2% -22.4% 0.00 05:45:00 1296.60 1291.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1290.94 2019-01-14 08:36:00.000 BP 2019-01-16 14:28:57.001 EP Short 1290.44 14 3 3 -7.00 -161.40 -7.00 F 8.10 -0.10 0.00 0.00 86.2% 235.8% 228.6% 0.00 53:52:57 1296.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1284.87 2019-01-16 14:28:57.001 BP 2019-01-22 03:03:20.026 EP Short 1286.55 11 4 4 18.50 -142.90 18.50 F 13.50 0.00 0.00 0.00 99.4% 56.6% 56.6% 0.00 132:34:23 1295.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1281.41 2019-01-22 08:28:00.000 BP 2019-01-24 09:41:00.000 EP Short 1280.92 9 3 3 -4.40 -147.30 -4.40 F 2.50 -4.00 2.50 -3.60 99.7% 42.3% -48.6% 0.00 49:13:00 1286.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1284.15 2019-01-24 12:14:00.000 BP 2019-01-25 08:31:00.000 EP Short 1279.95 2 2 2 -8.40 -155.70 -8.40 F 1.40 -4.00 1.40 -4.00 100.0% -3.7% -77.8% 0.00 20:17:00 1284.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1298.64 2019-01-25 08:45:46.028 BP 2019-01-27 18:13:58.001 EP Short 1293.74 5 3 3 -24.50 -180.20 -24.50 F 0.00 -10.70 0.00 0.00 97.8% -102.2% -162.2% 0.00 57:28:11 1302.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1306.71 2019-01-27 18:13:58.001 BP 2019-01-30 00:00:00.000 EP Short 1303.98 13 4 4 -35.40 -215.60 -35.40 F 2.50 -17.80 0.00 0.00 99.8% -11.1% -64.9% 0.00 53:46:01 1318.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1318.90 2019-01-30 04:35:00.000 BP 2019-01-30 14:05:00.000 EP Short 1316.92 4 3 3 -7.90 -223.50 -7.90 F 3.70 0.00 0.00 0.00 99.8% -14.2% -14.2% 0.00 09:30:00 1321.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1323.20 2019-01-30 14:31:46.007 BP 2019-01-30 14:32:00.000 EP Short 1323.60 1 1 1 0.40 -223.10 0.40 F 0.00 0.00 0.00 0.00 97.0% 0.0% 0.0% 0.00 00:00:13 1323.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1325.85 2019-01-30 14:32:00.000 BP 2019-01-30 14:51:00.000 EP Long 1323.20 2 2 2 5.30 -217.80 5.30 F 8.00 -1329.20 4.00 -1323.20 9.1% 99.3% 19.6% 0.00 00:19:00 1327.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1326.63 2019-01-30 14:58:00.000 BP 2019-01-31 06:12:28.044 EP Short 1323.67 3 3 3 -8.90 -226.70 -8.90 F 0.00 0.00 0.00 0.00 39.3% 0.0% 0.0% 0.00 15:14:28 1328.00 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1319.12 2019-01-31 08:40:52.002 BP 2019-02-07 07:44:49.022 EP Short 1320.70 17 4 4 26.90 -199.80 26.90 F 25.60 -0.50 0.00 0.00 98.9% 31.9% 14.3% 0.00 167:03:57 1331.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1311.40 2019-02-07 09:08:00.000 BP 2019-02-07 10:24:48.000 EP Long 1315.40 1 1 1 -4.00 -203.80 -4.00 F 0.40 -4.00 0.40 -4.00 0.0% 0.0% -90.9% 0.00 01:16:48 1315.80 1311.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1313.25 2019-02-07 10:25:00.000 BP 2019-02-11 11:17:57.001 EP Short 1312.65 11 5 5 -6.70 -210.50 -6.70 F 0.00 -19.40 0.00 0.00 78.0% 55.3% 0.8% 0.00 96:52:57 1319.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1314.60 2019-02-11 12:58:00.000 BP 2019-02-12 01:44:04.021 EP Short 1310.70 1 1 1 -3.90 -214.40 -3.90 F 0.70 -4.00 0.70 -4.00 100.0% 2.1% -83.0% 0.00 12:46:04 1314.70 1310.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1313.62 2019-02-12 03:44:00.000 BP 2019-02-14 09:06:00.000 EP Short 1312.79 13 4 4 -10.70 -225.10 -10.70 F 2.20 -14.60 0.00 0.00 99.5% -172.4% -226.2% 0.00 53:22:00 1320.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1320.94 2019-02-14 09:06:00.000 BP 2019-02-15 13:45:05.000 EP Short 1315.50 5 2 2 -27.20 -252.30 -27.20 F 3.00 -19.30 3.00 -3.30 99.9% -17.4% -98.3% 0.00 28:39:05 1323.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1324.70 2019-02-17 20:10:59.000 BP 2019-02-18 03:09:00.000 EP Long 1327.30 1 1 1 -2.60 -254.90 -2.60 F 1.20 -2.80 1.20 -2.80 0.0% 5.0% -65.0% 0.00 06:58:01 1328.50 1324.50 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1331.78 2019-02-18 03:09:00.000 BP 2019-02-19 07:58:00.000 EP Short 1326.75 4 3 3 -20.10 -275.00 -20.10 F 0.00 -6.00 0.00 0.00 68.2% 17.9% -32.1% 0.00 28:49:00 1334.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1339.20 2019-02-19 09:59:03.031 BP 2019-02-19 11:03:00.000 EP Short 1338.10 1 1 1 -1.10 -276.10 -1.10 F 0.00 0.00 0.00 0.00 98.0% 0.0% 0.0% 0.00 01:03:56 1339.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1343.10 2019-02-19 11:03:00.000 BP 2019-02-19 12:30:16.085 EP Short 1339.10 1 1 1 -4.00 -280.10 -4.00 F 0.00 -4.00 0.00 -4.00 100.0% 0.0% -100.0% 0.00 01:27:16 1343.10 1339.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1346.30 2019-02-19 18:45:59.002 BP 2019-02-19 20:20:37.065 EP Short 1342.50 1 1 1 -3.80 -283.90 -3.80 F 0.10 -4.00 0.10 -4.00 100.0% 4.9% -92.7% 0.00 01:34:38 1346.50 1342.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1334.69 2019-02-19 22:39:00.000 BP 2019-02-22 11:39:00.000 EP Short 1336.57 14 4 4 26.30 -257.60 26.30 F 40.70 0.00 0.00 0.00 99.1% 27.8% 27.8% 0.00 61:00:00 1349.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1322.19 2019-02-22 14:41:00.000 BP 2019-03-01 10:28:00.000 EP Short 1323.48 33 6 6 42.70 -214.90 42.70 F 53.80 -12.60 0.00 0.00 93.1% 74.1% 28.6% 0.00 163:47:00 1335.60 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1298.27 2019-03-01 10:28:00.000 BP 2019-03-03 20:20:57.001 EP Short 1304.07 7 4 4 40.60 -174.30 40.60 F 27.00 0.00 0.00 0.00 85.3% 5.5% 5.5% 0.00 57:52:57 1309.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1288.36 2019-03-04 01:12:59.001 BP 2019-03-05 15:17:52.058 EP Short 1289.14 8 5 5 6.20 -168.10 6.20 F 18.00 0.00 0.00 0.00 71.8% -13.3% -13.3% 0.00 38:04:53 1298.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1291.00 2019-03-05 21:49:59.000 BP 2019-03-06 01:55:28.057 EP Short 1287.30 1 1 1 -3.70 -171.80 -3.70 F 0.60 -4.00 0.60 -4.00 100.0% 6.5% -80.4% 0.00 04:05:29 1291.30 1286.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1286.58 2019-03-06 03:21:00.000 BP 2019-03-07 07:51:33.044 EP Short 1286.25 8 3 3 -2.60 -174.40 -2.60 F 3.90 -0.60 0.00 0.00 99.8% 57.1% 19.6% 0.00 28:30:33 1289.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1292.46 2019-03-07 08:13:00.000 BP 2019-03-08 08:31:00.000 EP Short 1288.36 5 3 3 -20.50 -194.90 -20.50 F 0.00 -6.80 0.00 0.00 100.0% -44.5% -84.5% 0.00 24:18:00 1298.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1294.90 2019-03-08 08:31:00.000 BP 2019-03-08 08:34:39.051 EP Long 1298.60 2 2 2 -7.40 -202.30 -7.40 F 0.20 -10.80 0.10 -6.80 1.4% 54.7% -43.6% 0.00 00:03:39 1298.70 1291.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1297.90 2019-03-08 08:34:39.051 BP 2019-03-08 08:42:00.000 EP Short 1294.90 1 1 1 -3.00 -205.30 -3.00 F 0.00 0.00 0.00 0.00 16.7% 0.0% 0.0% 0.00 00:07:20 1297.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1294.44 2019-03-08 09:41:00.000 BP 2019-03-12 08:30:01.145 EP Short 1296.03 7 5 5 11.10 -194.20 11.10 F 11.00 0.00 0.00 0.00 84.4% 0.4% 0.4% 0.00 93:49:01 1301.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1301.00 2019-03-12 08:31:00.000 BP 2019-03-12 14:52:37.090 EP Long 1297.60 1 1 1 3.40 -190.80 3.40 F 4.00 -1.90 4.00 -1.90 0.0% 89.8% 57.6% 0.00 06:21:37 1301.60 1295.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1308.30 2019-03-12 20:47:58.007 BP 2019-03-13 05:43:01.000 EP Long 1304.40 1 1 1 3.90 -186.90 3.90 F 4.00 -1.00 4.00 -1.00 0.0% 98.0% 78.0% 0.00 08:55:02 1308.40 1303.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1310.60 2019-03-13 08:40:00.000 BP 2019-03-13 14:55:23.077 EP Short 1306.60 1 1 1 -4.00 -190.90 -4.00 F 0.50 -4.00 0.50 -4.00 100.0% 0.0% -88.9% 0.00 06:15:23 1310.60 1306.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1299.62 2019-03-13 20:57:00.000 BP 2019-03-15 02:14:20.006 EP Short 1302.67 6 3 3 18.30 -172.60 18.30 F 25.00 0.00 0.00 0.00 66.1% -14.3% -14.3% 0.00 29:17:20 1311.60 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1304.49 2019-03-15 07:56:15.003 BP 2019-03-19 08:19:05.000 EP Short 1302.98 11 3 3 -16.60 -189.20 -16.60 F 2.30 -6.10 0.00 0.00 99.6% 10.1% -44.4% 0.00 96:22:49 1309.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1306.25 2019-03-19 10:24:59.000 BP 2019-03-20 08:42:03.000 EP Short 1304.75 6 4 4 -9.00 -198.20 -9.00 F 4.00 -1.30 4.00 -1.30 99.7% -37.8% -46.0% 0.00 22:17:04 1309.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1306.80 2019-03-20 09:20:27.016 BP 2019-03-20 09:48:00.000 EP Short 1308.50 1 1 1 1.70 -196.50 1.70 F 0.00 0.00 0.00 0.00 96.2% 0.0% 0.0% 0.00 00:27:32 1308.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1305.25 2019-03-20 09:48:00.000 BP 2019-03-20 14:05:00.000 EP Short 1303.53 4 3 3 -6.90 -203.40 -6.90 F 3.90 0.00 0.00 0.00 99.7% -83.3% -83.3% 0.00 04:17:00 1312.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1312.30 2019-03-20 14:12:00.000 BP 2019-03-20 14:46:00.000 EP Long 1313.60 1 1 1 -1.30 -204.70 -1.30 F 3.60 -1.70 3.60 -1.70 0.0% 7.5% -24.5% 0.00 00:34:00 1317.20 1311.90 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1317.60 2019-03-20 14:46:00.000 BP 2019-03-20 21:40:00.000 EP Short 1314.03 3 3 3 -10.70 -215.40 -10.70 F 0.00 0.00 0.00 0.00 52.9% 0.0% 0.0% 0.00 06:54:00 1317.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1309.07 2019-03-21 06:34:00.000 BP 2019-03-21 21:44:20.010 EP Short 1312.88 6 4 4 22.90 -192.50 22.90 F 12.50 0.00 0.00 0.00 99.6% -3.3% -3.3% 0.00 15:10:20 1318.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1313.61 2019-03-22 01:17:59.000 BP 2019-03-25 06:31:00.000 EP Short 1310.19 7 3 3 -24.00 -216.50 -24.00 F 0.20 -15.70 0.20 -4.00 86.6% 24.4% -59.9% 0.00 77:13:01 1318.70 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1318.05 2019-03-25 11:36:28.001 BP 2019-03-27 06:04:43.042 EP Short 1317.79 8 4 4 -2.10 -218.60 -2.10 F 11.20 0.00 0.00 0.00 99.2% -15.0% -15.0% 0.00 42:28:15 1324.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1312.81 2019-03-27 08:26:00.000 BP 2019-03-27 18:00:00.000 EP Short 1311.26 7 6 6 -10.90 -229.50 -10.90 F 10.00 -18.40 4.00 -6.60 99.6% 21.3% -8.9% 0.00 09:34:00 1316.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1315.00 2019-03-27 18:00:00.000 BP 2019-03-27 18:00:00.000 EP Long 1315.00 1 1 1 0.00 -229.50 0.00 F 0.00 -1315.00 0.00 -1315.00 0.0% 100.0% 0.0% 0.00 00:00:00 1315.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1316.40 2019-03-27 18:00:00.000 BP 2019-03-27 20:39:57.001 EP Short 1315.00 1 1 1 -1.40 -230.90 -1.40 F 0.00 0.00 0.00 0.00 100.0% 0.0% 0.0% 0.00 02:39:57 1316.40 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1300.53 2019-03-28 04:35:56.136 BP 2019-04-01 09:08:59.008 EP Short 1301.71 17 3 3 20.00 -210.90 20.00 F 32.70 -1.40 0.70 -1.40 86.6% 249.0% 237.2% 0.00 100:33:02 1313.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1294.61 2019-04-01 10:00:27.076 BP 2019-04-02 21:51:57.003 EP Short 1293.94 11 3 3 -7.40 -218.30 -7.40 F 9.50 -1.00 0.00 0.00 90.9% 35.6% 17.4% 0.00 35:51:29 1298.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1291.52 2019-04-03 09:02:00.000 BP 2019-04-04 10:44:08.065 EP Short 1292.23 6 4 4 4.30 -214.00 4.30 F 9.20 -0.80 0.00 0.00 60.4% -57.3% -90.7% 0.00 25:42:08 1299.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1297.80 2019-04-04 13:23:00.000 BP 2019-04-04 15:28:05.239 EP Long 1294.50 1 1 1 3.30 -210.70 3.30 F 4.00 -0.40 4.00 -0.40 0.0% 84.1% 75.0% 0.00 02:05:05 1298.50 1294.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1293.83 2019-04-04 20:01:00.000 BP 2019-04-05 09:32:00.000 EP Short 1293.95 11 3 3 1.30 -209.40 1.30 F 10.60 -0.20 0.00 0.00 81.5% 122.6% 113.5% 0.00 13:31:00 1298.70 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1297.20 2019-04-05 09:32:00.000 BP 2019-04-07 18:33:59.000 EP Short 1293.15 2 2 2 -8.10 -217.50 -8.10 F 1.50 -4.00 1.50 -4.00 99.9% -0.9% -73.6% 0.00 57:01:59 1297.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1305.97 2019-04-08 02:33:13.119 BP 2019-04-09 08:21:00.000 EP Short 1302.23 3 3 3 -11.20 -228.70 -11.20 F 0.00 0.00 0.00 0.00 98.8% 0.0% 0.0% 0.00 29:47:46 1307.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1309.77 2019-04-09 21:01:57.000 BP 2019-04-10 09:39:00.000 EP Short 1307.73 3 2 2 -6.10 -234.80 -6.10 F 0.00 -2.30 0.00 0.00 51.4% 11.6% -21.7% 0.00 12:37:03 1310.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1300.43 2019-04-10 11:14:41.000 BP 2019-04-12 05:31:26.000 EP Short 1302.62 10 5 5 21.90 -212.90 21.90 F 29.30 -3.80 1.80 -3.80 99.1% 296.8% 293.4% 0.00 42:16:45 1313.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1290.47 2019-04-12 07:40:57.004 BP 2019-04-15 11:43:13.000 EP Short 1293.10 4 3 3 10.50 -202.40 10.50 F 3.90 0.00 0.00 0.00 99.7% -24.4% -24.4% 0.00 76:02:15 1298.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1277.29 2019-04-15 20:36:54.000 BP 2019-04-25 09:15:00.000 EP Short 1278.00 26 6 6 18.50 -183.90 18.50 F 41.80 -4.30 4.30 -4.30 99.0% 32.4% 29.1% 0.00 228:38:06 1290.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1284.24 2019-04-25 11:36:00.000 BP 2019-04-26 12:24:00.000 EP Short 1282.14 12 3 3 -25.20 -209.10 -25.20 F 0.00 -16.00 0.00 0.00 82.5% 48.7% -26.3% 0.00 24:48:00 1290.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1285.53 2019-04-28 20:32:49.000 BP 2019-05-01 14:33:00.000 EP Short 1284.63 19 4 4 -17.20 -226.30 -17.20 F 6.60 -12.80 0.00 0.00 84.0% -138.2% -190.9% 0.00 66:00:11 1290.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1275.26 2019-05-01 14:33:00.000 BP 2019-05-03 09:00:00.000 EP Short 1278.11 10 4 4 28.50 -197.80 28.50 F 38.20 0.00 0.00 0.00 88.5% 9.5% 9.5% 0.00 42:27:00 1285.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1281.80 2019-05-03 10:00:01.027 BP 2019-05-03 10:01:00.000 EP Short 1280.70 1 1 1 -1.10 -198.90 -1.10 F 0.00 0.00 0.00 0.00 91.3% 0.0% 0.0% 0.00 00:00:58 1281.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1279.80 2019-05-03 10:01:00.000 BP 2019-05-03 15:58:00.000 EP Long 1281.80 2 2 2 -4.00 -202.90 -4.00 F 4.20 -7.40 2.10 -5.30 0.0% 45.6% -22.1% 0.00 05:57:00 1283.90 1276.50 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1286.13 2019-05-03 15:58:00.000 BP 2019-05-05 18:22:57.001 EP Short 1281.70 3 3 3 -13.30 -216.20 -13.30 F 0.00 0.00 0.00 0.00 33.4% 0.0% 0.0% 0.00 50:24:57 1287.00 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1283.69 2019-05-05 19:14:00.000 BP 2019-05-07 11:00:00.000 EP Short 1282.60 7 3 3 -7.60 -223.80 -7.60 F 5.20 0.00 0.00 0.00 99.7% -39.5% -39.5% 0.00 39:46:00 1286.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1289.23 2019-05-08 05:29:41.107 BP 2019-05-08 05:48:00.000 EP Short 1289.23 3 2 2 -0.00 -223.80 -0.00 F 0.30 0.00 0.00 0.00 98.7% -11.1% -11.1% 0.00 00:18:18 1289.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1285.35 2019-05-08 09:09:00.000 BP 2019-05-09 10:41:00.000 EP Short 1286.72 6 4 4 8.20 -215.60 8.20 F 12.90 0.00 0.00 0.00 70.7% -5.6% -5.6% 0.00 25:32:00 1292.80 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1289.05 2019-05-09 10:41:00.000 BP 2019-05-10 11:49:00.000 EP Short 1286.70 4 3 3 -9.40 -225.00 -9.40 F 0.00 -2.10 0.00 0.00 100.0% 3.6% -21.4% 0.00 25:08:00 1290.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1288.16 2019-05-10 15:17:00.063 BP 2019-05-13 09:00:00.000 EP Short 1285.82 5 4 4 -11.70 -236.70 -11.70 F 0.60 -4.10 0.60 -4.10 43.8% -300.6% -392.9% 0.00 65:42:59 1292.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1302.20 2019-05-13 09:26:19.032 BP 2019-05-13 20:01:00.000 EP Short 1298.65 2 2 2 -7.10 -243.80 -7.10 F 0.00 0.00 0.00 0.00 99.3% 0.0% 0.0% 0.00 10:34:40 1302.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1286.62 2019-05-13 21:48:59.000 BP 2019-05-23 08:04:55.018 EP Short 1288.34 22 4 4 37.80 -206.00 37.80 F 48.30 -5.40 0.00 0.00 89.4% 19.2% -3.5% 0.00 226:15:56 1304.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1280.10 2019-05-23 08:25:00.000 BP 2019-05-23 09:04:00.000 EP Long 1281.00 1 1 1 -0.90 -206.90 -0.90 F 0.00 -1281.00 0.00 -1281.00 0.0% 99.9% -0.1% 0.00 00:39:00 1281.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1285.00 2019-05-23 09:22:00.000 BP 2019-05-23 10:57:00.000 EP Short 1279.40 2 2 2 -11.20 -218.10 -11.20 F 0.70 -4.70 0.70 -4.70 9.1% -16.7% -103.7% 0.00 01:35:00 1285.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1284.53 2019-05-23 18:00:00.000 BP 2019-05-26 21:25:00.000 EP Short 1282.53 4 4 4 -8.00 -226.10 -8.00 F 0.00 0.00 0.00 0.00 35.6% 0.0% 0.0% 0.00 75:25:00 1287.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1281.29 2019-05-27 18:17:36.001 BP 2019-05-28 20:13:00.000 EP Short 1281.37 7 4 4 0.60 -225.50 0.60 F 18.70 0.00 0.00 0.00 69.6% -26.6% -26.6% 0.00 25:55:23 1286.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1287.30 2019-05-29 03:44:53.000 BP 2019-05-29 06:16:00.000 EP Short 1289.70 1 1 1 2.40 -223.10 2.40 F 0.00 0.00 0.00 0.00 96.7% 0.0% 0.0% 0.00 02:31:07 1289.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1285.28 2019-05-29 06:16:00.000 BP 2019-05-30 10:46:00.000 EP Short 1284.38 4 3 3 -3.60 -226.70 -3.60 F 3.90 0.00 0.00 0.00 99.6% -58.3% -58.3% 0.00 28:30:00 1290.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1292.30 2019-05-30 11:02:18.061 BP 2019-05-30 11:04:57.023 EP Long 1289.10 1 1 1 3.20 -223.50 3.20 F 3.30 -1.80 3.30 -1.80 0.0% 98.0% 62.7% 0.00 00:02:38 1292.40 1287.30 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1296.25 2019-05-30 11:06:09.003 BP 2019-05-31 01:18:55.000 EP Short 1292.15 2 2 2 -8.20 -231.70 -8.20 F 0.00 0.00 0.00 0.00 96.3% 0.0% 0.0% 0.00 14:12:45 1297.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1301.80 2019-05-31 05:35:35.033 BP 2019-05-31 05:36:00.000 EP Short 1301.80 1 1 1 0.00 -231.70 0.00 F 0.00 0.00 0.00 0.00 98.1% 0.0% 0.0% 0.00 00:00:24 1301.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1311.70 2019-05-31 10:32:31.097 BP 2019-06-02 18:35:58.000 EP Short 1305.65 2 2 2 -12.10 -243.80 -12.10 F 0.00 0.00 0.00 0.00 94.6% 0.0% 0.0% 0.00 56:03:26 1313.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1320.55 2019-06-02 22:22:54.018 BP 2019-06-03 06:28:00.000 EP Short 1316.00 2 2 2 -9.10 -252.90 -9.10 F 0.00 0.00 0.00 0.00 98.1% 0.0% 0.0% 0.00 08:05:05 1322.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1330.38 2019-06-03 09:12:00.000 BP 2019-06-05 06:48:00.000 EP Short 1327.48 21 4 4 -61.00 -313.90 -61.00 F 0.00 -43.00 0.00 0.00 90.3% 75.5% -5.4% 0.00 45:36:00 1344.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1343.20 2019-06-05 07:32:31.034 BP 2019-06-05 08:22:00.000 EP Short 1340.20 5 4 4 -15.00 -328.90 -15.00 F 0.00 -2.30 0.00 0.00 40.7% -6.1% -26.1% 0.00 00:49:28 1344.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1337.58 2019-06-05 08:24:50.002 BP 2019-06-05 18:34:16.000 EP Short 1338.33 10 5 5 7.50 -321.40 7.50 F 22.90 -0.20 0.00 0.00 99.1% 887.8% 867.8% 0.00 10:09:25 1347.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1340.25 2019-06-05 20:28:00.000 BP 2019-06-07 08:31:00.000 EP Short 1337.89 14 4 4 -33.10 -354.50 -33.10 F 0.00 -25.80 0.00 0.00 84.9% 67.2% -11.4% 0.00 36:03:00 1346.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1344.30 2019-06-07 08:33:00.000 BP 2019-06-07 08:50:36.031 EP Long 1348.20 1 1 1 -3.90 -358.40 -3.90 F 1.60 -4.00 1.60 -4.00 0.0% 1.8% -69.6% 0.00 00:17:36 1349.80 1344.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1348.78 2019-06-07 08:51:00.000 BP 2019-06-07 10:31:00.000 EP Short 1345.68 5 3 3 -15.50 -373.90 -15.50 F 0.00 -1.80 0.00 0.00 63.3% -1073.3% -1113.3% 0.00 01:40:00 1351.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1331.79 2019-06-07 11:24:00.000 BP 2019-06-11 12:40:00.000 EP Short 1335.74 14 6 6 55.30 -318.60 55.30 F 64.20 0.00 0.00 0.00 78.1% 77.3% 77.3% 0.00 97:16:00 1352.70 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1340.40 2019-06-11 22:40:32.000 BP 2019-06-12 02:12:00.000 EP Short 1335.60 1 1 1 -4.80 -323.40 -4.80 F 0.00 0.00 0.00 0.00 98.3% 0.0% 0.0% 0.00 03:31:28 1340.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1338.10 2019-06-12 03:58:00.000 BP 2019-06-12 08:15:25.162 EP Long 1341.40 1 1 1 -3.30 -326.70 -3.30 F 0.90 -4.00 0.90 -4.00 0.0% 14.3% -67.3% 0.00 04:17:25 1342.30 1337.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1338.93 2019-06-12 08:15:25.347 BP 2019-06-12 22:13:52.016 EP Short 1337.73 9 4 4 -10.80 -337.50 -10.80 F 0.90 -5.30 0.00 0.00 70.3% 3.7% -40.8% 0.00 13:58:26 1342.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1342.30 2019-06-12 23:26:58.006 BP 2019-06-13 04:35:36.001 EP Short 1338.30 1 1 1 -4.00 -341.50 -4.00 F 0.70 -4.00 0.70 -4.00 100.0% 0.0% -85.1% 0.00 05:08:37 1342.30 1337.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1343.15 2019-06-13 05:22:59.000 BP 2019-06-13 11:31:33.079 EP Short 1338.80 2 2 2 -8.70 -350.20 -8.70 F 0.00 0.00 0.00 0.00 99.9% 0.0% 0.0% 0.00 06:08:34 1343.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1350.30 2019-06-13 18:25:59.000 BP 2019-06-13 22:35:39.014 EP Long 1348.10 1 1 1 2.20 -348.00 2.20 F 2.30 -2.40 2.30 -2.40 0.0% 97.9% 46.8% 0.00 04:09:40 1350.40 1345.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1349.07 2019-06-14 02:22:01.016 BP 2019-06-16 23:33:20.008 EP Short 1351.64 11 5 5 28.20 -319.80 28.20 F 16.00 -3.20 0.00 0.00 99.1% 39.1% 30.0% 0.00 69:11:18 1360.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1341.53 2019-06-17 01:15:59.000 BP 2019-06-17 09:07:00.000 EP Short 1340.83 7 4 4 -4.90 -324.70 -4.90 F 7.60 0.00 0.00 0.00 99.8% -27.1% -27.1% 0.00 07:51:01 1345.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1348.70 2019-06-17 10:22:00.000 BP 2019-06-18 07:27:00.000 EP Short 1344.92 6 3 3 -22.70 -347.40 -22.70 F 0.50 -19.50 0.50 -5.20 53.6% 38.3% -11.3% 0.00 21:05:00 1352.80 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1355.30 2019-06-18 07:27:00.000 BP 2019-06-18 09:03:00.000 EP Long 1352.40 1 1 1 2.90 -344.50 2.90 F 2.90 -1352.40 2.90 -1352.40 7.0% 100.0% 0.2% 0.00 01:36:00 1355.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1348.45 2019-06-18 09:41:00.000 BP 2019-06-18 11:06:25.107 EP Short 1350.60 6 5 5 12.90 -331.60 12.90 F 1.80 0.00 0.00 0.00 79.5% -18.5% -18.5% 0.00 01:25:25 1357.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1355.60 2019-06-18 11:24:42.047 BP 2019-06-18 11:25:00.000 EP Short 1355.40 1 1 1 -0.20 -331.80 -0.20 F 0.00 0.00 0.00 0.00 90.6% 0.0% 0.0% 0.00 00:00:17 1355.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1350.99 2019-06-18 11:31:35.013 BP 2019-06-19 14:01:00.000 EP Short 1349.40 7 4 4 -11.10 -342.90 -11.10 F 6.90 0.00 0.00 0.00 58.0% -177.2% -177.2% 0.00 26:29:24 1355.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1356.40 2019-06-19 14:01:00.000 BP 2019-06-19 14:03:58.013 EP Long 1352.50 1 1 1 3.90 -339.00 3.90 F 4.00 -0.60 4.00 -0.60 77.8% 97.8% 84.8% 0.00 00:02:58 1356.50 1351.90 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1355.13 2019-06-19 14:04:00.000 BP 2019-06-19 14:16:26.055 EP Long 1356.60 3 3 3 -4.40 -343.40 -4.40 F 10.20 -13.20 3.40 -4.60 0.0% 57.1% 0.0% 0.00 00:12:26 1360.00 1352.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1356.37 2019-06-19 14:16:26.055 BP 2019-06-19 14:40:00.000 EP Short 1353.43 7 6 6 -20.60 -364.00 -20.60 F 0.00 -11.50 0.00 0.00 32.7% 17.4% 3.1% 0.00 00:23:33 1360.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1356.67 2019-06-19 14:40:00.000 BP 2019-06-19 15:59:32.024 EP Short 1353.70 3 3 3 -8.90 -372.90 -8.90 F 0.00 0.00 0.00 0.00 99.9% 0.0% 0.0% 0.00 01:19:32 1359.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1366.10 2019-06-19 16:17:23.307 BP 2019-06-19 16:18:00.000 EP Short 1364.80 1 1 1 -1.30 -374.20 -1.30 F 0.00 0.00 0.00 0.00 91.8% 0.0% 0.0% 0.00 00:00:36 1366.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1372.14 2019-06-19 18:07:59.016 BP 2019-06-19 20:57:00.000 EP Short 1366.26 5 3 3 -29.40 -403.60 -29.40 F 0.00 -7.00 0.00 0.00 51.1% 17.1% -22.9% 0.00 02:49:00 1378.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1378.70 2019-06-19 20:57:00.000 BP 2019-06-19 21:02:42.079 EP Short 1374.80 1 1 1 -3.90 -407.50 -3.90 F 0.50 -4.00 0.50 -4.00 100.0% 2.2% -86.7% 0.00 00:05:42 1378.80 1374.30 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1384.69 2019-06-19 21:04:00.000 BP 2019-06-19 21:26:00.000 EP Short 1384.86 8 4 4 1.40 -406.10 1.40 F 9.80 -2.80 2.20 -1.10 92.1% -42.7% -56.5% 0.00 00:22:00 1397.70 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1386.40 2019-06-19 21:26:00.000 BP 2019-06-20 08:33:00.000 EP Short 1385.12 10 3 3 -12.80 -418.90 -12.80 F 1.40 -6.90 0.00 0.00 99.9% -81.5% -151.5% 0.00 11:07:00 1388.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1388.93 2019-06-20 08:33:00.000 BP 2019-06-20 12:03:22.244 EP Short 1385.80 3 3 3 -9.40 -428.30 -9.40 F 0.00 0.00 0.00 0.00 99.9% 0.0% 0.0% 0.00 03:30:22 1390.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1390.50 2019-06-20 12:11:00.000 BP 2019-06-20 12:25:00.000 EP Long 1394.30 1 1 1 -3.80 -432.10 -3.80 F 0.00 -1394.30 0.00 -1394.30 0.0% 99.7% -0.3% 0.00 00:14:00 1394.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1394.84 2019-06-20 12:25:02.000 BP 2019-06-20 20:09:58.000 EP Short 1391.22 5 3 3 -18.10 -450.20 -18.10 F 2.80 -8.10 1.50 -4.40 99.9% 39.0% -45.0% 0.00 07:44:56 1396.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1399.60 2019-06-20 20:36:00.000 BP 2019-06-20 21:44:49.069 EP Short 1395.90 1 1 1 -3.70 -453.90 -3.70 F 0.60 -4.00 0.60 -4.00 100.0% 6.5% -80.4% 0.00 01:08:49 1399.90 1395.30 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1398.94 2019-06-20 21:52:38.002 BP 2019-06-21 06:38:00.000 EP Short 1401.16 15 5 5 33.30 -420.60 33.30 F 45.30 -5.30 0.00 0.00 98.8% 87.0% 47.0% 0.00 08:45:21 1412.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1401.08 2019-06-21 06:40:00.000 BP 2019-06-21 09:46:00.000 EP Short 1399.68 6 4 4 -8.40 -429.00 -8.40 F 3.10 -1.80 0.00 0.00 99.7% -20.8% -37.4% 0.00 03:06:00 1404.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1399.30 2019-06-21 09:46:00.000 BP 2019-06-21 10:08:04.113 EP Long 1403.30 1 1 1 -4.00 -433.00 -4.00 F 0.40 -4.00 0.40 -4.00 9.8% 0.0% -90.9% 0.00 00:22:04 1403.70 1399.30 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1397.68 2019-06-21 10:08:04.113 BP 2019-06-21 11:22:20.047 EP Short 1397.10 6 5 5 -3.50 -436.50 -3.50 F 5.50 0.00 0.00 0.00 52.8% -10.9% -10.9% 0.00 01:14:15 1403.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1398.20 2019-06-21 12:00:00.000 BP 2019-06-21 12:39:32.055 EP Long 1402.10 1 1 1 -3.90 -440.40 -3.90 F 0.10 -4.00 0.10 -4.00 0.0% 2.4% -95.1% 0.00 00:39:32 1402.20 1398.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1405.70 2019-06-21 12:40:00.000 BP 2019-06-23 18:38:00.000 EP Short 1402.29 8 5 5 -27.30 -467.70 -27.30 F 0.00 -17.80 0.00 0.00 73.2% 28.3% -9.2% 0.00 53:58:00 1412.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1412.82 2019-06-23 18:38:00.000 BP 2019-06-24 16:32:00.000 EP Short 1410.68 24 4 4 -51.60 -519.30 -51.60 F 4.00 -40.20 4.00 -1.50 99.8% 50.1% -27.2% 0.00 21:54:00 1425.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1425.80 2019-06-24 16:45:00.000 BP 2019-06-24 18:46:24.177 EP Short 1421.90 1 1 1 -3.90 -523.20 -3.90 F 0.50 -4.00 0.50 -4.00 100.0% 2.2% -86.7% 0.00 02:01:24 1425.90 1421.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1431.80 2019-06-24 19:06:00.000 BP 2019-06-24 20:24:49.050 EP Long 1427.90 1 1 1 3.90 -519.30 3.90 F 4.00 -1.70 4.00 -1.70 0.0% 98.2% 68.4% 0.00 01:18:49 1431.90 1426.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1432.30 2019-06-24 20:24:52.035 BP 2019-06-24 20:25:00.000 EP Short 1431.90 1 1 1 -0.40 -519.70 -0.40 F 0.00 -0.50 0.00 -0.50 96.6% 20.0% -80.0% 0.00 00:00:07 1432.40 1431.90 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1428.50 2019-06-24 20:51:19.199 BP 2019-06-24 20:52:00.000 EP Short 1428.30 1 1 1 -0.20 -519.90 -0.20 F 0.00 0.00 0.00 0.00 0.0% 0.0% 0.0% 0.00 00:00:40 1428.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1435.18 2019-06-24 20:52:00.000 BP 2019-06-25 00:03:00.000 EP Short 1429.70 4 3 3 -21.90 -541.80 -21.90 F 0.00 -6.50 0.00 0.00 81.1% -2.3% -27.3% 0.00 03:11:00 1440.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1429.43 2019-06-25 00:36:00.000 BP 2019-06-25 02:06:33.033 EP Short 1433.33 7 4 4 27.30 -514.50 27.30 F 23.30 0.00 0.00 0.00 66.8% 3.6% 3.6% 0.00 01:30:33 1442.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1434.10 2019-06-25 02:14:00.000 BP 2019-06-25 02:55:54.045 EP Short 1430.20 1 1 1 -3.90 -518.40 -3.90 F 1.50 -4.00 1.50 -4.00 100.0% 1.8% -70.9% 0.00 00:41:54 1434.20 1428.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1436.30 2019-06-25 02:56:00.000 BP 2019-06-25 03:34:03.087 EP Long 1434.40 1 1 1 1.90 -516.50 1.90 F 2.60 -1.80 2.60 -1.80 0.0% 84.1% 43.2% 0.00 00:38:03 1437.00 1432.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1438.30 2019-06-25 04:08:39.057 BP 2019-06-25 04:09:00.000 EP Short 1438.00 1 1 1 -0.30 -516.80 -0.30 F 0.00 0.00 0.00 0.00 93.1% 0.0% 0.0% 0.00 00:00:20 1438.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1434.30 2019-06-25 04:09:00.000 BP 2019-06-25 04:31:53.030 EP Long 1438.30 2 2 2 -8.00 -524.80 -8.00 F 1.80 -9.70 0.90 -5.70 9.5% 37.7% -47.7% 0.00 00:22:53 1439.20 1432.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1429.09 2019-06-25 04:31:53.030 BP 2019-06-25 13:53:00.000 EP Short 1429.75 31 8 8 20.20 -504.60 20.20 F 37.00 -0.10 0.00 0.00 88.8% -57.7% -61.2% 0.00 09:21:06 1439.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1422.28 2019-06-25 18:02:46.000 BP 2019-06-25 19:14:59.004 EP Short 1422.97 6 4 4 4.10 -500.50 4.10 F 5.30 0.00 0.00 0.00 66.9% -1.3% -1.3% 0.00 01:12:13 1429.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1411.57 2019-06-25 19:14:59.004 BP 2019-06-25 23:54:54.311 EP Short 1417.70 7 5 5 42.90 -457.60 42.90 F 9.40 0.00 0.00 0.00 99.6% 55.3% 55.3% 0.00 04:39:55 1424.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1411.15 2019-06-25 23:54:54.408 BP 2019-06-26 08:47:00.000 EP Short 1409.66 14 5 5 -20.80 -478.40 -20.80 F 0.00 -21.80 0.00 0.00 92.6% 61.1% -3.2% 0.00 08:52:05 1414.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1412.17 2019-06-26 09:00:18.110 BP 2019-06-26 11:14:00.000 EP Short 1411.05 4 4 4 -4.50 -482.90 -4.50 F 0.00 0.00 0.00 0.00 43.6% 0.0% 0.0% 0.00 02:13:41 1415.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1417.90 2019-06-26 11:45:29.061 BP 2019-06-26 11:46:00.000 EP Short 1416.60 1 1 1 -1.30 -484.20 -1.30 F 0.00 0.00 0.00 0.00 88.0% 0.0% 0.0% 0.00 00:00:30 1417.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1408.42 2019-06-26 13:08:59.001 BP 2019-06-27 09:13:26.043 EP Short 1408.88 12 4 4 5.50 -478.70 5.50 F 15.10 -1.30 0.00 0.00 81.9% 634.8% 618.2% 0.00 20:04:27 1418.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1409.80 2019-06-27 09:14:55.073 BP 2019-06-27 10:09:00.000 EP Short 1407.90 1 1 1 -1.90 -480.60 -1.90 F 0.00 0.00 0.00 0.00 96.0% 0.0% 0.0% 0.00 00:54:04 1409.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1414.50 2019-06-27 18:02:18.002 BP 2019-06-27 19:50:00.000 EP Short 1413.60 1 1 1 -0.90 -481.50 -0.90 F 0.00 0.00 0.00 0.00 97.3% 0.0% 0.0% 0.00 01:47:41 1414.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1420.50 2019-06-27 20:18:46.000 BP 2019-06-27 21:03:00.000 EP Short 1418.40 1 1 1 -2.10 -483.60 -2.10 F 0.00 0.00 0.00 0.00 97.9% 0.0% 0.0% 0.00 00:44:14 1420.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1416.34 2019-06-27 21:40:18.033 BP 2019-06-28 03:42:33.013 EP Short 1417.60 8 5 5 10.10 -473.50 10.10 F 22.50 0.00 0.00 0.00 98.9% -2.0% -2.0% 0.00 06:02:14 1424.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1396.82 2019-06-28 04:02:10.018 BP 2019-07-01 08:34:00.000 EP Short 1398.02 27 5 5 32.50 -441.00 32.50 F 50.10 0.00 0.00 0.00 98.3% 53.3% 53.3% 0.00 76:31:49 1418.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1396.80 2019-07-01 10:00:00.000 BP 2019-07-01 10:59:00.000 EP Short 1394.82 4 3 3 -7.90 -448.90 -7.90 F 0.00 -3.20 0.00 0.00 25.0% 24.2% -0.8% 0.00 00:59:00 1399.40 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1395.30 2019-07-01 10:59:00.000 BP 2019-07-01 11:19:00.000 EP Long 1398.00 1 1 1 -2.70 -451.60 -2.70 F 0.70 -3.50 0.70 -3.50 19.7% 19.0% -64.3% 0.00 00:20:00 1398.70 1394.50 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1392.23 2019-07-01 11:19:00.000 BP 2019-07-02 00:40:52.002 EP Short 1392.64 8 5 5 3.30 -448.30 3.30 F 13.20 0.00 0.00 0.00 50.7% -40.8% -40.8% 0.00 13:21:52 1398.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1396.30 2019-07-02 02:25:00.000 BP 2019-07-02 07:57:00.000 EP Short 1394.20 3 3 3 -6.30 -454.60 -6.30 F 0.00 0.00 0.00 0.00 60.3% 0.0% 0.0% 0.00 05:32:00 1397.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1404.50 2019-07-02 08:30:00.000 BP 2019-07-02 12:05:00.000 EP Short 1400.10 5 3 3 -22.00 -476.60 -22.00 F 0.00 -13.40 0.00 0.00 69.0% 30.0% -30.0% 0.00 03:35:00 1408.50 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1412.70 2019-07-02 13:08:00.000 BP 2019-07-02 15:03:00.000 EP Short 1408.20 3 3 3 -13.50 -490.10 -13.50 F 0.00 0.00 0.00 0.00 30.2% 0.0% 0.0% 0.00 01:55:00 1412.70 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1416.40 2019-07-02 15:05:49.088 BP 2019-07-02 15:12:00.000 EP Short 1415.60 1 1 1 -0.80 -490.90 -0.80 F 0.00 0.00 0.00 0.00 72.5% 0.0% 0.0% 0.00 00:06:10 1416.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1420.00 2019-07-02 15:12:00.000 BP 2019-07-02 16:35:58.045 EP Short 1416.30 1 1 1 -3.70 -494.60 -3.70 F 1.00 -4.00 1.00 -4.00 100.0% 6.0% -74.0% 0.00 01:23:58 1420.30 1415.30 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1424.20 2019-07-02 16:37:58.003 BP 2019-07-02 18:00:00.103 EP Short 1420.80 1 1 1 -3.40 -498.00 -3.40 F 0.80 -4.00 0.80 -4.00 100.0% 12.5% -70.8% 0.00 01:22:02 1424.80 1420.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1424.63 2019-07-02 18:01:00.000 BP 2019-07-02 18:04:34.005 EP Short 1422.60 4 4 4 -8.10 -506.10 -8.10 F 0.00 -4.00 0.00 -4.00 99.9% 0.8% -32.5% 0.00 00:03:34 1426.60 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1432.56 2019-07-02 18:05:00.000 BP 2019-07-02 18:37:00.000 EP Short 1430.54 8 4 4 -16.20 -522.30 -16.20 F 0.00 -15.10 0.00 0.00 99.7% 65.2% 2.7% 0.00 00:32:00 1439.00 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1433.22 2019-07-02 18:41:00.000 BP 2019-07-02 19:53:00.000 EP Short 1430.18 4 4 4 -12.20 -534.50 -12.20 F 0.00 0.00 0.00 0.00 37.5% 0.0% 0.0% 0.00 01:12:00 1435.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1431.19 2019-07-02 20:12:03.007 BP 2019-07-03 00:17:42.000 EP Short 1431.05 11 6 6 -1.50 -536.00 -1.50 F 1.70 -13.60 1.70 -5.10 82.8% 74.3% 6.2% 0.00 04:05:38 1439.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1427.65 2019-07-03 00:17:42.000 BP 2019-07-03 01:35:00.000 EP Long 1430.50 2 2 2 -5.70 -541.70 -5.70 F 0.00 -2861.00 0.00 -1430.50 0.0% 99.9% -0.1% 0.00 01:17:18 1430.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1422.93 2019-07-03 01:35:00.000 BP 2019-07-03 10:34:00.000 EP Short 1423.45 11 4 4 5.70 -536.00 5.70 F 11.90 -3.40 0.00 0.00 90.2% 45.2% 27.0% 0.00 08:59:00 1431.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1419.44 2019-07-03 10:34:00.000 BP 2019-07-04 18:26:59.000 EP Short 1419.41 14 4 4 -0.30 -536.30 -0.30 F 8.30 -5.70 4.00 -1.90 99.7% 2.8% -44.7% 0.00 31:52:59 1423.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1424.50 2019-07-04 18:40:29.043 BP 2019-07-04 18:50:00.000 EP Short 1424.10 1 1 1 -0.40 -536.70 -0.40 F 0.00 0.00 0.00 0.00 97.9% 0.0% 0.0% 0.00 00:09:30 1424.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1416.44 2019-07-04 18:50:00.000 BP 2019-07-05 08:30:05.204 EP Short 1418.10 12 6 6 19.90 -516.80 19.90 F 19.10 -5.00 9.60 -5.00 99.4% 38.1% 24.6% 0.00 13:40:05 1426.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1406.80 2019-07-05 08:30:05.204 BP 2019-07-05 08:31:00.000 EP Long 1409.40 1 1 1 -2.60 -519.40 -2.60 F 0.00 -1409.40 0.00 -1409.40 72.7% 99.8% -0.2% 0.00 00:00:54 1409.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1398.16 2019-07-05 08:31:00.000 BP 2019-07-05 11:37:00.000 EP Short 1398.39 14 3 3 3.20 -516.20 3.20 F 19.40 0.00 0.00 0.00 99.4% 9.7% 9.7% 0.00 03:06:00 1407.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1399.24 2019-07-05 11:56:41.030 BP 2019-07-10 08:34:00.000 EP Short 1398.64 31 4 4 -18.60 -534.80 -18.60 F 14.00 -10.60 0.00 0.00 93.4% 2.8% -29.4% 0.00 116:37:18 1409.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1413.59 2019-07-10 08:53:32.009 BP 2019-07-12 13:47:00.000 EP Short 1413.15 37 6 6 -16.20 -551.00 -16.20 F 7.20 -28.80 2.00 -6.50 99.1% 57.2% -12.6% 0.00 52:53:27 1427.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1419.60 2019-07-14 18:02:25.013 BP 2019-07-14 18:04:00.000 EP Short 1418.70 1 1 1 -0.90 -551.90 -0.90 F 0.00 0.00 0.00 0.00 89.6% 0.0% 0.0% 0.00 00:01:34 1419.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1415.64 2019-07-14 19:06:24.083 BP 2019-07-15 18:11:00.000 EP Short 1415.13 11 3 3 -5.60 -557.50 -5.60 F 6.40 -3.40 0.00 0.00 85.3% -41.1% -59.3% 0.00 23:04:35 1421.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1414.48 2019-07-15 21:00:10.013 BP 2019-07-16 09:37:49.086 EP Short 1412.47 6 3 3 -12.10 -569.60 -12.10 F 0.00 -4.20 0.00 0.00 67.1% 10.8% -39.2% 0.00 12:37:39 1420.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1407.96 2019-07-16 09:57:00.000 BP 2019-07-17 09:47:00.000 EP Short 1407.68 13 3 3 -3.70 -573.30 -3.70 F 10.90 -2.90 4.00 -2.90 99.6% 27.9% 6.1% 0.00 23:50:00 1413.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1425.04 2019-07-17 10:19:55.025 BP 2019-07-18 14:20:00.000 EP Short 1422.76 17 3 3 -38.80 -612.10 -38.80 F 0.00 -29.20 0.00 0.00 99.5% 62.6% -25.6% 0.00 28:00:04 1434.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1446.02 2019-07-18 14:40:20.004 BP 2019-07-18 18:06:00.000 EP Short 1441.42 5 2 2 -23.00 -635.10 -23.00 F 0.00 -12.70 0.00 0.00 98.5% -58.2% -118.2% 0.00 03:25:39 1450.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1436.69 2019-07-18 18:21:00.000 BP 2019-07-22 01:37:59.000 EP Short 1437.82 24 4 4 27.30 -607.80 27.30 F 39.80 -1.20 0.00 0.00 90.5% 65970697666609.9% 65970697666605.5% 0.00 79:16:59 1454.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1422.61 2019-07-22 02:16:00.000 BP 2019-07-23 07:43:00.000 EP Short 1423.15 8 4 4 4.30 -603.50 4.30 F 16.90 -3.20 0.00 0.00 72.4% 108.1% 70.6% 0.00 29:27:00 1430.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1421.37 2019-07-23 10:03:31.185 BP 2019-07-23 22:52:33.025 EP Short 1423.04 7 4 4 11.70 -591.80 11.70 F 16.40 0.00 0.00 0.00 99.3% 10.3% 10.3% 0.00 12:49:01 1429.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1425.71 2019-07-24 03:27:23.024 BP 2019-07-25 05:20:14.001 EP Short 1424.47 7 3 3 -8.70 -600.50 -8.70 F 2.20 -4.60 0.00 0.00 99.2% -86.4% -115.0% 0.00 25:52:50 1430.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1430.50 2019-07-25 05:31:00.000 BP 2019-07-25 07:44:10.085 EP Long 1426.80 1 1 1 3.70 -596.80 3.70 F 4.00 -0.70 4.00 -0.70 0.0% 93.6% 78.7% 0.00 02:13:10 1430.80 1426.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1423.02 2019-07-25 07:45:00.000 BP 2019-07-30 07:40:00.000 EP Short 1421.78 32 4 4 -39.70 -636.50 -39.70 F 28.40 -32.90 3.90 -4.00 99.1% 55.7% 35.4% 0.00 119:55:00 1442.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1443.20 2019-07-30 08:33:49.047 BP 2019-07-31 09:42:00.465 EP Short 1440.67 7 3 3 -17.70 -654.20 -17.70 F 0.00 -13.10 0.00 0.00 72.8% 27.1% -30.1% 0.00 25:08:11 1445.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1434.95 2019-07-31 09:43:00.000 BP 2019-07-31 14:08:00.000 EP Short 1437.73 11 5 5 30.50 -623.70 30.50 F 29.80 0.00 0.00 0.00 99.5% 23.4% 23.4% 0.00 04:25:00 1445.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1439.70 2019-07-31 14:11:37.016 BP 2019-07-31 14:16:00.000 EP Long 1437.63 3 2 2 6.20 -617.50 6.20 F 9.00 -1442.40 5.00 -1437.30 0.0% 99.2% 0.1% 0.00 00:04:22 1442.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1429.80 2019-07-31 14:16:00.000 BP 2019-07-31 18:03:58.001 EP Short 1431.19 15 4 4 20.80 -596.70 20.80 F 24.30 0.00 0.00 0.00 94.9% 35.4% 35.4% 0.00 03:47:58 1443.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1419.14 2019-07-31 19:11:00.000 BP 2019-08-01 10:59:00.000 EP Short 1418.29 17 4 4 -14.50 -611.20 -14.50 F 10.30 -7.50 7.20 -0.30 99.5% -14.4% -17.4% 0.00 15:48:00 1425.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1425.70 2019-08-01 11:30:00.000 BP 2019-08-01 12:18:00.000 EP Long 1429.10 1 1 1 -3.40 -614.60 -3.40 F 0.70 -3.40 0.70 -3.40 0.0% 0.0% -82.9% 0.00 00:48:00 1429.80 1425.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1437.91 2019-08-01 12:18:00.000 BP 2019-08-01 13:54:00.000 EP Short 1433.37 9 5 5 -40.90 -655.50 -40.90 F 0.00 -18.80 0.00 0.00 87.0% 27.6% -16.8% 0.00 01:36:00 1449.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1454.27 2019-08-01 14:09:00.000 BP 2019-08-01 15:11:00.000 EP Short 1449.60 3 3 3 -14.00 -669.50 -14.00 F 0.00 0.00 0.00 0.00 59.6% 0.0% 0.0% 0.00 01:02:00 1455.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1456.12 2019-08-01 15:28:00.000 BP 2019-08-01 16:00:00.000 EP Short 1453.48 6 4 4 -15.80 -685.30 -15.80 F 0.00 -11.20 0.00 0.00 80.7% 24.5% -8.8% 0.00 00:32:00 1458.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1450.91 2019-08-01 16:01:00.000 BP 2019-08-02 10:09:00.000 EP Short 1451.15 25 4 4 6.00 -679.30 6.00 F 27.50 -7.10 0.00 0.00 91.2% 83.8% 71.8% 0.00 18:08:00 1460.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1457.72 2019-08-02 10:40:55.014 BP 2019-08-04 23:05:11.081 EP Short 1456.32 13 4 4 -18.10 -697.40 -18.10 F 7.10 -11.70 0.00 0.00 99.6% -6.8% -37.5% 0.00 60:24:16 1465.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1464.40 2019-08-04 23:06:00.000 BP 2019-08-04 23:55:00.000 EP Long 1466.50 1 1 1 -2.10 -699.50 -2.10 F 1.50 -2.40 1.50 -2.40 0.0% 7.7% -53.8% 0.00 00:49:00 1468.00 1464.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1474.31 2019-08-04 23:55:00.000 BP 2019-08-05 14:33:00.000 EP Short 1472.57 15 3 3 -26.10 -725.60 -26.10 F 0.40 -27.10 0.40 -5.50 93.1% 70.1% -16.4% 0.00 14:38:00 1480.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1476.80 2019-08-05 14:33:00.000 BP 2019-08-05 15:19:38.024 EP Long 1480.60 2 2 2 -7.60 -733.20 -7.60 F 2.40 -1484.90 1.50 -1480.30 0.0% 99.6% -0.3% 0.00 00:46:38 1481.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1477.43 2019-08-05 15:19:38.024 BP 2019-08-05 22:52:29.012 EP Short 1477.73 9 5 5 2.70 -730.50 2.70 F 2.40 -4.60 0.00 0.00 73.7% 48.9% 23.9% 0.00 07:32:50 1486.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1474.77 2019-08-05 23:34:58.004 BP 2019-08-06 06:59:41.021 EP Short 1473.90 7 3 3 -6.10 -736.60 -6.10 F 6.30 0.00 0.00 0.00 99.8% -43.6% -43.6% 0.00 07:24:43 1477.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1478.40 2019-08-06 07:26:00.000 BP 2019-08-06 07:27:00.000 EP Short 1478.30 1 1 1 -0.10 -736.70 -0.10 F 0.00 0.00 0.00 0.00 100.0% 0.0% 0.0% 0.00 00:01:00 1478.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1480.22 2019-08-06 07:45:00.000 BP 2019-08-06 10:34:23.053 EP Short 1476.18 5 3 3 -20.20 -756.90 -20.20 F 0.00 -13.50 0.00 0.00 50.5% 22.7% -17.3% 0.00 02:49:23 1482.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1490.72 2019-08-06 11:12:15.010 BP 2019-08-06 21:46:00.000 EP Short 1485.52 5 2 2 -26.00 -782.90 -26.00 F 0.00 -6.20 0.00 0.00 99.2% -52.8% -112.8% 0.00 10:33:44 1500.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1499.63 2019-08-06 21:53:35.051 BP 2019-08-07 02:26:53.068 EP Short 1496.48 4 3 3 -12.60 -795.50 -12.60 F 0.00 -3.20 0.00 0.00 51.3% -1.6% -26.6% 0.00 04:33:18 1502.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1498.70 2019-08-07 02:31:00.000 BP 2019-08-07 02:47:59.001 EP Long 1501.90 1 1 1 -3.20 -798.70 -3.20 F 1.40 -3.50 1.40 -3.50 0.0% 6.1% -65.3% 0.00 00:16:59 1503.30 1498.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1508.40 2019-08-07 02:47:59.001 BP 2019-08-07 09:54:00.000 EP Short 1503.91 10 4 4 -44.90 -843.60 -44.90 F 0.00 -25.70 0.00 0.00 78.5% 7.3% -62.7% 0.00 07:06:00 1520.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1515.10 2019-08-07 10:04:16.075 BP 2019-08-07 11:28:00.000 EP Short 1514.33 6 4 4 -4.60 -848.20 -4.60 F 6.40 0.00 0.00 0.00 69.7% -1096.9% -1096.9% 0.00 01:23:43 1522.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1513.85 2019-08-07 12:03:00.000 BP 2019-08-07 22:22:28.012 EP Short 1514.06 23 4 4 4.90 -843.30 4.90 F 8.20 -10.70 0.00 0.00 95.7% 1.2% -72.7% 0.00 10:19:28 1521.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1509.24 2019-08-07 23:08:00.000 BP 2019-08-08 09:51:00.000 EP Short 1509.27 8 4 4 0.30 -843.00 0.30 F 0.90 -4.00 0.90 -4.00 99.6% 401321744138246.7% 401321744138151.3% 0.00 10:43:00 1515.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1514.38 2019-08-08 10:31:00.000 BP 2019-08-09 10:20:00.000 EP Short 1513.05 24 5 5 -32.00 -875.00 -32.00 F 0.00 -39.10 0.00 0.00 91.4% 76.3% -11.2% 0.00 23:49:00 1521.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1508.93 2019-08-09 10:28:00.000 BP 2019-08-12 04:08:48.085 EP Short 1509.48 14 4 4 7.70 -867.30 7.70 F 3.60 -7.30 0.00 0.00 99.5% 85.0% 13.6% 0.00 65:40:48 1517.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1511.20 2019-08-12 04:18:00.000 BP 2019-08-12 04:50:47.030 EP Long 1507.40 1 1 1 3.80 -863.50 3.80 F 4.00 -1.30 4.00 -1.30 0.0% 96.2% 71.7% 0.00 00:32:47 1511.40 1506.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1514.90 2019-08-12 04:50:56.057 BP 2019-08-12 04:53:00.000 EP Short 1512.00 1 1 1 -2.90 -866.40 -2.90 F 0.00 0.00 0.00 0.00 98.3% 0.0% 0.0% 0.00 00:02:03 1514.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1516.10 2019-08-12 06:11:00.000 BP 2019-08-12 08:03:00.000 EP Long 1517.30 1 1 1 -1.20 -867.60 -1.20 F 2.60 -2.50 2.60 -2.50 0.0% 25.5% -23.5% 0.00 01:52:00 1519.90 1514.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1516.32 2019-08-12 08:03:00.000 BP 2019-08-12 14:29:14.005 EP Short 1514.25 6 5 5 -12.40 -880.00 -12.40 F 0.00 -2.70 0.00 0.00 84.8% -8.0% -24.7% 0.00 06:26:14 1519.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1531.96 2019-08-12 14:42:48.543 BP 2019-08-13 05:54:00.000 EP Short 1528.09 11 3 3 -42.60 -922.60 -42.60 F 0.00 -36.10 0.00 0.00 89.9% 50.4% -31.4% 0.00 15:11:11 1543.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1533.10 2019-08-13 06:39:00.000 BP 2019-08-13 08:50:00.000 EP Short 1537.23 7 4 4 28.90 -893.70 28.90 F 19.40 0.00 0.00 0.00 83.1% 27.4% 27.4% 0.00 02:11:00 1546.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1508.67 2019-08-13 09:00:11.035 BP 2019-08-13 09:59:00.000 EP Short 1513.49 14 3 3 67.50 -826.20 67.50 F 75.10 0.00 0.00 0.00 91.6% 30.2% 30.2% 0.00 00:58:48 1532.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1501.90 2019-08-13 10:00:37.032 BP 2019-08-13 10:01:00.000 EP Short 1502.10 1 1 1 0.20 -826.00 0.20 F 0.00 0.00 0.00 0.00 98.4% 0.0% 0.0% 0.00 00:00:22 1502.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1506.60 2019-08-13 10:01:40.028 BP 2019-08-13 10:02:00.000 EP Short 1505.30 1 1 1 -1.30 -827.30 -1.30 F 0.00 0.00 0.00 0.00 87.5% 0.0% 0.0% 0.00 00:00:19 1506.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1508.24 2019-08-13 10:03:00.000 BP 2019-08-13 11:00:00.000 EP Short 1505.87 11 3 3 -26.00 -853.30 -26.00 F 3.90 -10.50 0.00 0.00 91.7% -299.2% -362.8% 0.00 00:57:00 1515.40 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1512.17 2019-08-13 11:00:15.018 BP 2019-08-14 06:06:32.012 EP Short 1511.03 20 4 4 -22.90 -876.20 -22.90 F 0.00 -14.50 0.00 0.00 93.5% 59.7% -25.3% 0.00 19:06:16 1517.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1519.80 2019-08-14 06:19:00.000 BP 2019-08-14 06:54:37.138 EP Long 1519.40 1 1 1 0.40 -875.80 0.40 F 1.50 -2.70 1.50 -2.70 0.0% 73.8% 9.5% 0.00 00:35:37 1520.90 1516.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1525.60 2019-08-14 07:36:20.089 BP 2019-08-14 07:44:00.000 EP Short 1523.00 1 1 1 -2.60 -878.40 -2.60 F 0.00 0.00 0.00 0.00 94.0% 0.0% 0.0% 0.00 00:07:39 1525.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1523.07 2019-08-14 07:58:00.000 BP 2019-08-14 10:31:21.008 EP Short 1522.99 7 5 5 -0.60 -879.00 -0.60 F 0.00 -3.70 0.00 0.00 86.1% 60.6% 3.5% 0.00 02:33:21 1529.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1529.70 2019-08-14 11:02:00.000 BP 2019-08-14 11:13:49.053 EP Long 1526.70 1 1 1 3.00 -876.00 3.00 F 3.30 -0.70 3.30 -0.70 0.0% 92.5% 75.0% 0.00 00:11:49 1530.00 1526.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1532.85 2019-08-14 11:14:38.090 BP 2019-08-14 13:01:00.000 EP Short 1528.40 2 2 2 -8.90 -884.90 -8.90 F 0.00 0.00 0.00 0.00 90.3% 0.0% 0.0% 0.00 01:46:21 1534.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1528.58 2019-08-14 13:14:00.000 BP 2019-08-14 14:06:03.006 EP Short 1529.42 4 3 3 3.40 -881.50 3.40 F 3.90 0.00 0.00 0.00 99.8% -25.6% -25.6% 0.00 00:52:03 1533.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1526.52 2019-08-14 14:09:00.000 BP 2019-08-15 10:31:00.000 EP Short 1525.91 24 4 4 -14.50 -896.00 -14.50 F 9.70 -10.50 4.00 -3.00 99.5% 23.4% -26.0% 0.00 20:22:00 1534.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1528.31 2019-08-15 13:46:58.042 BP 2019-08-16 06:31:39.039 EP Short 1530.26 12 4 4 23.40 -872.60 23.40 F 8.10 -10.00 0.00 0.00 99.4% -38.2% -88.2% 0.00 16:44:40 1537.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1525.95 2019-08-16 08:12:59.001 BP 2019-08-16 10:00:01.079 EP Short 1521.45 2 2 2 -9.00 -881.60 -9.00 F 0.00 0.00 0.00 0.00 99.9% 0.0% 0.0% 0.00 01:47:02 1526.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1519.63 2019-08-16 10:13:00.000 BP 2019-08-16 11:32:35.001 EP Short 1520.25 4 3 3 2.50 -879.10 2.50 F 4.00 -1.80 4.00 -1.80 99.7% 16.2% 0.7% 0.00 01:19:35 1525.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1524.15 2019-08-16 12:22:00.000 BP 2019-08-16 13:32:58.005 EP Short 1519.60 2 2 2 -9.10 -888.20 -9.10 F 1.00 -4.00 1.00 -4.00 99.9% -11.0% -91.0% 0.00 01:10:58 1524.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1514.63 2019-08-16 14:58:00.000 BP 2019-08-19 21:17:07.024 EP Short 1516.39 21 5 5 36.90 -851.30 36.90 F 37.60 -0.50 0.00 0.00 94.9% 1618.3% 1594.5% 0.00 78:19:07 1528.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1511.45 2019-08-19 21:47:59.006 BP 2019-08-20 05:16:00.000 EP Short 1505.80 2 2 2 -11.30 -862.60 -11.30 F 2.30 -3.70 2.30 -3.70 99.9% -32.5% -94.2% 0.00 07:28:00 1513.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1513.34 2019-08-20 07:10:18.065 BP 2019-08-21 11:45:58.000 EP Short 1512.81 12 3 3 -6.40 -869.00 -6.40 F 9.00 -3.00 0.00 0.00 99.4% 17.6% -7.4% 0.00 28:35:39 1518.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1510.01 2019-08-21 11:59:00.000 BP 2019-08-22 09:01:00.000 EP Short 1510.75 10 4 4 7.40 -861.60 7.40 F 1.50 -8.80 0.00 0.00 78.0% 118.1% 58.1% 0.00 21:02:00 1517.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1512.70 2019-08-22 09:45:00.408 BP 2019-08-22 09:46:00.000 EP Short 1510.80 1 1 1 -1.90 -863.50 -1.90 F 0.00 0.00 0.00 0.00 82.6% 0.0% 0.0% 0.00 00:00:59 1512.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1510.13 2019-08-22 10:09:00.000 BP 2019-08-23 08:31:00.000 EP Short 1508.81 7 4 4 -9.20 -872.70 -9.20 F 2.50 -0.80 0.00 0.00 67.6% -121.9% -150.5% 0.00 22:22:00 1514.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1511.80 2019-08-23 08:31:00.000 BP 2019-08-23 08:52:00.000 EP Long 1514.20 1 1 1 -2.40 -875.10 -2.40 F 0.00 -1514.20 0.00 -1514.20 2.1% 99.8% -0.2% 0.00 00:21:00 1514.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1514.60 2019-08-23 09:36:58.028 BP 2019-08-23 10:01:00.000 EP Long 1515.80 1 1 1 -1.20 -876.30 -1.20 F 1.70 -4.00 1.70 -4.00 0.0% 49.1% -21.1% 0.00 00:24:01 1517.50 1511.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1522.75 2019-08-23 10:01:00.000 BP 2019-08-23 10:58:00.000 EP Short 1517.85 6 3 3 -29.40 -905.70 -29.40 F 0.00 -18.50 0.00 0.00 91.4% 20.8% -29.2% 0.00 00:57:00 1528.50 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1535.73 2019-08-23 11:02:35.024 BP 2019-08-23 11:10:00.000 EP Short 1532.03 3 2 2 -11.10 -916.80 -11.10 F 0.10 0.00 0.00 0.00 94.6% -2466.7% -2466.7% 0.00 00:07:24 1539.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1538.38 2019-08-23 11:12:16.017 BP 2019-08-23 14:37:36.000 EP Short 1534.82 5 3 3 -17.80 -934.60 -17.80 F 0.00 -6.90 0.00 0.00 62.2% 15.4% -24.6% 0.00 03:25:19 1539.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1535.80 2019-08-23 14:38:00.000 BP 2019-08-23 16:33:44.008 EP Long 1539.80 1 1 1 -4.00 -938.60 -4.00 F 0.20 -4.00 0.20 -4.00 0.0% 0.0% -95.2% 0.00 01:55:44 1540.00 1535.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1550.32 2019-08-23 16:35:59.001 BP 2019-08-26 05:59:06.029 EP Short 1549.91 30 5 5 -12.40 -951.00 -12.40 F 0.00 -49.30 0.00 0.00 97.7% 90.8% 0.8% 0.00 61:23:07 1562.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1543.10 2019-08-26 06:17:00.000 BP 2019-08-26 07:00:42.000 EP Short 1539.10 1 1 1 -4.00 -955.00 -4.00 F 0.00 -4.00 0.00 -4.00 100.0% 0.0% -100.0% 0.00 00:43:42 1543.10 1539.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1540.03 2019-08-26 07:20:00.000 BP 2019-08-26 09:45:00.000 EP Short 1538.23 4 3 3 -7.20 -962.20 -7.20 F 4.00 -2.20 4.00 -2.20 99.8% -31.7% -49.5% 0.00 02:25:00 1542.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1546.00 2019-08-26 10:12:21.000 BP 2019-08-26 10:13:00.000 EP Short 1545.80 1 1 1 -0.20 -962.40 -0.20 F 0.00 0.00 0.00 0.00 97.9% 0.0% 0.0% 0.00 00:00:39 1546.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1542.50 2019-08-26 10:45:49.154 BP 2019-08-27 10:49:00.000 EP Short 1542.46 9 4 4 -0.40 -962.80 -0.40 F 10.60 -1.20 7.40 -0.30 81.8% -20.5% -43.1% 0.00 24:03:10 1547.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1551.40 2019-08-27 11:12:00.000 BP 2019-08-27 11:29:16.020 EP Long 1549.40 1 1 1 2.00 -960.80 2.00 F 2.10 -0.80 2.10 -0.80 0.0% 96.6% 69.0% 0.00 00:17:16 1551.50 1548.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1552.90 2019-08-27 12:03:03.014 BP 2019-08-27 19:45:55.000 EP Short 1551.40 6 3 3 -9.00 -969.80 -9.00 F 0.00 -2.20 0.00 0.00 98.7% -89.2% -139.2% 0.00 07:42:51 1554.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1549.26 2019-08-27 22:04:50.043 BP 2019-08-28 07:24:00.000 EP Short 1547.90 7 4 4 -9.50 -979.30 -9.50 F 9.20 -5.10 1.20 -5.10 72.0% -25.7% -34.7% 0.00 09:19:09 1555.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1553.60 2019-08-28 07:24:00.000 BP 2019-08-28 08:17:00.000 EP Long 1554.20 1 1 1 -0.60 -979.90 -0.60 F 0.00 -1554.20 0.00 -1554.20 12.7% 100.0% -0.0% 0.00 00:53:00 1554.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1548.54 2019-08-28 08:23:00.000 BP 2019-08-28 10:41:00.000 EP Short 1549.92 5 4 4 6.90 -973.00 6.90 F 2.30 0.00 0.00 0.00 77.1% -37.4% -37.4% 0.00 02:18:00 1554.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1553.15 2019-08-28 18:00:00.000 BP 2019-08-29 02:05:02.005 EP Short 1550.55 4 3 3 -10.40 -983.40 -10.40 F 0.00 -4.90 0.00 0.00 84.8% 4.6% -20.4% 0.00 08:05:02 1554.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1545.01 2019-08-29 03:06:00.000 BP 2019-08-29 15:59:00.000 EP Short 1547.13 17 4 4 36.10 -947.30 36.10 F 35.40 -0.30 4.00 -0.30 99.4% 46.4% 45.6% 0.00 12:53:00 1557.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1536.84 2019-08-29 20:08:00.000 BP 2019-08-30 11:19:00.000 EP Short 1536.15 13 3 3 -8.90 -956.20 -8.90 F 5.70 -7.80 0.00 0.00 83.7% 46.5% -15.0% 0.00 15:11:00 1540.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1530.70 2019-08-30 11:39:59.005 BP 2019-08-30 14:59:00.000 EP Short 1533.34 5 4 4 13.20 -943.00 13.20 F 10.40 0.00 0.00 0.00 51.0% -14.6% -14.6% 0.00 03:19:00 1541.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1536.41 2019-08-30 16:45:51.012 BP 2019-09-02 11:51:16.012 EP Short 1535.21 14 4 4 -16.80 -959.80 -16.80 F 0.70 -22.30 0.60 -4.00 85.9% 39.6% -38.6% 0.00 67:05:25 1544.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1536.90 2019-09-02 12:38:59.006 BP 2019-09-02 18:02:00.000 EP Long 1539.70 1 1 1 -2.80 -962.60 -2.80 F 0.80 -2.90 0.80 -2.90 0.0% 2.7% -75.7% 0.00 05:23:00 1540.50 1536.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1536.93 2019-09-02 18:02:00.000 BP 2019-09-03 04:03:00.000 EP Short 1534.83 6 4 4 -12.60 -975.20 -12.60 F 5.50 -0.70 0.00 0.00 60.3% -167.9% -187.9% 0.00 10:01:00 1541.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1543.68 2019-09-03 04:14:59.004 BP 2019-09-03 09:15:00.000 EP Short 1540.48 4 2 2 -12.80 -988.00 -12.80 F 1.40 -5.90 1.40 -4.00 99.9% 27.5% -59.6% 0.00 05:00:00 1546.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1555.62 2019-09-03 10:00:00.159 BP 2019-09-03 16:50:00.038 EP Short 1551.66 5 3 3 -19.80 -1007.80 -19.80 F 0.00 -11.10 0.00 0.00 86.4% 41.3% -18.7% 0.00 06:49:59 1558.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1558.90 2019-09-03 18:05:59.000 BP 2019-09-03 19:54:52.000 EP Short 1554.90 1 1 1 -4.00 -1011.80 -4.00 F 0.80 -4.00 0.80 -4.00 100.0% 0.0% -83.3% 0.00 01:48:53 1558.90 1554.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1553.23 2019-09-03 20:27:00.000 BP 2019-09-05 03:00:57.042 EP Short 1553.66 16 4 4 6.90 -1004.90 6.90 F 21.70 -9.70 0.00 0.00 99.5% 17.4% -7.6% 0.00 30:33:57 1566.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1550.64 2019-09-05 03:05:45.012 BP 2019-09-05 07:42:00.000 EP Short 1552.84 5 3 3 11.00 -993.90 11.00 F 14.40 0.00 0.00 0.00 99.1% -6.5% -6.5% 0.00 04:36:14 1557.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1526.98 2019-09-05 08:17:00.000 BP 2019-09-05 10:27:00.000 EP Short 1537.43 9 4 4 94.10 -899.80 94.10 F 69.50 0.00 0.00 0.00 74.2% 65.9% 65.9% 0.00 02:10:00 1553.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1524.24 2019-09-05 10:57:00.000 BP 2019-09-06 12:55:00.000 EP Short 1522.92 33 5 5 -43.60 -943.40 -43.60 F 2.50 -46.30 2.50 -5.20 97.4% -66.8% -157.3% 0.00 25:58:00 1535.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1510.63 2019-09-06 12:56:17.025 BP 2019-09-10 09:35:00.000 EP Short 1512.69 29 4 4 59.80 -883.60 59.80 F 74.10 0.00 0.00 0.00 98.3% 9.5% 9.5% 0.00 92:38:42 1529.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1500.18 2019-09-10 10:04:00.000 BP 2019-09-11 15:17:28.051 EP Short 1499.49 15 4 4 -10.30 -893.90 -10.30 F 17.00 -1.30 0.00 0.00 85.8% -42.5% -49.1% 0.00 29:13:28 1509.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1503.11 2019-09-11 18:17:00.000 BP 2019-09-12 02:53:00.000 EP Short 1502.26 7 3 3 -6.00 -899.90 -6.00 F 4.80 0.00 0.00 0.00 99.8% -38.3% -38.3% 0.00 08:36:00 1507.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1512.30 2019-09-12 03:21:59.022 BP 2019-09-12 04:20:00.000 EP Short 1511.00 1 1 1 -1.30 -901.20 -1.30 F 0.00 0.00 0.00 0.00 97.8% 0.0% 0.0% 0.00 00:58:00 1512.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1518.83 2019-09-12 07:10:00.000 BP 2019-09-12 08:10:00.000 EP Short 1511.87 3 3 3 -20.90 -922.10 -20.90 F 0.00 0.00 0.00 0.00 57.3% 0.0% 0.0% 0.00 01:00:00 1522.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1516.19 2019-09-12 08:12:03.136 BP 2019-09-13 02:35:08.015 EP Short 1517.79 17 4 4 27.20 -894.90 27.20 F 29.60 -8.00 0.00 0.00 97.4% 91.1% 67.5% 0.00 18:23:04 1531.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1515.47 2019-09-13 03:29:00.000 BP 2019-09-13 07:57:00.000 EP Short 1510.30 3 2 2 -15.50 -910.40 -15.50 F 1.00 -8.60 1.00 -4.60 99.9% -5.5% -89.3% 0.00 04:28:00 1516.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1508.67 2019-09-13 08:15:00.000 BP 2019-09-18 11:39:00.000 EP Short 1508.17 45 4 4 -22.60 -933.00 -22.60 F 38.10 -12.40 0.00 0.00 99.3% -107.5% -154.1% 0.00 123:24:00 1519.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1518.90 2019-09-18 11:59:00.000 BP 2019-09-18 12:39:08.046 EP Short 1515.20 1 1 1 -3.70 -936.70 -3.70 F 0.00 -4.00 0.00 -4.00 100.0% 7.5% -92.5% 0.00 00:40:08 1519.20 1515.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1512.08 2019-09-18 12:51:00.000 BP 2019-09-18 14:08:00.000 EP Short 1512.20 9 5 5 1.10 -935.60 1.10 F 5.90 -0.40 0.00 0.00 99.6% 175.1% 164.0% 0.00 01:17:00 1519.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1498.31 2019-09-18 14:12:14.014 BP 2019-09-18 14:47:00.000 EP Short 1502.50 9 4 4 37.70 -897.90 37.70 F 24.00 -3.70 3.40 -3.70 77.9% 126.0% 114.4% 0.00 00:34:45 1511.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1516.84 2019-09-18 14:52:39.050 BP 2019-09-24 12:24:00.000 EP Short 1514.73 44 4 4 -92.80 -990.70 -92.80 F 3.80 -84.40 0.00 0.00 99.8% 67.0% -21.6% 0.00 141:31:20 1537.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1541.00 2019-09-24 12:40:21.099 BP 2019-09-24 12:42:00.000 EP Short 1540.50 1 1 1 -0.50 -991.20 -0.50 F 0.00 0.00 0.00 0.00 95.6% 0.0% 0.0% 0.00 00:01:38 1541.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1525.43 2019-09-24 13:18:00.000 BP 2019-09-25 20:10:37.046 EP Short 1528.03 21 4 4 54.70 -936.50 54.70 F 61.00 -1.50 0.00 0.00 90.4% 68.9% 58.9% 0.00 30:52:37 1543.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1513.80 2019-09-26 01:23:56.001 BP 2019-09-26 03:16:00.000 EP Long 1517.50 1 1 1 -3.70 -940.20 -3.70 F 0.50 -3.80 0.50 -3.80 0.0% 2.3% -86.0% 0.00 01:52:03 1518.00 1513.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1512.32 2019-09-26 03:16:00.000 BP 2019-09-26 08:40:04.011 EP Short 1512.37 6 5 5 0.30 -939.90 0.30 F 0.00 -1.60 0.00 0.00 60.2% 10.4% -39.6% 0.00 05:24:04 1518.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1515.10 2019-09-26 09:11:00.000 BP 2019-09-26 10:01:00.000 EP Long 1516.40 1 1 1 -1.30 -941.20 -1.30 F 3.10 -1.80 3.10 -1.80 0.0% 10.2% -26.5% 0.00 00:50:00 1519.50 1514.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1508.86 2019-09-26 10:01:00.000 BP 2019-09-27 08:30:00.000 EP Short 1509.23 14 5 5 5.20 -936.00 5.20 F 13.30 -10.90 0.00 0.00 92.4% 20.6% -29.4% 0.00 22:29:00 1519.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1486.37 2019-09-27 09:02:59.023 BP 2019-10-01 10:03:00.000 EP Short 1487.02 43 5 5 28.00 -908.00 28.00 F 57.50 -25.40 0.00 0.00 94.0% 129.5% 96.9% 0.00 97:00:00 1509.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1484.30 2019-10-01 10:03:00.000 BP 2019-10-01 10:23:25.019 EP Long 1480.40 1 1 1 3.90 -904.10 3.90 F 4.00 -1.70 4.00 -1.70 25.0% 98.2% 68.4% 0.00 00:20:25 1484.40 1478.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1487.80 2019-10-01 10:37:00.000 BP 2019-10-01 10:42:53.009 EP Long 1485.90 1 1 1 1.90 -902.20 1.90 F 2.00 -0.60 2.00 -0.60 0.0% 96.2% 73.1% 0.00 00:05:53 1487.90 1485.30 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1492.15 2019-10-01 10:59:30.034 BP 2019-10-01 12:16:00.000 EP Short 1489.00 2 2 2 -6.30 -908.50 -6.30 F 0.00 0.00 0.00 0.00 97.8% 0.0% 0.0% 0.00 01:16:29 1492.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1488.46 2019-10-01 12:41:00.000 BP 2019-10-02 07:16:00.000 EP Short 1486.50 7 4 4 -13.70 -922.20 -13.70 F 0.70 -1.70 0.00 0.00 67.0% -1926.2% -1969.0% 0.00 18:35:00 1493.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1495.10 2019-10-02 08:15:04.095 BP 2019-10-02 08:16:00.000 EP Short 1495.00 2 2 2 -0.20 -922.40 -0.20 F 0.00 0.00 0.00 0.00 96.3% 0.0% 0.0% 0.00 00:00:55 1497.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1499.90 2019-10-02 08:20:00.000 BP 2019-10-02 11:11:00.000 EP Short 1497.53 11 4 4 -26.10 -948.50 -26.10 F 0.00 -23.90 0.00 0.00 73.4% 62.5% -1.1% 0.00 02:51:00 1505.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1509.65 2019-10-02 11:33:43.060 BP 2019-10-02 13:32:59.011 EP Short 1507.40 2 2 2 -4.50 -953.00 -4.50 F 0.00 0.00 0.00 0.00 98.9% 0.0% 0.0% 0.00 01:59:15 1509.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1508.09 2019-10-02 14:19:00.000 BP 2019-10-03 07:50:10.142 EP Short 1505.90 8 3 3 -17.50 -970.50 -17.50 F 0.60 -11.50 0.00 0.00 71.2% 3.2% -46.8% 0.00 17:31:10 1511.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1506.80 2019-10-03 07:51:00.000 BP 2019-10-03 08:13:21.011 EP Long 1510.60 1 1 1 -3.80 -974.30 -3.80 F 0.30 -3.80 0.30 -3.80 0.0% 0.0% -92.7% 0.00 00:22:21 1510.90 1506.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1511.25 2019-10-03 08:13:21.032 BP 2019-10-03 10:01:00.000 EP Short 1506.15 4 4 4 -20.40 -994.70 -20.40 F 1.30 -12.00 1.30 -12.00 53.9% 3.8% -18.8% 0.00 01:47:38 1517.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1518.50 2019-10-03 10:01:00.000 BP 2019-10-03 10:02:00.000 EP Short 1515.20 1 1 1 -3.30 -998.00 -3.30 F 0.00 0.00 0.00 0.00 100.0% 0.0% 0.0% 0.00 00:01:00 1518.50 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1518.53 2019-10-03 10:04:13.054 BP 2019-10-03 10:48:00.000 EP Short 1519.53 6 3 3 6.00 -992.00 6.00 F 10.80 0.00 0.00 0.00 95.4% -11.9% -11.9% 0.00 00:43:46 1523.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1511.76 2019-10-03 11:02:00.000 BP 2019-10-04 10:30:00.000 EP Short 1511.43 22 4 4 -7.30 -999.30 -7.30 F 12.20 -2.00 0.00 0.00 90.1% 6.0% -7.6% 0.00 23:28:00 1523.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1510.32 2019-10-04 11:33:00.000 BP 2019-10-07 09:47:09.021 EP Short 1509.37 15 5 5 -14.30 -1013.60 -14.30 F 0.00 -27.60 0.00 0.00 93.1% 64.5% -15.5% 0.00 70:14:09 1518.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1499.44 2019-10-07 10:37:07.015 BP 2019-10-08 04:53:00.000 EP Short 1499.08 11 4 4 -3.90 -1017.50 -3.90 F 22.10 0.00 0.00 0.00 98.7% -8.0% -8.0% 0.00 18:15:52 1508.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1510.59 2019-10-08 05:56:23.009 BP 2019-10-08 19:42:55.017 EP Short 1508.79 14 5 5 -25.20 -1042.70 -25.20 F 0.00 -16.00 0.00 0.00 99.4% 71.1% -14.6% 0.00 13:46:32 1514.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1514.85 2019-10-08 20:20:00.000 BP 2019-10-09 03:20:36.038 EP Short 1511.00 2 2 2 -7.70 -1050.40 -7.70 F 0.00 0.00 0.00 0.00 99.9% 0.0% 0.0% 0.00 07:00:36 1515.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1512.37 2019-10-09 03:36:00.000 BP 2019-10-09 18:22:41.013 EP Short 1511.88 12 4 4 -5.90 -1056.30 -5.90 F 10.40 -2.00 4.00 -0.40 99.8% 13.1% -13.4% 0.00 14:46:41 1518.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1516.70 2019-10-09 18:23:00.000 BP 2019-10-09 20:00:00.000 EP Long 1519.70 2 2 2 -6.00 -1062.30 -6.00 F 5.20 -13.40 2.60 -9.60 0.1% 55.0% -20.4% 0.00 01:37:00 1522.30 1510.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1510.02 2019-10-09 20:00:00.000 BP 2019-10-10 13:06:00.000 EP Short 1510.65 22 5 5 13.90 -1048.40 13.90 F 21.70 -9.50 0.00 0.00 85.6% 77.8% 20.6% 0.00 17:06:00 1522.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1490.25 2019-10-10 14:36:57.005 BP 2019-10-11 12:33:00.000 EP Short 1493.03 18 4 4 50.10 -998.30 50.10 F 67.50 -9.50 0.00 0.00 87.6% 123.1% 95.3% 0.00 21:56:02 1508.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1490.38 2019-10-11 13:24:00.000 BP 2019-10-13 18:00:00.000 EP Short 1487.92 5 3 3 -12.30 -1010.60 -12.30 F 2.10 -3.00 0.00 0.00 64.6% -61.1% -81.1% 0.00 52:36:00 1493.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1492.83 2019-10-13 18:12:00.000 BP 2019-10-14 03:08:59.021 EP Short 1489.40 4 4 4 -13.70 -1024.30 -13.70 F 0.00 0.00 0.00 0.00 99.9% 0.0% 0.0% 0.00 08:56:59 1493.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1492.80 2019-10-14 05:20:03.019 BP 2019-10-15 20:36:54.020 EP Short 1494.92 13 4 4 27.50 -996.80 27.50 F 8.60 -7.00 0.00 0.00 99.3% 86.5% 48.0% 0.00 39:16:51 1503.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1487.97 2019-10-16 02:03:59.000 BP 2019-10-16 03:46:28.051 EP Short 1484.60 3 3 3 -10.10 -1006.90 -10.10 F 0.00 0.00 0.00 0.00 99.9% 0.0% 0.0% 0.00 01:42:29 1489.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1486.33 2019-10-16 05:02:00.000 BP 2019-10-16 08:53:00.000 EP Short 1485.26 8 3 3 -8.50 -1015.40 -8.50 F 10.50 -0.50 4.00 -0.50 99.7% -11.1% -13.9% 0.00 03:51:00 1493.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1492.87 2019-10-16 09:30:00.000 BP 2019-10-16 20:45:00.000 EP Short 1490.07 6 4 4 -16.80 -1032.20 -16.80 F 0.20 -5.60 0.00 0.00 62.4% -675.7% -695.7% 0.00 11:15:00 1496.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1493.87 2019-10-16 21:05:55.024 BP 2019-10-18 08:35:25.003 EP Short 1492.61 11 4 4 -13.90 -1046.10 -13.90 F 0.50 -16.00 0.00 0.00 82.1% -169.1% -232.7% 0.00 35:29:29 1501.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1491.95 2019-10-18 09:17:00.000 BP 2019-10-22 19:36:14.000 EP Short 1491.58 13 3 3 -4.80 -1050.90 -4.80 F 6.00 -8.90 0.50 -4.00 99.6% 59.2% -8.3% 0.00 106:19:14 1497.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1491.30 2019-10-22 20:05:35.026 BP 2019-10-23 02:06:00.000 EP Long 1492.70 1 1 1 -1.40 -1052.30 -1.40 F 0.00 -1492.70 0.00 -1492.70 15.4% 99.9% -0.1% 0.00 06:00:24 1492.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1495.00 2019-10-23 03:38:10.086 BP 2019-10-23 06:03:00.000 EP Long 1495.30 1 1 1 -0.30 -1052.60 -0.30 F 0.00 -1495.30 0.00 -1495.30 0.0% 100.0% -0.0% 0.00 02:24:49 1495.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1498.95 2019-10-23 06:42:00.000 BP 2019-10-23 09:55:00.000 EP Short 1493.00 2 2 2 -11.90 -1064.50 -11.90 F 0.00 -6.00 0.00 -6.00 0.0% 0.8% -99.2% 0.00 03:13:00 1499.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1497.85 2019-10-23 12:54:41.002 BP 2019-10-24 09:34:00.000 EP Short 1494.63 4 3 3 -12.90 -1077.40 -12.90 F 0.00 -1.80 0.00 0.00 49.8% -48.6% -73.6% 0.00 20:39:18 1500.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1503.83 2019-10-24 09:46:00.000 BP 2019-10-29 11:59:09.340 EP Short 1504.57 24 3 3 17.90 -1059.50 17.90 F 26.50 -34.00 1.20 -4.00 99.2% 72.5% -4.7% 0.00 122:13:09 1519.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1492.72 2019-10-29 12:17:00.000 BP 2019-10-30 15:03:00.000 EP Short 1491.72 9 3 3 -9.00 -1068.50 -9.00 F 2.40 -10.90 2.40 -3.70 99.7% -275.6% -366.9% 0.00 26:46:00 1497.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1496.10 2019-10-30 15:10:20.003 BP 2019-10-30 15:11:00.000 EP Short 1495.80 1 1 1 -0.30 -1068.80 -0.30 F 4.80 -1.60 4.80 -1.60 98.0% 20.3% -4.7% 0.00 00:00:39 1497.40 1491.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1497.70 2019-10-30 15:14:00.000 BP 2019-10-30 15:25:23.010 EP Short 1493.70 1 1 1 -4.00 -1072.80 -4.00 F 0.50 -4.00 0.50 -4.00 100.0% 0.0% -88.9% 0.00 00:11:23 1497.70 1493.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1509.76 2019-10-30 16:27:00.000 BP 2019-11-01 09:29:29.007 EP Short 1506.19 11 3 3 -39.30 -1112.10 -39.30 F 0.50 -40.40 0.50 -4.00 99.8% 46.3% -51.7% 0.00 41:02:29 1517.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1516.30 2019-11-01 09:41:00.000 BP 2019-11-01 10:00:07.100 EP Long 1512.40 1 1 1 3.90 -1108.20 3.90 F 4.00 -0.40 4.00 -0.40 0.0% 97.7% 88.6% 0.00 00:19:07 1516.40 1512.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1516.60 2019-11-01 10:01:15.061 BP 2019-11-01 10:02:00.000 EP Short 1518.30 1 1 1 1.70 -1106.50 1.70 F 0.00 0.00 0.00 0.00 86.7% 0.0% 0.0% 0.00 00:00:44 1518.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1502.09 2019-11-01 10:04:00.000 BP 2019-11-06 08:48:02.013 EP Short 1502.59 29 5 5 14.70 -1091.80 14.70 F 34.10 -16.30 0.00 0.00 91.9% 88.9% 30.3% 0.00 119:44:02 1517.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1492.30 2019-11-06 09:17:00.000 BP 2019-11-06 11:48:29.014 EP Short 1488.30 1 1 1 -4.00 -1095.80 -4.00 F 1.10 -4.00 1.10 -4.00 100.0% 0.0% -78.4% 0.00 02:31:29 1492.30 1487.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1492.90 2019-11-06 11:53:00.000 BP 2019-11-06 12:07:00.000 EP Long 1495.00 1 1 1 -2.10 -1097.90 -2.10 F 0.00 -1495.00 0.00 -1495.00 0.0% 99.9% -0.1% 0.00 00:14:00 1495.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1467.53 2019-11-06 12:41:00.000 BP 2019-11-11 13:02:08.216 EP Short 1469.81 38 5 5 86.60 -1011.30 86.60 F 82.20 0.00 0.00 0.00 95.8% 12.6% 12.6% 0.00 120:21:08 1494.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1454.20 2019-11-11 19:05:00.000 BP 2019-11-12 14:56:00.000 EP Short 1453.79 10 3 3 -4.10 -1015.40 -4.10 F 13.40 -0.80 4.00 -0.80 99.7% 10.5% 7.1% 0.00 19:51:00 1460.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1461.85 2019-11-12 16:52:58.001 BP 2019-11-13 04:14:04.000 EP Short 1458.72 6 3 3 -18.80 -1034.20 -18.80 F 0.00 -13.40 0.00 0.00 59.9% 19.9% -30.1% 0.00 11:21:05 1464.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1467.30 2019-11-13 04:40:00.000 BP 2019-11-13 07:38:09.065 EP Long 1465.90 1 1 1 1.40 -1032.80 1.40 F 1.50 -1.90 1.50 -1.90 0.0% 97.1% 41.2% 0.00 02:58:09 1467.40 1464.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1466.89 2019-11-13 08:31:00.000 BP 2019-11-18 11:11:00.000 EP Short 1465.03 23 4 4 -42.80 -1075.60 -42.80 F 0.00 -39.60 0.00 0.00 91.9% 71.0% -11.6% 0.00 122:40:00 1475.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1471.80 2019-11-18 11:17:00.000 BP 2019-11-18 20:38:00.000 EP Long 1474.00 1 1 1 -2.20 -1077.80 -2.20 F 1.80 -3.30 1.80 -3.30 0.0% 21.6% -43.1% 0.00 09:21:00 1475.80 1470.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1470.96 2019-11-18 20:38:00.000 BP 2019-11-19 10:07:00.000 EP Short 1469.93 7 5 5 -7.20 -1085.00 -7.20 F 0.00 -3.00 0.00 0.00 86.6% 13.3% -29.5% 0.00 13:29:00 1475.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1475.60 2019-11-19 11:40:00.000 BP 2019-11-20 02:43:00.000 EP Short 1472.84 5 3 3 -13.80 -1098.80 -13.80 F 0.00 -4.40 0.00 0.00 86.2% -9.0% -69.0% 0.00 15:03:00 1477.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1463.63 2019-11-20 06:57:00.000 BP 2019-11-26 11:36:00.000 EP Short 1464.40 35 5 5 26.90 -1071.90 26.90 F 42.80 -1.20 0.00 0.00 93.2% 34.8% 26.2% 0.00 148:39:00 1479.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1465.14 2019-11-26 11:46:58.019 BP 2019-12-02 10:01:00.000 EP Short 1463.09 17 4 4 -34.80 -1106.70 -34.80 F 0.40 -34.80 0.40 -4.30 87.2% 58.9% -39.6% 0.00 142:14:01 1472.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1472.55 2019-12-02 10:43:00.000 BP 2019-12-03 05:17:00.000 EP Short 1468.05 4 3 3 -18.00 -1124.70 -18.00 F 0.00 -6.40 0.00 0.00 40.6% 14.5% -10.5% 0.00 18:34:00 1475.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1484.98 2019-12-03 08:27:17.031 BP 2019-12-04 02:01:31.086 EP Short 1481.55 6 3 3 -20.60 -1145.30 -20.60 F 0.00 -9.30 0.00 0.00 98.6% 24.8% -25.2% 0.00 17:34:14 1488.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1483.40 2019-12-04 04:07:00.000 BP 2019-12-04 08:20:00.000 EP Short 1483.48 4 3 3 0.30 -1145.00 0.30 F 3.90 0.00 0.00 0.00 99.6% -42.3% -42.3% 0.00 04:13:00 1489.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1481.74 2019-12-04 08:27:29.007 BP 2019-12-05 11:36:30.000 EP Short 1481.52 5 3 3 -1.10 -1146.10 -1.10 F 7.40 0.00 0.00 0.00 61.0% -27.0% -27.0% 0.00 27:09:00 1487.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1473.41 2019-12-05 13:30:58.004 BP 2019-12-09 08:45:00.035 EP Short 1476.66 8 3 3 26.00 -1120.10 26.00 F 23.20 0.00 0.00 0.00 99.5% 58.5% 58.5% 0.00 91:14:02 1483.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1465.90 2019-12-09 08:47:00.000 BP 2019-12-09 09:44:00.000 EP Long 1469.60 1 1 1 -3.70 -1123.80 -3.70 F 0.10 -3.90 0.10 -3.90 0.0% 5.0% -92.5% 0.00 00:57:00 1469.70 1465.70 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1469.53 2019-12-09 09:44:00.000 BP 2019-12-10 09:12:00.000 EP Short 1466.85 6 3 3 -16.10 -1139.90 -16.10 F 0.50 -9.30 0.50 -3.80 60.9% -56.6% -150.8% 0.00 23:28:00 1473.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1470.35 2019-12-10 09:44:00.000 BP 2019-12-11 08:41:00.000 EP Short 1468.85 4 3 3 -6.00 -1145.90 -6.00 F 3.80 0.00 0.00 0.00 99.8% -33.6% -33.6% 0.00 22:57:00 1472.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1478.05 2019-12-11 11:07:43.023 BP 2019-12-11 14:15:29.006 EP Short 1475.30 2 2 2 -5.50 -1151.40 -5.50 F 0.00 0.00 0.00 0.00 99.0% 0.0% 0.0% 0.00 03:07:45 1478.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1479.80 2019-12-11 14:39:00.000 BP 2019-12-11 14:48:35.010 EP Short 1475.80 1 1 1 -4.00 -1155.40 -4.00 F 1.30 -4.00 1.30 -4.00 100.0% 0.0% -75.5% 0.00 00:09:35 1479.80 1474.50 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1478.54 2019-12-11 15:25:00.000 BP 2019-12-12 12:24:00.000 EP Short 1480.14 11 3 3 17.60 -1137.80 17.60 F 24.50 -17.20 0.00 0.00 99.5% 65.7% 20.2% 0.00 20:59:00 1491.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1475.01 2019-12-12 14:06:55.075 BP 2019-12-16 10:13:00.000 EP Short 1473.12 20 3 3 -38.00 -1175.80 -38.00 F 0.00 -29.00 0.00 0.00 95.5% 43.7% -41.3% 0.00 92:06:04 1484.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1483.35 2019-12-16 10:33:52.019 BP 2019-12-17 05:57:00.000 EP Short 1481.08 4 3 3 -9.10 -1184.90 -9.10 F 0.00 -3.60 0.00 0.00 51.1% 25.7% 0.7% 0.00 19:23:07 1484.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1480.33 2019-12-17 08:46:07.011 BP 2019-12-18 10:31:00.000 EP Short 1478.82 6 3 3 -9.10 -1194.00 -9.10 F 0.90 -1.70 0.00 0.00 67.1% -126.3% -159.6% 0.00 25:44:52 1484.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1485.09 2019-12-18 11:32:59.004 BP 2019-12-23 20:46:33.003 EP Short 1481.36 7 3 3 -26.10 -1220.10 -26.10 F 0.00 -12.30 0.00 0.00 67.9% 32.3% -24.8% 0.00 129:13:33 1490.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1494.70 2019-12-23 20:47:00.000 BP 2019-12-24 01:04:36.021 EP Long 1490.80 1 1 1 3.90 -1216.20 3.90 F 4.00 -0.40 4.00 -0.40 0.0% 97.7% 88.6% 0.00 04:17:36 1494.80 1490.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1504.90 2019-12-24 06:07:00.000 BP 2019-12-26 07:15:59.009 EP Short 1497.83 3 2 2 -21.20 -1237.40 -21.20 F 1.20 -4.00 1.20 -4.00 100.0% -66.7% -151.3% 0.00 49:08:59 1510.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1514.40 2019-12-26 09:57:59.000 BP 2019-12-26 09:58:00.000 EP Short 1514.30 1 1 1 -0.10 -1237.50 -0.10 F 0.00 0.00 0.00 0.00 98.1% 0.0% 0.0% 0.00 00:00:01 1514.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1517.19 2019-12-26 11:23:00.000 BP 2019-12-27 11:25:48.035 EP Short 1514.27 7 3 3 -20.40 -1257.90 -20.40 F 0.00 -14.60 0.00 0.00 84.6% 64.2% 7.0% 0.00 24:02:48 1518.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1518.90 2019-12-27 14:23:00.000 BP 2019-12-30 20:01:00.000 EP Short 1515.50 4 3 3 -13.60 -1271.50 -13.60 F 0.00 -1.30 0.00 0.00 99.9% -138.5% -188.5% 0.00 77:38:00 1520.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1528.10 2019-12-30 20:50:40.003 BP 2019-12-31 02:12:00.000 EP Short 1524.80 1 1 1 -3.30 -1274.80 -3.30 F 0.00 0.00 0.00 0.00 98.0% 0.0% 0.0% 0.00 05:21:19 1528.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1524.69 2019-12-31 06:42:59.017 BP 2020-01-02 09:38:00.000 EP Short 1524.23 7 4 4 -3.20 -1278.00 -3.20 F 6.80 0.00 0.00 0.00 68.2% -33.8% -33.8% 0.00 50:55:00 1533.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1564.94 2020-01-02 09:57:29.011 BP 2020-01-05 20:10:46.009 EP Short 1558.67 14 3 3 -87.70 -1365.70 -87.70 F 0.00 -102.00 0.00 0.00 86.7% 20.4% -58.2% 0.00 82:13:16 1588.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1569.94 2020-01-05 21:05:00.000 BP 2020-01-07 01:34:00.000 EP Short 1571.41 10 3 3 14.70 -1351.00 14.70 F 27.60 -1.20 0.00 0.00 92.6% 592.3% 562.3% 0.00 28:29:00 1581.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1578.51 2020-01-07 01:53:36.059 BP 2020-01-09 06:52:27.015 EP Short 1579.30 43 4 4 34.20 -1316.80 34.20 F 29.30 -75.60 0.00 0.00 94.1% 101.2% 33.8% 0.00 52:58:50 1613.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1556.40 2020-01-09 07:51:10.009 BP 2020-01-09 07:54:00.000 EP Short 1555.00 1 1 1 -1.40 -1318.20 -1.40 F 0.00 0.00 0.00 0.00 98.7% 0.0% 0.0% 0.00 00:02:49 1556.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1565.50 2020-01-09 08:12:00.000 BP 2020-01-31 02:41:45.000 EP Short 1563.95 77 4 4 -119.70 -1437.90 -119.70 F 17.10 -132.40 4.30 -4.50 97.0% 68.4% -14.2% 0.00 522:29:45 1590.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1587.00 2020-01-31 09:32:41.027 BP 2020-01-31 09:33:00.000 EP Short 1587.10 1 1 1 0.10 -1437.80 0.10 F 0.00 0.00 0.00 0.00 98.7% 0.0% 0.0% 0.00 00:00:18 1587.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1573.39 2020-01-31 11:44:00.000 BP 2020-02-13 00:00:00.000 EP Short 1574.08 43 4 4 29.60 -1408.20 29.60 F 85.80 -15.20 0.00 0.00 97.4% 17.6% 3.6% 0.00 300:16:00 1598.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1645.18 2020-02-13 05:51:58.005 BP 2020-02-24 21:13:00.000 EP Short 1642.35 61 4 4 -172.60 -1580.80 -172.60 F 0.00 -231.90 0.00 0.00 98.3% 86.2% -8.8% 0.00 279:21:01 1691.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1650.97 2020-02-24 21:42:00.000 BP 2020-02-25 10:25:00.000 EP Short 1650.20 15 4 4 -11.60 -1592.40 -11.60 F 39.80 0.00 0.00 0.00 85.7% -9.7% -9.7% 0.00 12:43:00 1660.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1645.95 2020-02-25 10:44:00.000 BP 2020-02-25 20:03:00.000 EP Short 1646.34 15 3 3 5.90 -1586.50 5.90 F 27.40 -8.00 1.20 -4.40 85.0% 47.1% 11.4% 0.00 09:19:00 1660.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1639.55 2020-02-25 20:36:00.000 BP 2020-02-26 11:12:00.000 EP Short 1642.28 10 4 4 27.30 -1559.20 27.30 F 48.60 -4.00 5.60 -4.00 77.5% 1688.5% 1656.0% 0.00 14:36:00 1653.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1647.87 2020-02-26 11:21:00.000 BP 2020-02-27 08:10:59.007 EP Short 1645.47 14 4 4 -33.60 -1592.80 -33.60 F 0.30 -23.40 0.30 -4.20 84.5% 59.2% -39.4% 0.00 20:49:59 1655.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1646.29 2020-02-27 08:30:26.028 BP 2020-02-28 01:25:22.001 EP Short 1646.61 24 4 4 7.60 -1585.20 7.60 F 14.60 -20.70 0.00 0.00 91.9% 80.5% 13.8% 0.00 16:54:55 1662.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1596.56 2020-02-28 01:45:00.000 BP 2020-03-01 19:26:00.000 EP Short 1598.64 56 4 4 116.10 -1469.10 116.10 F 147.80 0.00 0.00 0.00 95.5% 10.1% 10.1% 0.00 65:41:00 1642.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1601.56 2020-03-01 19:52:26.039 BP 2020-03-02 04:16:00.000 EP Short 1599.03 12 3 3 -30.30 -1499.40 -30.30 F 0.00 -17.50 0.00 0.00 99.1% 65.0% -18.4% 0.00 08:23:33 1608.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1596.92 2020-03-02 06:33:00.000 BP 2020-03-02 20:01:00.000 EP Short 1598.14 16 4 4 19.50 -1479.90 19.50 F 28.00 0.00 0.00 0.00 93.8% -1.3% -1.3% 0.00 13:28:00 1612.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1619.68 2020-03-02 20:08:47.007 BP 2020-03-03 10:38:00.000 EP Short 1613.00 11 3 3 -73.50 -1553.40 -73.50 F 0.00 -56.00 0.00 0.00 91.6% -68.3% -141.0% 0.00 14:29:12 1635.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1639.42 2020-03-03 10:38:34.070 BP 2020-03-03 18:00:00.000 EP Short 1637.91 18 4 4 -27.30 -1580.70 -27.30 F 1.90 -25.10 0.00 0.00 96.9% -57.2% -123.9% 0.00 07:21:25 1650.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1642.81 2020-03-03 18:10:32.001 BP 2020-03-04 05:29:25.002 EP Short 1643.43 9 4 4 5.60 -1575.10 5.60 F 14.10 -2.50 0.00 0.00 98.4% 120.3% 64.8% 0.00 11:18:53 1650.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1648.65 2020-03-04 05:44:00.000 BP 2020-03-04 07:21:00.000 EP Short 1641.90 2 2 2 -13.50 -1588.60 -13.50 F 0.00 0.00 0.00 0.00 0.0% 0.0% 0.0% 0.00 01:37:00 1649.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1641.55 2020-03-04 07:40:00.000 BP 2020-03-05 05:13:59.000 EP Short 1640.75 12 4 4 -9.60 -1598.20 -9.60 F 15.90 -3.70 9.10 -3.70 84.0% -8.2% -15.4% 0.00 21:33:59 1650.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1669.70 2020-03-05 07:16:11.197 BP 2020-03-06 03:31:35.011 EP Short 1666.27 13 3 3 -44.60 -1642.80 -44.60 F 0.00 -41.20 0.00 0.00 98.7% 68.1% -16.5% 0.00 20:15:23 1681.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1684.10 2020-03-06 04:37:04.014 BP 2020-03-06 04:41:00.000 EP Short 1681.90 1 1 1 -2.20 -1645.00 -2.20 F 0.00 0.00 0.00 0.00 95.5% 0.0% 0.0% 0.00 00:03:55 1684.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1671.27 2020-03-06 04:53:00.000 BP 2020-03-06 10:58:00.000 EP Short 1672.30 21 3 3 21.70 -1623.30 21.70 F 45.60 -15.70 0.00 0.00 93.9% 159.7% 112.1% 0.00 06:05:00 1690.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1678.67 2020-03-06 10:58:03.042 BP 2020-03-09 10:00:37.082 EP Short 1678.29 93 4 4 -36.00 -1659.30 -36.00 F 0.00 -86.40 0.00 0.00 97.7% 90.4% -6.4% 0.00 70:02:34 1704.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1670.85 2020-03-09 10:05:42.011 BP 2020-03-09 13:26:00.000 EP Short 1669.31 10 3 3 -15.40 -1674.70 -15.40 F 0.00 -14.10 0.00 0.00 82.5% 43.5% -36.5% 0.00 03:20:17 1678.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1665.08 2020-03-09 13:36:00.000 BP 2020-03-10 10:40:00.032 EP Short 1666.34 26 4 4 32.70 -1642.00 32.70 F 34.20 -13.60 0.00 0.00 95.4% 45.3% 18.3% 0.00 21:04:00 1682.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1650.84 2020-03-10 11:01:00.000 BP 2020-03-11 19:36:00.000 EP Short 1651.16 32 3 3 10.20 -1631.80 10.20 F 18.20 -30.10 0.00 0.00 96.4% 5.0% -45.0% 0.00 32:35:00 1669.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1638.50 2020-03-11 21:04:21.035 BP 2020-03-12 03:54:07.020 EP Short 1639.15 10 3 3 6.50 -1625.30 6.50 F 19.90 0.00 0.00 0.00 98.7% 6.1% 6.1% 0.00 06:49:45 1650.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1643.10 2020-03-12 04:12:12.113 BP 2020-03-12 04:13:00.000 EP Short 1642.70 1 1 1 -0.40 -1625.70 -0.40 F 0.00 0.00 0.00 0.00 67.7% 0.0% 0.0% 0.00 00:00:47 1643.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1598.17 2020-03-12 04:42:00.000 BP 2020-03-12 12:33:00.000 EP Short 1601.98 37 4 4 141.00 -1484.70 141.00 F 153.00 -4.20 9.00 -4.20 92.1% 21.4% 18.8% 0.00 07:51:00 1645.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1586.15 2020-03-12 12:36:00.000 BP 2020-03-12 16:55:00.000 EP Short 1585.29 27 4 4 -23.20 -1507.90 -23.20 F 0.00 -64.00 0.00 0.00 95.5% 47.3% -45.3% 0.00 04:19:00 1608.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1569.26 2020-03-12 16:59:55.002 BP 2020-03-12 22:42:00.000 EP Short 1570.78 14 4 4 21.30 -1486.60 21.30 F 36.50 -11.00 0.00 0.00 85.4% 78.7% 21.6% 0.00 05:42:04 1584.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1582.72 2020-03-12 22:44:00.000 BP 2020-03-13 08:46:00.000 EP Short 1579.76 24 3 3 -70.90 -1557.50 -70.90 F 4.00 -66.40 4.00 -1.90 93.0% -49.4% -128.5% 0.00 10:02:00 1594.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1583.86 2020-03-13 08:48:00.000 BP 2020-03-13 10:22:00.000 EP Short 1585.42 13 3 3 20.20 -1537.30 20.20 F 33.80 -4.40 0.00 0.00 92.8% 86.1% 55.4% 0.00 01:34:00 1597.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1538.09 2020-03-13 10:24:00.000 BP 2020-03-15 19:45:00.000 EP Short 1537.52 77 4 4 -43.80 -1581.10 -43.80 F 117.90 -63.30 11.40 -3.60 95.0% 36.2% 1.5% 0.00 57:21:00 1582.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1544.66 2020-03-15 19:46:00.000 BP 2020-03-15 22:37:00.000 EP Short 1547.02 13 4 4 30.60 -1550.50 30.60 F 50.50 -4.10 0.00 0.00 94.1% 95.4% 64.6% 0.00 02:51:00 1563.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1497.33 2020-03-15 22:38:33.016 BP 2020-03-16 15:43:05.016 EP Short 1497.48 129 5 5 19.70 -1530.80 19.70 F 143.10 -4.10 0.00 0.00 96.1% 14.8% 9.4% 0.00 17:04:32 1550.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1506.33 2020-03-16 15:52:52.001 BP 2020-03-16 18:09:00.000 EP Short 1503.95 11 3 3 -26.20 -1557.00 -26.20 F 0.00 -28.30 0.00 0.00 89.6% 160.7% 88.0% 0.00 02:16:07 1517.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1502.75 2020-03-16 18:11:40.001 BP 2020-03-16 23:54:53.000 EP Short 1503.10 23 3 3 8.00 -1549.00 8.00 F 28.00 -18.60 0.00 0.00 90.0% 282.8% 243.7% 0.00 05:43:12 1519.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1480.96 2020-03-17 00:11:37.008 BP 2020-03-17 08:21:00.000 EP Short 1481.88 24 4 4 22.00 -1527.00 22.00 F 48.60 0.00 0.00 0.00 94.3% -1.6% -1.6% 0.00 08:09:22 1505.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1525.00 2020-03-17 08:30:41.054 BP 2020-03-17 15:15:59.001 EP Short 1522.56 42 4 4 -102.50 -1629.50 -102.50 F 0.40 -126.30 0.00 0.00 98.0% 16.4% -74.1% 0.00 06:45:17 1551.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1513.41 2020-03-17 15:20:56.001 BP 2020-03-18 06:41:27.003 EP Short 1514.73 46 3 3 60.70 -1568.80 60.70 F 88.20 -5.40 0.00 0.00 93.8% 61.7% 40.0% 0.00 15:20:31 1544.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1500.12 2020-03-18 06:46:00.000 BP 2020-03-18 14:43:59.000 EP Short 1499.80 57 4 4 -18.30 -1587.10 -18.30 F 29.90 -26.20 0.00 0.00 97.0% 64.2% 9.8% 0.00 07:57:59 1519.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1486.01 2020-03-18 14:44:57.013 BP 2020-03-19 02:10:59.001 EP Short 1486.78 37 4 4 28.30 -1558.80 28.30 F 54.40 -13.50 0.00 0.00 96.4% 65.0% 38.0% 0.00 11:26:01 1504.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1479.84 2020-03-19 02:15:04.100 BP 2020-03-19 18:18:00.000 EP Short 1479.67 56 3 3 -9.70 -1568.50 -9.70 F 0.00 -54.10 0.00 0.00 97.6% 86.7% -7.9% 0.00 16:02:55 1496.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1499.38 2020-03-19 18:24:57.000 BP 2020-03-23 09:54:00.000 EP Short 1497.02 85 4 4 -200.30 -1768.80 -200.30 F 5.30 -183.60 5.30 -4.70 96.6% 87.9% -10.2% 0.00 87:29:03 1531.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1553.29 2020-03-23 10:00:59.004 BP 2020-03-23 18:11:00.000 EP Short 1548.76 18 3 3 -81.60 -1850.40 -81.60 F 3.50 -62.30 3.50 -3.60 89.3% 6.3% -85.5% 0.00 08:10:00 1571.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1623.23 2020-03-23 18:12:09.001 BP 2020-03-24 07:08:00.000 EP Short 1619.16 55 4 4 -223.80 -2074.20 -223.80 F 7.30 -262.10 7.30 -0.40 95.9% 76.7% -18.2% 0.00 12:55:50 1696.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1672.58 2020-03-24 07:08:28.002 BP 2020-03-24 07:52:00.000 EP Short 1670.54 13 3 3 -26.50 -2100.70 -26.50 F 3.10 -17.70 3.10 -6.90 86.3% 33.9% -59.0% 0.00 00:43:31 1680.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1668.17 2020-03-24 07:52:03.008 BP 2020-03-24 08:46:00.000 EP Short 1668.56 12 4 4 4.70 -2096.00 4.70 F 20.30 -10.70 1.80 -5.50 81.0% 130.9% 62.1% 0.00 00:53:56 1679.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1659.07 2020-03-24 08:46:47.026 BP 2020-03-24 19:20:00.000 EP Short 1659.06 51 4 4 -0.70 -2096.70 -0.70 F 87.30 -7.50 0.00 0.00 96.7% 24.4% 18.5% 0.00 10:33:12 1684.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1651.28 2020-03-24 19:27:27.006 BP 2020-03-25 13:11:59.000 EP Short 1652.36 74 4 4 80.20 -2016.50 80.20 F 124.70 -9.40 0.00 0.00 97.2% 18.1% 12.7% 0.00 17:44:31 1699.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1632.15 2020-03-25 13:18:56.022 BP 2020-03-26 05:46:00.000 EP Short 1631.77 30 4 4 -11.20 -2027.70 -11.20 F 16.00 -22.20 3.80 -4.50 92.3% -125.3% -190.7% 0.00 16:27:03 1647.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1652.04 2020-03-26 05:49:59.004 BP 2020-03-27 02:17:57.001 EP Short 1649.99 51 4 4 -104.20 -2131.90 -104.20 F 1.40 -83.60 1.40 -4.10 95.2% 84.7% -13.8% 0.00 20:27:57 1672.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1643.61 2020-03-27 02:27:19.000 BP 2020-03-27 11:18:00.000 EP Short 1642.34 26 3 3 -33.00 -2164.90 -33.00 F 18.00 -20.90 0.00 0.00 88.1% -7.7% -42.3% 0.00 08:50:41 1658.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1655.47 2020-03-27 11:22:00.000 BP 2020-03-30 04:56:00.000 EP Short 1655.79 26 4 4 8.50 -2156.40 8.50 F 21.30 -26.70 4.00 -2.90 92.5% -111.4% -185.5% 0.00 65:34:00 1673.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1631.78 2020-03-30 05:25:28.032 BP 2020-03-31 08:13:00.000 EP Short 1632.82 33 4 4 34.50 -2121.90 34.50 F 55.50 -5.20 0.00 0.00 94.7% 48.6% 9.2% 0.00 26:47:31 1651.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1607.82 2020-03-31 08:22:03.007 BP 2020-03-31 19:10:59.001 EP Short 1610.06 19 4 4 42.50 -2079.40 42.50 F 49.00 -20.80 0.00 0.00 88.4% 58.4% 16.3% 0.00 10:48:55 1629.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1603.86 2020-03-31 19:39:56.002 BP 2020-04-01 08:30:38.038 EP Short 1600.54 11 4 4 -36.60 -2116.00 -36.60 F 0.00 -42.10 0.00 0.00 91.8% 57.0% -24.8% 0.00 12:50:42 1611.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1598.04 2020-04-01 08:35:44.010 BP 2020-04-01 18:08:55.000 EP Short 1596.66 16 3 3 -22.00 -2138.00 -22.00 F 9.60 -13.30 0.00 0.00 88.3% -61.0% -111.0% 0.00 09:33:10 1606.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1604.59 2020-04-01 18:13:00.000 BP 2020-04-02 08:12:00.000 EP Short 1602.76 15 4 4 -27.40 -2165.40 -27.40 F 2.60 -16.20 2.00 -3.60 88.1% 8.8% -64.1% 0.00 13:59:00 1613.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1631.86 2020-04-02 08:15:30.042 BP 2020-04-03 03:41:38.018 EP Short 1630.14 34 4 4 -58.40 -2223.80 -58.40 F 0.00 -70.70 0.00 0.00 99.4% 84.5% -6.7% 0.00 19:26:07 1645.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1636.77 2020-04-03 04:25:00.000 BP 2020-04-03 09:05:27.003 EP Short 1635.59 12 4 4 -14.10 -2237.90 -14.10 F 2.80 -24.20 0.00 0.00 90.6% -119.7% -186.4% 0.00 04:40:27 1644.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1642.03 2020-04-03 09:43:00.000 BP 2020-04-03 10:57:00.000 EP Short 1637.70 3 3 3 -13.00 -2250.90 -13.00 F 0.00 0.00 0.00 0.00 75.1% 0.0% 0.0% 0.00 01:14:00 1646.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1646.01 2020-04-03 11:02:00.000 BP 2020-04-06 02:17:00.000 EP Short 1644.51 15 4 4 -22.50 -2273.40 -22.50 F 2.60 -17.60 2.60 -4.40 86.2% 70.4% -22.2% 0.00 63:15:00 1654.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1698.77 2020-04-06 02:50:00.000 BP 2020-04-07 01:49:00.000 EP Short 1695.20 49 3 3 -174.70 -2448.10 -174.70 F 0.00 -205.30 0.00 0.00 98.7% 79.0% -14.8% 0.00 22:59:00 1739.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1692.30 2020-04-07 02:01:00.000 BP 2020-04-08 08:00:27.000 EP Short 1693.92 44 4 4 71.50 -2376.60 71.50 F 88.60 -4.20 5.70 -4.20 94.0% 23.0% 20.1% 0.00 29:59:27 1721.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1686.09 2020-04-08 08:06:00.000 BP 2020-04-09 03:03:59.003 EP Short 1683.73 15 4 4 -35.40 -2412.00 -35.40 F 0.00 -28.50 0.00 0.00 94.5% -191.4% -271.4% 0.00 18:57:59 1694.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1704.66 2020-04-09 03:37:46.117 BP 2020-04-09 08:32:00.000 EP Short 1699.88 9 3 3 -43.00 -2455.00 -43.00 F 0.00 -22.00 0.00 0.00 88.5% 50.4% -16.3% 0.00 04:54:13 1713.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1734.78 2020-04-09 08:33:00.000 BP 2020-04-13 02:23:00.000 EP Short 1732.31 35 4 4 -86.40 -2541.40 -86.40 F 0.00 -82.40 0.00 0.00 96.4% 85.7% -5.8% 0.00 89:50:00 1754.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1740.91 2020-04-13 02:38:30.007 BP 2020-04-13 11:11:00.000 EP Short 1739.31 14 4 4 -22.40 -2563.80 -22.40 F 1.50 -13.70 0.00 0.00 93.7% -107.3% -171.6% 0.00 08:32:29 1748.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1765.93 2020-04-13 11:23:40.002 BP 2020-04-13 20:12:00.000 EP Short 1759.96 7 3 3 -41.80 -2605.60 -41.80 F 0.00 -30.20 0.00 0.00 98.0% 41.4% -15.7% 0.00 08:48:19 1772.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1759.71 2020-04-13 20:19:00.000 BP 2020-04-15 06:35:59.003 EP Short 1760.72 48 4 4 48.60 -2557.00 48.60 F 70.90 -38.60 0.00 0.00 96.7% 71.5% 29.0% 0.00 34:16:59 1787.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1745.99 2020-04-15 06:37:34.019 BP 2020-04-15 14:12:46.000 EP Short 1745.44 16 4 4 -8.80 -2565.80 -8.80 F 3.30 -14.60 0.00 0.00 93.8% 8.5% -60.3% 0.00 07:35:11 1755.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1750.79 2020-04-15 15:11:00.000 BP 2020-04-16 10:21:00.000 EP Short 1750.56 19 4 4 -4.30 -2570.10 -4.30 F 7.00 -42.70 0.00 0.00 94.1% 13.5% -65.5% 0.00 19:10:00 1768.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1734.08 2020-04-16 10:27:50.001 BP 2020-04-16 19:50:00.000 EP Short 1735.14 20 3 3 21.00 -2549.10 21.00 F 43.70 -1.70 0.00 0.00 88.9% 26.8% 21.8% 0.00 09:22:09 1761.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1717.86 2020-04-16 20:02:57.000 BP 2020-04-17 03:33:13.008 EP Short 1720.49 16 4 4 42.20 -2506.90 42.20 F 42.20 -7.40 11.50 -5.50 86.7% 59.5% 20.4% 0.00 07:30:16 1736.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1703.40 2020-04-17 03:38:00.000 BP 2020-04-20 14:44:41.000 EP Short 1702.94 43 4 4 -20.00 -2526.90 -20.00 F 23.50 -29.40 0.00 0.00 97.5% 17.8% -35.7% 0.00 83:06:41 1722.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1708.22 2020-04-20 14:59:00.000 BP 2020-04-21 02:56:00.000 EP Short 1705.45 8 3 3 -22.20 -2549.10 -22.20 F 0.00 -4.80 0.00 0.00 87.8% 1.5% -73.5% 0.00 11:57:00 1714.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1696.02 2020-04-21 03:07:06.000 BP 2020-04-22 08:30:37.006 EP Short 1695.55 69 4 4 -32.70 -2581.80 -32.70 F 105.10 -44.80 0.00 0.00 97.5% -30.8% -52.6% 0.00 29:23:31 1729.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1727.10 2020-04-22 08:51:44.012 BP 2020-04-22 08:56:00.000 EP Short 1722.50 1 1 1 -4.60 -2586.40 -4.60 F 0.00 0.00 0.00 0.00 97.5% 0.0% 0.0% 0.00 00:04:15 1727.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1731.96 2020-04-22 08:59:00.000 BP 2020-04-22 13:17:00.000 EP Short 1728.95 10 3 3 -30.10 -2616.50 -30.10 F 1.90 -15.00 0.00 0.00 92.9% 6.8% -53.2% 0.00 04:18:00 1738.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1736.48 2020-04-22 13:30:00.000 BP 2020-04-23 02:06:57.000 EP Short 1735.93 10 4 4 -5.50 -2622.00 -5.50 F 1.60 -6.30 0.00 0.00 89.9% 0.8% -54.8% 0.00 12:36:57 1744.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1749.27 2020-04-23 02:23:00.000 BP 2020-04-24 02:40:00.000 EP Short 1748.06 27 4 4 -32.70 -2654.70 -32.70 F 1.90 -44.10 1.90 -5.40 91.7% -5.2% -102.3% 0.00 24:17:00 1764.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1745.16 2020-04-24 03:06:54.000 BP 2020-04-24 12:06:02.007 EP Short 1748.65 14 4 4 48.90 -2605.80 48.90 F 32.80 -11.60 0.00 0.00 92.3% 56.2% 20.5% 0.00 08:59:08 1760.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1738.40 2020-04-24 12:21:00.000 BP 2020-04-24 13:56:58.001 EP Short 1730.87 3 2 2 -22.60 -2628.40 -22.60 F 0.00 -5.90 0.00 0.00 52.1% -9.0% -42.4% 0.00 01:35:58 1740.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1738.22 2020-04-24 14:56:00.000 BP 2020-04-27 03:12:51.010 EP Short 1738.60 10 5 5 3.80 -2624.60 3.80 F 0.00 -15.80 0.00 0.00 89.6% 85.8% 5.8% 0.00 60:16:51 1745.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1724.44 2020-04-27 03:36:00.000 BP 2020-04-28 05:22:00.000 EP Short 1725.68 19 3 3 23.50 -2601.10 23.50 F 44.60 -11.00 0.00 0.00 94.6% 49.4% 28.3% 0.00 25:46:00 1743.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1717.61 2020-04-28 05:25:50.028 BP 2020-04-28 11:39:00.000 EP Short 1720.47 9 4 4 25.70 -2575.40 25.70 F 41.50 -3.60 0.00 0.00 91.9% 348.0% 303.6% 0.00 06:13:09 1729.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1719.03 2020-04-28 11:56:00.000 BP 2020-04-29 15:34:00.000 EP Short 1717.72 24 4 4 -31.40 -2606.80 -31.40 F 0.00 -25.20 0.00 0.00 97.1% 69.9% -17.6% 0.00 27:38:00 1727.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1706.03 2020-04-29 15:40:45.027 BP 2020-05-01 03:06:59.005 EP Short 1708.40 31 4 4 73.50 -2533.30 73.50 F 65.90 -11.50 0.00 0.00 98.0% 37.3% 14.7% 0.00 35:26:13 1733.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1685.62 2020-05-01 03:27:00.000 BP 2020-05-01 07:25:00.000 EP Short 1681.68 5 3 3 -19.70 -2553.00 -19.70 F 0.00 -5.30 0.00 0.00 75.3% -81.0% -121.0% 0.00 03:58:00 1692.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1706.06 2020-05-01 07:40:37.018 BP 2020-05-04 09:22:11.001 EP Short 1703.37 21 4 4 -56.60 -2609.60 -56.60 F 0.00 -70.60 0.00 0.00 90.7% 57.2% -28.5% 0.00 73:41:33 1726.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1705.08 2020-05-04 09:46:00.000 BP 2020-05-06 20:28:57.001 EP Short 1705.22 46 4 4 6.40 -2603.20 6.40 F 20.30 -23.90 0.00 0.00 98.0% 112.7% 64.9% 0.00 58:42:57 1717.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1717.06 2020-05-06 20:48:22.000 BP 2020-05-08 09:49:00.000 EP Short 1714.03 25 4 4 -75.80 -2679.00 -75.80 F 8.90 -86.30 0.00 0.00 95.4% 52.2% -23.8% 0.00 37:00:38 1735.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1710.61 2020-05-08 09:57:38.001 BP 2020-05-11 07:00:24.046 EP Short 1712.64 19 4 4 38.70 -2640.30 38.70 F 27.90 -7.80 0.00 0.00 89.4% 136.1% 120.3% 0.00 69:02:46 1730.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1702.82 2020-05-11 07:44:59.008 BP 2020-05-12 00:00:00.000 EP Short 1701.98 12 4 4 -10.10 -2650.40 -10.10 F 7.50 -25.00 0.00 0.00 91.1% 28.7% -29.7% 0.00 16:15:00 1712.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1710.79 2020-05-12 01:06:20.073 BP 2020-05-13 11:27:00.000 EP Short 1708.49 18 3 3 -41.40 -2691.80 -41.40 F 0.00 -30.90 0.00 0.00 93.1% 46.2% -37.1% 0.00 34:20:39 1724.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1721.72 2020-05-13 11:51:13.006 BP 2020-05-14 03:05:00.000 EP Short 1721.30 5 3 3 -2.10 -2693.90 -2.10 F 5.40 0.00 0.00 0.00 62.8% -21.1% -21.1% 0.00 15:13:46 1727.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1726.04 2020-05-14 03:52:48.008 BP 2020-05-14 09:36:00.000 EP Short 1722.83 7 3 3 -22.50 -2716.40 -22.50 F 0.00 -6.00 0.00 0.00 72.8% -10.7% -67.8% 0.00 05:43:11 1730.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1745.43 2020-05-14 09:46:58.109 BP 2020-05-15 11:25:00.000 EP Short 1742.86 20 4 4 -51.40 -2767.80 -51.40 F 0.00 -42.80 0.00 0.00 99.3% 75.6% -9.4% 0.00 25:38:01 1756.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1758.89 2020-05-15 11:29:00.000 BP 2020-05-17 19:47:00.000 EP Short 1755.69 8 4 4 -25.60 -2793.40 -25.60 F 0.00 -13.90 0.00 0.00 87.6% 58.8% -16.2% 0.00 56:18:00 1765.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1747.24 2020-05-17 20:53:59.002 BP 2020-05-19 09:07:00.000 EP Short 1747.70 31 3 3 14.30 -2779.10 14.30 F 49.70 -34.50 0.00 0.00 95.5% 45.2% 12.9% 0.00 36:13:00 1775.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1741.45 2020-05-19 09:16:13.056 BP 2020-05-22 02:57:00.000 EP Short 1740.51 34 3 3 -32.10 -2811.20 -32.10 F 4.70 -57.40 0.00 0.00 93.9% 56.8% -28.5% 0.00 65:40:46 1757.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1730.29 2020-05-22 03:01:29.000 BP 2020-05-25 23:07:59.005 EP Short 1731.51 13 4 4 15.80 -2795.40 15.80 F 33.30 0.00 0.00 0.00 90.9% 12.5% 12.5% 0.00 92:06:30 1742.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1713.51 2020-05-26 00:37:51.000 BP 2020-05-27 09:53:32.052 EP Short 1716.47 24 5 5 71.20 -2724.20 71.20 F 82.80 0.00 0.00 0.00 95.2% 2.9% 2.9% 0.00 33:15:41 1737.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1714.95 2020-05-27 10:02:00.000 BP 2020-05-27 12:11:00.000 EP Short 1708.40 4 3 3 -26.20 -2750.40 -26.20 F 0.00 -6.80 0.00 0.00 68.8% -1.1% -51.1% 0.00 02:09:00 1718.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1731.48 2020-05-27 12:15:11.003 BP 2020-05-28 15:58:36.018 EP Short 1730.71 12 4 4 -9.20 -2759.60 -9.20 F 0.00 -33.20 0.00 0.00 92.1% 56.2% -18.8% 0.00 27:43:25 1742.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1733.88 2020-05-28 19:13:07.068 BP 2020-05-29 06:39:59.001 EP Short 1731.46 5 3 3 -12.10 -2771.70 -12.10 F 4.90 0.00 0.00 0.00 76.2% -55.9% -55.9% 0.00 11:26:51 1740.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1731.12 2020-05-29 07:04:47.039 BP 2020-06-04 11:03:34.034 EP Short 1731.98 57 4 4 49.40 -2722.30 49.40 F 90.20 -27.00 0.00 0.00 97.5% 29.9% -8.7% 0.00 147:58:46 1760.70 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1721.60 2020-06-04 11:14:16.001 BP 2020-06-04 12:16:00.000 EP Short 1718.00 1 1 1 -3.60 -2725.90 -3.60 F 0.00 0.00 0.00 0.00 95.5% 0.0% 0.0% 0.00 01:01:43 1721.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1694.45 2020-06-04 14:47:59.006 BP 2020-06-05 11:03:56.002 EP Short 1697.38 24 4 4 70.20 -2655.70 70.20 F 71.10 0.00 0.00 0.00 95.4% 14.5% 14.5% 0.00 20:15:56 1729.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1686.70 2020-06-05 11:26:00.000 BP 2020-06-05 15:46:00.000 EP Short 1679.20 2 2 2 -15.00 -2670.70 -15.00 F 0.00 0.00 0.00 0.00 25.0% 0.0% 0.0% 0.00 04:20:00 1687.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1699.64 2020-06-07 18:03:00.000 BP 2020-06-09 05:20:59.003 EP Short 1695.26 14 3 3 -61.20 -2731.90 -61.20 F 4.10 -45.80 4.10 -4.50 84.7% 48.4% -41.4% 0.00 35:17:59 1715.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1718.57 2020-06-09 07:16:59.001 BP 2020-06-09 08:38:00.000 EP Short 1713.05 4 4 4 -22.10 -2754.00 -22.10 F 0.00 0.00 0.00 0.00 71.2% 0.0% 0.0% 0.00 01:21:00 1723.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1725.20 2020-06-09 08:52:51.049 BP 2020-06-10 08:01:00.000 EP Short 1722.67 7 4 4 -17.70 -2771.70 -17.70 F 1.20 -3.80 0.00 0.00 84.5% -79.3% -122.2% 0.00 23:08:08 1732.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1732.67 2020-06-10 08:30:59.003 BP 2020-06-15 10:29:00.000 EP Short 1732.83 55 4 4 9.30 -2762.40 9.30 F 19.90 -24.20 1.20 -3.20 95.8% 71.5% 16.6% 0.00 121:58:00 1751.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1733.38 2020-06-15 11:24:31.080 BP 2020-06-19 08:31:59.003 EP Short 1732.43 45 3 3 -42.70 -2805.10 -42.70 F 0.00 -35.90 0.00 0.00 98.2% 85.3% -10.3% 0.00 93:07:27 1746.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1759.97 2020-06-19 09:21:59.020 BP 2020-06-22 08:29:44.004 EP Short 1757.18 12 4 4 -33.40 -2838.50 -33.40 F 1.40 -50.50 1.40 -4.60 82.5% 36.8% -57.4% 0.00 71:07:44 1775.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1770.00 2020-06-22 08:42:17.085 BP 2020-06-22 08:43:00.000 EP Short 1769.90 1 1 1 -0.10 -2838.60 -0.10 F 0.00 0.00 0.00 0.00 96.8% 0.0% 0.0% 0.00 00:00:42 1770.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1768.62 2020-06-22 09:02:00.000 BP 2020-06-22 11:12:04.000 EP Short 1769.66 5 4 4 5.20 -2833.40 5.20 F 0.00 -5.10 0.00 0.00 75.2% 92.9% 32.9% 0.00 02:10:04 1777.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1769.00 2020-06-22 12:24:00.000 BP 2020-06-22 21:28:00.000 EP Short 1767.70 4 3 3 -5.20 -2838.60 -5.20 F 0.80 0.00 0.00 0.00 72.0% -296.9% -296.9% 0.00 09:04:00 1774.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1765.42 2020-06-22 21:38:00.000 BP 2020-06-23 06:16:00.000 EP Short 1766.30 6 4 4 5.30 -2833.30 5.30 F 22.60 0.00 0.00 0.00 62.1% -11.9% -11.9% 0.00 08:38:00 1775.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1783.00 2020-06-23 06:16:02.005 BP 2020-06-24 10:51:00.000 EP Short 1780.75 21 3 3 -47.10 -2880.40 -47.10 F 0.00 -50.40 0.00 0.00 91.6% 19.1% -71.4% 0.00 28:34:57 1795.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1777.66 2020-06-24 11:14:00.000 BP 2020-06-24 13:05:37.012 EP Short 1780.46 5 4 4 14.00 -2866.40 14.00 F 13.60 0.00 0.00 0.00 53.5% -14.2% -14.2% 0.00 01:51:37 1790.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1772.11 2020-06-24 13:26:00.000 BP 2020-06-26 04:51:00.000 EP Short 1771.88 12 3 3 -2.80 -2869.20 -2.80 F 10.20 0.00 0.00 0.00 90.9% -25.0% -25.0% 0.00 39:25:00 1779.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1781.63 2020-06-26 05:10:59.003 BP 2020-07-02 04:30:59.000 EP Short 1781.89 31 4 4 8.00 -2861.20 8.00 F 45.50 -24.00 0.00 0.00 93.2% 16.7% -5.9% 0.00 143:19:59 1802.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1774.34 2020-07-02 08:04:00.000 BP 2020-07-02 09:43:00.000 EP Short 1776.56 8 4 4 17.80 -2843.40 17.80 F 19.70 0.00 0.00 0.00 87.0% 1.0% 1.0% 0.00 01:39:00 1785.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1786.76 2020-07-02 10:22:34.051 BP 2020-07-06 08:14:00.000 EP Short 1784.69 7 4 4 -14.50 -2857.90 -14.50 F 0.80 -3.80 0.00 0.00 93.6% -113.8% -156.7% 0.00 93:51:25 1791.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1790.36 2020-07-06 08:35:05.047 BP 2020-07-07 10:01:00.000 EP Short 1791.00 8 5 5 5.10 -2852.80 5.10 F 23.20 0.00 0.00 0.00 91.7% 23.3% 23.3% 0.00 25:25:54 1799.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1819.64 2020-07-07 10:10:16.144 BP 2020-07-09 08:46:53.005 EP Short 1817.22 14 4 4 -33.90 -2886.70 -33.90 F 0.00 -37.30 0.00 0.00 97.5% 70.9% -7.7% 0.00 46:36:36 1829.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1808.00 2020-07-09 09:38:00.000 BP 2020-07-12 18:00:22.013 EP Short 1809.02 17 3 3 17.40 -2869.30 17.40 F 28.40 -8.70 0.00 0.00 94.0% 78.8% 55.2% 0.00 80:22:22 1823.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1814.74 2020-07-13 01:55:53.004 BP 2020-07-21 21:07:00.000 EP Short 1812.93 46 4 4 -83.10 -2952.40 -83.10 F 31.70 -60.60 0.00 0.00 98.5% 38.1% -7.5% 0.00 211:11:06 1853.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1856.23 2020-07-21 21:10:38.005 BP 2020-07-22 05:35:59.020 EP Short 1855.69 10 4 4 -5.40 -2957.80 -5.40 F 0.00 -6.30 0.00 0.00 99.4% 66.0% -4.0% 0.00 08:25:21 1863.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1854.52 2020-07-22 06:23:57.008 BP 2020-07-22 09:54:41.005 EP Short 1856.40 6 4 4 11.30 -2946.50 11.30 F 0.00 -5.20 0.00 0.00 91.6% 194.7% 128.0% 0.00 03:30:43 1863.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1858.95 2020-07-22 10:11:00.000 BP 2020-07-22 11:42:00.000 EP Short 1854.05 4 3 3 -19.60 -2966.10 -19.60 F 0.00 -1.90 0.00 0.00 83.8% -122.4% -172.4% 0.00 01:31:00 1863.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1870.98 2020-07-22 12:13:44.098 BP 2020-07-23 02:41:00.000 EP Short 1868.09 9 3 3 -26.00 -2992.10 -26.00 F 0.00 -17.60 0.00 0.00 96.3% -49.6% -116.3% 0.00 14:27:15 1876.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1880.59 2020-07-23 04:01:23.000 BP 2020-07-23 14:52:23.000 EP Short 1880.02 12 3 3 -6.90 -2999.00 -6.90 F 11.60 -18.20 0.00 0.00 99.4% 19.5% -22.1% 0.00 10:51:00 1893.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1906.53 2020-07-23 15:17:00.000 BP 2020-07-27 04:37:00.000 EP Short 1901.75 27 4 4 -129.10 -3128.10 -129.10 F 0.00 -114.60 0.00 0.00 96.1% 70.0% -18.8% 0.00 85:20:00 1938.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1942.66 2020-07-27 04:45:09.028 BP 2020-07-27 23:35:00.000 EP Short 1942.16 34 3 3 -17.20 -3145.30 -17.20 F 5.40 -81.00 4.90 -0.60 93.0% 64.6% -21.7% 0.00 18:49:50 1970.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1924.09 2020-07-27 23:36:52.021 BP 2020-07-28 08:44:00.000 EP Short 1923.54 29 3 3 -15.70 -3161.00 -15.70 F 48.90 -2.80 0.00 0.00 92.5% 12.0% 8.6% 0.00 09:07:07 1944.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1935.08 2020-07-28 08:46:26.042 BP 2020-07-28 10:20:00.000 EP Short 1931.78 6 3 3 -19.80 -3180.80 -19.80 F 0.00 -8.10 0.00 0.00 73.9% 40.5% -26.2% 0.00 01:33:33 1940.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1951.05 2020-07-28 10:27:00.000 BP 2020-07-29 03:02:00.000 EP Short 1948.29 21 3 3 -58.10 -3238.90 -58.10 F 0.00 -52.40 0.00 0.00 95.9% 77.2% -13.3% 0.00 16:35:00 1959.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1960.42 2020-07-29 03:47:00.000 BP 2020-07-30 08:58:18.002 EP Short 1960.23 41 4 4 -8.00 -3246.90 -8.00 F 37.70 -44.10 0.00 0.00 97.3% 24.8% -25.2% 0.00 29:11:18 1985.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1980.34 2020-07-30 09:01:19.056 BP 2020-07-31 03:48:06.020 EP Short 1977.82 21 4 4 -52.80 -3299.70 -52.80 F 22.10 -48.90 0.00 0.00 95.6% 68.8% 6.9% 0.00 18:46:46 1998.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1987.79 2020-07-31 04:17:59.000 BP 2020-07-31 11:00:00.000 EP Short 1989.95 8 3 3 17.30 -3282.40 17.30 F 25.30 0.00 0.00 0.00 86.3% 128.3% 128.3% 0.00 06:42:01 1997.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1990.91 2020-07-31 11:02:00.000 BP 2020-08-04 10:09:00.000 EP Short 1989.37 37 4 4 -57.20 -3339.60 -57.20 F 0.70 -41.10 0.00 0.00 96.6% -0.2% -89.4% 0.00 95:07:00 2004.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 2024.06 2020-08-04 10:19:44.189 BP 2020-08-04 19:48:00.000 EP Short 2016.21 11 3 3 -86.40 -3426.00 -86.40 F 0.00 -66.10 0.00 0.00 92.2% 56.4% -16.3% 0.00 09:28:15 2046.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 2036.11 2020-08-04 20:01:00.000 BP 2020-08-05 01:52:00.000 EP Short 2037.39 7 4 4 8.90 -3417.10 8.90 F 27.60 0.00 0.00 0.00 66.4% -11.7% -11.7% 0.00 05:51:00 2048.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 2053.25 2020-08-05 01:58:33.002 BP 2020-08-05 09:42:00.000 EP Short 2048.84 11 3 3 -48.60 -3465.70 -48.60 F 0.00 -41.10 0.00 0.00 82.1% 66.3% -15.5% 0.00 07:43:26 2059.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 2056.72 2020-08-05 09:43:00.000 BP 2020-08-05 15:39:00.000 EP Short 2057.21 12 4 4 5.90 -3459.80 5.90 F 22.80 -20.80 0.00 0.00 91.8% 162.7% 104.3% 0.00 05:56:00 2068.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 2069.19 2020-08-05 15:42:00.000 BP 2020-08-07 02:03:00.000 EP Short 2068.69 38 4 4 -18.90 -3478.70 -18.90 F 2.80 -45.60 2.80 -3.50 94.4% 68.9% -27.6% 0.00 34:21:00 2089.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 2059.21 2020-08-07 02:24:00.000 BP 2020-08-07 10:12:00.000 EP Short 2062.41 17 3 3 54.30 -3424.40 54.30 F 45.40 -3.80 8.70 -3.80 88.1% 36.1% 30.7% 0.00 07:48:00 2074.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 2038.24 2020-08-07 10:13:05.008 BP 2020-08-09 18:37:59.014 EP Short 2039.21 21 4 4 20.40 -3404.00 20.40 F 29.90 -8.00 0.00 0.00 92.1% 72.9% 39.5% 0.00 56:24:54 2050.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 2043.05 2020-08-09 19:45:57.004 BP 2020-08-09 21:03:00.000 EP Short 2036.60 2 2 2 -12.90 -3416.90 -12.90 F 0.00 0.00 0.00 0.00 33.8% 0.0% 0.0% 0.00 01:17:02 2043.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 2026.41 2020-08-09 21:22:57.003 BP 2020-08-11 05:02:43.059 EP Short 2029.65 33 4 4 107.10 -3309.80 107.10 F 114.60 -37.10 0.00 0.00 92.8% 31.6% -10.9% 0.00 31:39:46 2056.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1952.03 2020-08-11 05:51:00.000 BP 2020-08-11 20:03:01.006 EP Short 1953.84 58 4 4 105.10 -3204.70 105.10 F 108.00 0.00 0.00 0.00 95.8% 5.6% 5.6% 0.00 14:12:01 2001.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1933.50 2020-08-11 20:06:18.024 BP 2020-08-11 20:35:00.000 EP Short 1927.40 1 1 1 -6.10 -3210.80 -6.10 F 0.00 0.00 0.00 0.00 84.8% 0.0% 0.0% 0.00 00:28:41 1933.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1903.65 2020-08-11 20:38:12.034 BP 2020-08-11 22:29:00.000 EP Short 1907.22 17 3 3 60.70 -3150.10 60.70 F 83.90 -8.00 0.00 0.00 87.9% 124.0% 106.3% 0.00 01:50:47 1934.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1904.64 2020-08-11 22:32:25.008 BP 2020-08-12 03:37:00.000 EP Short 1901.66 23 4 4 -68.50 -3218.60 -68.50 F 55.10 -46.30 0.00 0.00 96.5% 8.5% -17.5% 0.00 05:04:34 1941.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1942.46 2020-08-12 03:41:00.000 BP 2020-08-12 10:14:16.015 EP Short 1941.98 40 4 4 -19.20 -3237.80 -19.20 F 24.60 -36.40 2.90 -4.70 94.3% -98.9% -158.5% 0.00 06:33:16 1956.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1952.80 2020-08-12 10:22:20.015 BP 2020-08-12 10:32:00.000 EP Short 1948.90 1 1 1 -3.90 -3241.70 -3.90 F 0.00 0.00 0.00 0.00 92.5% 0.0% 0.0% 0.00 00:09:39 1952.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1952.12 2020-08-12 10:37:00.000 BP 2020-08-12 13:56:02.000 EP Short 1951.97 9 3 3 -1.40 -3243.10 -1.40 F 2.30 -17.60 2.30 -3.50 77.1% 66.3% -20.5% 0.00 03:19:02 1961.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1935.73 2020-08-12 14:17:00.000 BP 2020-08-13 01:20:47.001 EP Short 1938.00 15 3 3 34.00 -3209.10 34.00 F 54.90 0.00 0.00 0.00 92.1% 9.2% 9.2% 0.00 11:03:47 1952.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1942.31 2020-08-13 01:42:00.000 BP 2020-08-13 04:51:00.000 EP Short 1940.07 7 3 3 -15.70 -3224.80 -15.70 F 0.00 -12.60 0.00 0.00 83.1% 44.4% -12.7% 0.00 03:09:00 1946.50 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1937.87 2020-08-13 05:29:55.001 BP 2020-08-13 08:40:01.039 EP Short 1939.48 9 3 3 14.50 -3210.30 14.50 F 23.50 -4.80 0.00 0.00 77.5% 239.7% 206.4% 0.00 03:10:06 1951.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1943.80 2020-08-13 08:55:31.032 BP 2020-08-13 09:23:00.000 EP Short 1939.27 3 3 3 -13.60 -3223.90 -13.60 F 0.00 0.00 0.00 0.00 79.5% 0.0% 0.0% 0.00 00:27:28 1947.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1956.51 2020-08-13 09:28:58.021 BP 2020-08-13 13:38:00.000 EP Short 1951.05 13 3 3 -71.00 -3294.90 -71.00 F 0.00 -47.40 0.00 0.00 85.5% 42.2% -34.7% 0.00 04:09:01 1973.90 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1958.23 2020-08-13 13:44:47.026 BP 2020-08-14 04:22:00.000 EP Short 1959.85 24 4 4 38.90 -3256.00 38.90 F 53.90 0.00 0.00 0.00 91.6% 4.3% 4.3% 0.00 14:37:12 1974.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1953.91 2020-08-14 04:31:59.001 BP 2020-08-14 14:41:00.000 EP Short 1953.60 19 3 3 -5.90 -3261.90 -5.90 F 8.60 -15.70 4.30 -3.40 88.6% -308.8% -368.4% 0.00 10:09:00 1965.30 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1949.12 2020-08-14 14:53:00.000 BP 2020-08-16 20:59:12.002 EP Short 1949.74 8 3 3 4.90 -3257.00 4.90 F 2.20 -15.30 2.20 -3.80 71.8% 21.0% -52.7% 0.00 54:06:12 1959.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1950.30 2020-08-16 21:04:00.000 BP 2020-08-17 00:51:00.000 EP Short 1945.90 4 3 3 -17.60 -3274.60 -17.60 F 0.00 -4.50 0.00 0.00 66.5% 19.4% -5.6% 0.00 03:47:00 1954.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 2001.60 2020-08-17 02:55:55.009 BP 2020-08-19 02:07:15.005 EP Short 2000.00 43 4 4 -69.10 -3343.70 -69.10 F 0.00 -120.90 0.00 0.00 99.4% 51.5% -41.5% 0.00 47:11:19 2024.60 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1996.63 2020-08-19 02:14:00.000 BP 2020-08-19 04:55:00.000 EP Short 1996.28 4 3 3 -1.40 -3345.10 -1.40 F 11.30 0.00 0.00 0.00 68.5% -19.7% -19.7% 0.00 02:41:00 2003.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1966.99 2020-08-19 05:06:00.000 BP 2020-08-19 18:13:01.001 EP Short 1971.29 37 4 4 158.80 -3186.30 158.80 F 144.20 0.00 0.00 0.00 95.7% 28.0% 28.0% 0.00 13:07:01 2005.80 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1944.80 2020-08-19 18:47:00.000 BP 2020-08-19 18:57:52.011 EP Long 1944.20 1 1 1 0.60 -3185.70 0.60 F 0.80 -2.10 0.80 -2.10 0.0% 93.1% 20.7% 0.00 00:10:52 1945.00 1942.10 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1940.13 2020-08-19 19:07:00.000 BP 2020-08-19 20:51:00.000 EP Short 1940.93 3 3 3 2.40 -3183.30 2.40 F 9.20 -4.70 9.20 -4.70 0.0% 39.6% 5.8% 0.00 01:44:00 1946.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1947.74 2020-08-19 20:51:16.000 BP 2020-08-19 22:58:59.001 EP Short 1945.66 5 4 4 -10.40 -3193.70 -10.40 F 7.90 0.00 0.00 0.00 86.9% -17.7% -17.7% 0.00 02:07:43 1953.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1942.72 2020-08-19 23:42:59.002 BP 2020-08-20 09:50:20.083 EP Short 1944.42 24 4 4 40.90 -3152.80 40.90 F 64.40 -5.90 0.00 0.00 96.7% 26.2% 22.0% 0.00 10:07:21 1961.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1943.08 2020-08-20 09:58:00.000 BP 2020-08-21 10:13:20.149 EP Short 1943.81 39 4 4 28.50 -3124.30 28.50 F 46.30 -40.70 0.00 0.00 97.0% 26.5% -27.3% 0.00 24:15:20 1963.10 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1943.95 2020-08-21 10:20:50.058 BP 2020-08-21 10:47:00.000 EP Short 1939.40 2 2 2 -9.10 -3133.40 -9.10 F 0.00 0.00 0.00 0.00 66.3% 0.0% 0.0% 0.00 00:26:09 1945.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1946.77 2020-08-21 10:58:18.060 BP 2020-08-25 00:00:59.338 EP Short 1946.03 39 4 4 -29.00 -3162.40 -29.00 F 7.40 -48.10 0.00 0.00 98.8% 120.3% 43.4% 0.00 85:02:41 1966.40 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1935.38 2020-08-25 00:57:59.907 BP 2020-08-25 06:35:38.524 EP Short 1936.22 6 4 4 5.00 -3157.40 5.00 F 8.60 -3.60 4.70 -3.60 60.1% 100.0% 44.9% 0.00 05:37:38 1943.90 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1928.38 2020-08-25 06:42:59.353 BP 2020-08-25 14:54:59.838 EP Short 1928.30 16 4 4 -1.30 -3158.70 -1.30 F 18.70 -5.20 0.00 0.00 93.0% 81.7% 50.5% 0.00 08:12:00 1938.70 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1923.58 2020-08-25 14:55:39.653 BP 2020-08-26 09:04:04.864 EP Short 1927.13 12 4 4 42.70 -3116.00 42.70 F 22.10 -1.10 0.00 0.00 93.6% 150.3% 125.3% 0.00 18:08:25 1939.30 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1924.10 2020-08-26 09:07:03.092 BP 2020-08-26 09:09:59.924 EP Short 1921.10 1 1 1 -3.00 -3119.00 -3.00 F 0.00 0.00 0.00 0.00 97.4% 0.0% 0.0% 0.00 00:02:56 1924.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1949.50 2020-08-26 09:32:31.045 BP 2020-08-26 16:50:59.727 EP Short 1945.16 12 3 3 -52.10 -3171.10 -52.10 F 0.00 -36.80 0.00 0.00 96.9% 61.0% -14.0% 0.00 07:18:28 1962.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1950.13 2020-08-26 18:04:57.614 BP 2020-08-27 10:12:59.859 EP Short 1952.06 36 5 5 69.30 -3101.80 69.30 F 75.60 -39.20 0.00 0.00 96.0% 22.0% 2.6% 0.00 16:08:02 1987.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1954.60 2020-08-27 10:13:10.050 BP 2020-08-31 06:30:44.629 EP Short 1952.53 54 3 3 -111.70 -3213.50 -111.70 F 9.20 -128.00 0.00 0.00 97.8% 31.7% -51.6% 0.00 92:17:34 1985.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1972.28 2020-08-31 07:36:21.024 BP 2020-09-02 22:05:59.802 EP Short 1971.76 64 4 4 -33.40 -3246.90 -33.40 F 1.90 -77.90 0.00 0.00 97.4% 77.3% -14.8% 0.00 62:29:38 2001.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1941.71 2020-09-02 22:52:59.722 BP 2020-09-03 09:29:59.917 EP Short 1941.83 14 4 4 1.60 -3245.30 1.60 F 36.00 0.00 0.00 0.00 91.8% -6.9% -6.9% 0.00 10:37:00 1956.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1938.05 2020-09-03 09:36:59.933 BP 2020-09-07 09:06:02.614 EP Short 1937.68 51 4 4 -19.10 -3264.40 -19.10 F 38.40 -30.90 0.00 0.00 97.4% 32.5% -30.3% 0.00 95:29:02 1953.60 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1926.07 2020-09-07 10:03:59.673 BP 2020-09-08 07:57:59.824 EP Short 1928.83 15 4 4 41.30 -3223.10 41.30 F 36.20 -8.30 0.00 0.00 92.3% 197.0% 157.0% 0.00 21:54:00 1942.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1920.71 2020-09-08 07:58:58.579 BP 2020-09-08 10:13:59.427 EP Short 1919.51 12 3 3 -14.40 -3237.50 -14.40 F 0.00 -6.20 0.00 0.00 92.1% 8.3% -66.7% 0.00 02:15:00 1927.00 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1947.56 2020-09-08 10:28:46.378 BP 2020-09-10 09:16:59.483 EP Short 1944.36 33 4 4 -105.70 -3343.20 -105.70 F 2.90 -84.10 0.00 0.00 98.9% 68.5% -19.4% 0.00 46:48:13 1971.00 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1959.33 2020-09-10 09:31:59.763 BP 2020-09-11 09:12:59.964 EP Short 1960.35 15 4 4 15.20 -3328.00 15.20 F 35.80 -9.10 1.00 -4.40 85.3% 147.2% 117.6% 0.00 23:41:00 1975.20 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1954.07 2020-09-11 09:34:59.746 BP 2020-09-13 22:13:58.546 EP Short 1954.13 9 4 4 0.60 -3327.40 0.60 F 17.10 -7.20 0.00 0.00 87.4% 74.4% 18.9% 0.00 60:38:58 1963.40 0.00 20-40 S3.twconfig 2 0 [Sim]MGCZ22-COMEX 1955.95 2020-09-13 22:23:25.094 BP 2020-09-14 08:43:59.759 EP Short 1954.70 4 3 3 -5.00 -3332.40 -5.00 F 6.70 -2.00 6.70 -2.00 50.8% -92.9% -110.2% 0.00 10:20:34 1961.10 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1970.36 2020-09-14 08:46:20.344 BP 2020-09-14 22:13:59.260 EP Short 1965.70 5 3 3 -23.30 -3355.70 -23.30 F 0.00 -15.10 0.00 0.00 85.9% 27.3% -12.7% 0.00 13:27:38 1975.50 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1830.66 2020-09-14 23:32:30.162 BP 2022-11-17 01:47:59.844 EP Short 1830.55 5723 4 4 -644.00 -3999.70 -644.00 F 194.70 -1297.00 0.00 0.00 90.8% -1129674710963.6% -1129674711048.3% 0.00 19035:15:29 2078.80 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1769.15 2022-11-17 03:58:58.249 BP 2022-11-17 07:25:59.924 EP Short 1768.30 2 2 2 -1.70 -4001.40 -1.70 F 0.00 0.00 0.00 0.00 64.0% 0.0% 0.0% 0.00 03:27:01 1770.00 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1764.90 2022-11-17 07:38:38.235 BP 2022-11-17 08:24:59.955 EP Short 1764.90 2 2 2 0.00 -4001.40 0.00 F 0.00 0.00 0.00 0.00 49.8% 0.0% 0.0% 0.00 00:46:21 1767.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1761.80 2022-11-17 08:33:59.699 BP 2022-11-17 09:34:56.784 EP Short 1762.85 2 2 2 2.10 -3999.30 2.10 F 0.00 0.00 0.00 0.00 49.8% 0.0% 0.0% 0.00 01:00:57 1763.90 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1763.25 2022-11-17 10:40:59.009 BP 2022-11-17 13:38:57.290 EP Short 1759.35 2 2 2 -7.80 -4007.10 -7.80 F 0.00 0.00 0.00 0.00 50.8% 0.0% 0.0% 0.00 02:57:58 1764.50 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1768.40 2022-11-18 00:24:48.265 BP 2022-11-18 02:12:55.153 EP Short 1763.40 1 1 1 -5.00 -4012.10 -5.00 F 0.00 0.00 0.00 0.00 27.9% 0.0% 0.0% 0.00 01:48:06 1768.40 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1764.60 2022-11-18 02:59:55.637 BP 2022-11-18 03:10:44.639 EP Long 1767.90 1 1 1 -3.30 -4015.40 -3.30 F 0.10 -3.50 0.10 -3.50 0.0% 5.6% -91.7% 0.00 00:10:49 1768.00 1764.40 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1768.00 2022-11-18 03:10:59.177 BP 2022-11-18 04:32:36.277 EP Short 1764.50 2 2 2 -7.00 -4022.40 -7.00 F 0.00 0.00 0.00 0.00 95.0% 0.0% 0.0% 0.00 01:21:37 1768.60 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1765.30 2022-11-18 05:25:15.802 BP 2022-11-18 08:24:35.701 EP Short 1764.45 2 2 2 -1.70 -4024.10 -1.70 F 0.00 0.00 0.00 0.00 49.8% 0.0% 0.0% 0.00 02:59:19 1766.20 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1755.05 2022-11-18 08:48:35.735 BP 2022-11-18 10:16:55.098 EP Short 1760.95 2 2 2 11.80 -4012.30 11.80 F 0.00 0.00 0.00 0.00 49.8% 0.0% 0.0% 0.00 01:28:19 1762.20 0.00 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1539.00 2022-11-18 11:46:48.182 BP 2022-11-20 18:00:59.047 EP Short 1754.80 2 2 2 431.60 -3580.70 431.60 F 0.00 0.00 0.00 0.00 49.8% 0.0% 0.0% 0.00 54:14:10 1756.10 0.00 20-40 S3.twconfig 1 0 [Sim]MGCZ22-COMEX 1748.40 2022-11-20 20:17:59.998 BP 2022-11-21 00:58:57.964 EP Short 1747.70 1 1 1 -0.70 -3581.40 -0.70 F 2.50 -1.70 2.50 -1.70 100.0% 23.8% -16.7% 0.00 04:40:57 1749.40 1745.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1742.80 2022-11-21 02:43:57.884 BP 2022-11-21 05:10:55.618 EP Short 1744.60 1 1 1 1.80 -3579.60 1.80 F 6.20 -1.00 6.20 -1.00 100.0% 38.9% 25.0% 0.00 02:26:57 1745.60 1738.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1744.10 2022-11-21 08:17:58.385 BP 2022-11-21 08:48:54.667 EP Long 1745.00 1 1 1 -0.90 -3580.50 -0.90 F 3.40 -1.20 3.40 -1.20 0.0% 6.5% -19.6% 0.00 00:30:56 1748.40 1743.80 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1735.30 2022-11-21 09:37:59.726 BP 2022-11-21 11:24:53.532 EP Short 1742.70 1 1 1 7.40 -3573.10 7.40 F 7.50 -1.90 7.50 -1.90 100.0% 98.9% 78.7% 0.00 01:46:53 1744.60 1735.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1743.90 2022-11-21 13:06:56.067 BP 2022-11-22 00:32:59.924 EP Long 1739.60 1 1 1 4.30 -3568.80 4.30 F 7.00 -3.00 7.00 -3.00 0.0% 73.0% 43.0% 0.00 11:26:03 1746.60 1736.60 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1745.30 2022-11-22 01:31:56.360 BP 2022-11-22 02:51:58.844 EP Short 1741.80 1 1 1 -3.50 -3572.30 -3.50 F 0.60 -3.50 0.60 -3.50 100.0% 0.0% -85.4% 0.00 01:20:02 1745.30 1741.20 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1746.60 2022-11-22 03:26:59.977 BP 2022-11-22 08:15:59.594 EP Long 1747.30 1 1 1 -0.70 -3573.00 -0.70 F 3.70 -2.90 3.70 -2.90 0.0% 33.3% -10.6% 0.00 04:48:59 1751.00 1744.40 Auto Entry 1 0 [Sim]MGCZ22-COMEX 1746.60 2022-11-22 08:56:57.145 BP 2022-11-22 09:48:57.941 EP Short 1744.00 1 1 1 -2.60 -3575.60 -2.60 F 1.30 -3.70 1.30 -3.70 100.0% 22.0% -52.0% 0.00 00:52:00 1747.70 1742.70 Auto Entry 1 0 Total: -3575.60 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-02 03:21:38
