Date/Time: Fri, 03 May 2024 03:44:34 +0000
cannot connect do datafeed
View Count: 1052
[2014-05-25 07:58:13] |
User30743 - Posts: 364 |
hello, ive been facing problems with connection to datafeed, i cant coonect althout my internet is working, the dafafeed is set ok and everything should work well. any tips where the problem might be? |
connect.png / V - Attached On 2014-05-25 07:58:06 UTC - Size: 100.1 KB - 346 views |
[2014-05-26 07:10:34] |
You are encountering a "permission denied" error when connecting to Rithmic. Refer to step number 15 here: http://www.sierrachart.com/?l=doc/Rithmic.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
