Date/Time: Sun, 05 May 2024 18:12:16 +0000
How to get data?
View Count: 969
[2014-05-26 17:37:57] |
User24187 - Posts: 54 |
The goal is to gather daily data on the NQ, such as 5 min OR, 15 min OR, etc. Is it possible to automate this process? Where do I begin?
[2014-05-26 19:49:13] |
Here are the instructions for opening charts: http://www.sierrachart.com/index.php?l=doc/doc_GettingStarted.php#ConnectingtoData You may want to use the Intraday File Update List to have data stored for this symbol without having a chart open: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSettingsMenu.html#IntradayFileUpdateList Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
