Date/Time: Fri, 03 May 2024 22:30:34 +0000
SC historical data doesn't have seconds for range bars
View Count: 981
[2014-05-26 15:53:21] |
onnb - Posts: 661 |
hi - I am using SC Historical Data with ESM4. I have a range chart open set to 1.00 range bars. All my timestamps have 00 seconds. I am on version 1132. Any idea why this might be?
[2014-05-26 19:43:36] |
The correct symbol is ESM14. You are not using the correct symbol. Always choose the correct symbol through File >> Find Symbol to make sure the symbol is correct.
