Date/Time: Fri, 13 Nov 2026 21:50:35 +0000
simulated feed and market orders
View Count: 696
[2022-11-14 05:23:33]
User61576 - Posts: 458
SC team can you pls share and explain what the error actually means if I use denali deed for data?
imageScreenshot_1.jpg / V - Attached On 2022-11-14 05:22:33 UTC - Size: 39.02 KB - 250 views
[2022-11-14 10:49:57]
You are not using the correct symbols. You need to translate them with this Edit menu command:
Edit Menu: Edit >> Translate Symbols To Current Service
