Date/Time: Mon, 29 Apr 2024 08:12:02 +0000
Delete Chart Drawings added by UseTool
View Count: 1058
[2014-05-23 21:00:37] |
sampater - Posts: 243 |
I have a question: If i have Chart Drawings that have been added by Advanced Custom Studies using sc.UseTool() and have specified AddAsUserDrawnDrawing = 1, then i must deleted them by calling sc.DeleteLineOrText() or sc.DeleteUserDrawnACSDrawing() ? Here: http://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html#AddAsUserDrawnDrawing is described that i must do it by calling sc.DeleteLineOrText(), and here: http://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html#scDeleteUserDrawnACSDrawing that sc.DeleteUserDrawnACSDrawing() deletes these Chart Drawings. Which function is properly, or both work for this? Thanks Marek |
[2014-05-23 22:26:24] |
We need to update the documentation. You need to use: http://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html#scDeleteUserDrawnACSDrawing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-24 07:57:36] |
Thanks for update. (from http://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html#AddAsUserDrawnDrawing ) "A chart drawing added with AddAsUserDrawnDrawing set to 1 is not saved to a Chartbook like an actual user drawn drawing would be." - Is this up to date? Thanks Marek Date Time Of Last Edit: 2014-05-24 07:57:59
[2014-05-24 20:07:33] |
Yes.
