Date/Time: Wed, 01 May 2024 23:39:13 +0000
bar study data not in order
View Count: 194
[2022-11-21 11:24:15] |
User339214 - Posts: 22 |
there are sporadic instances where the BarStudyData.csv is not in order. Below is an example of ESZ22 at row ~ 1.47 million Is this a known issue, and is there a way to automatically fix things up (deleting all the files and reloading does fix it, but too manual) 2022/11/21, 10:04:22.0, 3955.75, 3955.75, 3955.75, 3955.75, 4, 4, 3955.75, 3955.75, 3955.75, 4, 0 2022/11/21, 10:04:23.0, 3955.75, 3955.75, 3955.75, 3955.75, 1, 1, 3955.75, 3955.75, 3955.75, 1, 0 2022/11/21, 10:04:24.0, 3955.75, 3955.75, 3955.75, 3955.75, 3, 3, 3955.75, 3955.75, 3955.75, 1, 2 2022/11/21, 10:04:25.0, 3955.75, 3955.75, 3955.75, 3955.75, 15, 15, 3955.75, 3955.75, 3955.75, 2, 13 2022/11/21, 10:04:26.0, 3955.75, 3955.75, 3955.75, 3955.75, 1, 1, 3955.75, 3955.75, 3955.75, 0, 1 2022/11/21, 10:04:27.0, 3956.00, 3956.00, 3956.00, 3956.00, 1, 1, 3956.00, 3956.00, 3956.00, 0, 1 2022/11/21, 10:04:24.0, 3955.75, 3955.75, 3955.75, 3955.75, 3, 3, 3955.75, 3955.75, 3955.75, 1, 2 2022/11/21, 10:04:25.0, 3955.75, 3955.75, 3955.75, 3955.75, 15, 15, 3955.75, 3955.75, 3955.75, 2, 13 2022/11/21, 10:04:26.0, 3955.75, 3955.75, 3955.75, 3955.75, 1, 1, 3955.75, 3955.75, 3955.75, 0, 1 2022/11/21, 10:04:27.0, 3956.00, 3956.00, 3956.00, 3956.00, 1, 1, 3956.00, 3956.00, 3956.00, 0, 1 2022/11/21, 10:04:28.0, 3956.00, 3956.00, 3956.00, 3956.00, 20, 19, 3956.00, 3956.00, 3956.00, 10, 10 2022/11/21, 10:04:34.0, 3956.25, 3956.25, 3956.00, 3956.00, 16, 15, 3956.13, 3956.08, 3956.13, 2, 14 2022/11/21, 10:04:35.0, 3956.25, 3956.25, 3956.25, 3956.25, 15, 15, 3956.25, 3956.25, 3956.25, 8, 7 2022/11/21, 10:04:36.0, 3956.25, 3956.50, 3956.25, 3956.50, 9, 8, 3956.38, 3956.42, 3956.38, 1, 8 |
[2022-11-21 16:05:27] |
Sierra_Chart Engineering - Posts: 14173 |
We would not know why this is the case. You have to look at the chart and see if you notice the same problem there with timestamps. Should not be the case. You can also try re-downloading the data: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
