Date/Time: Sat, 27 Apr 2024 18:30:45 +0000
One graph divided by another one
View Count: 1338
[2014-05-25 10:53:58] |
User78745 - Posts: 38 |
Dear all, Do you think there is a study which can divided one graph by another one ? I need a ratio graphic. Best regards, |
[2014-05-25 12:06:31] |
vegasfoster - Posts: 444 |
Yes, it's called the study subgraphs ratio.
[2014-05-25 12:58:29] |
Dear Vegasfoster, Tx you for you help. Regards, |
[2014-05-26 03:36:27] |
Here is the documentation for the Study Subgraphs Ratio study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s236 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-26 12:29:02] |
Dear all, I have just tried to draw a ratio between 2 graphs but unfortunately you can use the study subgraphs ration only with two subgraphs or one main graph & one subgraph but not with 2 graphs. Probably it should have a way to do it. regards, |
[2014-05-26 20:05:12] |
The Input Study 1/2 inputs have the ability to reference any study on the chart and within those studies reference any Subgraphs. There is complete flexibility with that study. Do you want to reference two different charts? If so, you will need to use the one of the Ratio studies instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
