Date/Time: Fri, 13 Nov 2026 21:50:24 +0000
Large volume study stopped working
View Count: 1031
| [2022-11-11 19:46:06] |
| User427421 - Posts: 48 |
Hello, I had to switch my charts to CQG (was using ritmic before) After the switch my large volume indicator study stopped working. I tried many things but it still not working. I even duplicated the chart and it's not working either.
| [2022-11-11 20:05:51] |
| Sierra_Chart Engineering - Posts: 25422 |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-11 20:39:48] |
Thanks, that fixed the issue
