Date/Time: Sun, 05 May 2024 13:17:50 +0000
Issues with studies after migration to another PC
View Count: 266
[2022-11-19 08:11:46] |
maxm1987 - Posts: 104 |
Dear support. i migrated my installation to another pc. please have a look at the screenshot. ffor some reason the studies names are not displayed correctly anymore but rather it shows the path on the computer where the studies are located. Aditionally, my studies are not shown on the chart, the only study that is displayed is market profile and volume profile but the Mid, and the SMAs wont get displayed. Any idea whats wrong? |
studies.PNG / V - Attached On 2022-11-19 07:57:48 UTC - Size: 92.95 KB - 64 views |
[2022-11-21 14:38:30] |
Sierra_Chart Engineering - Posts: 14232 |
We want you to install Sierra Chart again to the same folder as the installation where you have a problem. The Sierra Chart studies file apparently is missing. Follow the instructions here: Software Download: Fast Update The process of updating will install the necessary files. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-21 14:40:34
