Date/Time: Mon, 29 Apr 2024 16:18:12 +0000
Quoteboard
View Count: 983
[2014-05-27 07:12:40] |
User22153 - Posts: 46 |
Hello Support, I have a problem with the quotebaord and the charts. I've drawn objects on different stocks, however they show up on all the other stocks. This is only happens when the quote board is linked to the chart. The only way around this that I can see is if i open each stock chart without quotebaord but this is impossible to manage. Is there a disable button for the drawings to stay on the chart that they are drawn on and not shown on all the stocks? Thanks |
[2014-05-27 08:08:56] |
There is an option in the Chart >> Chart Settings to prevent this: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ShowingDrawingsforDifferentSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
