Date/Time: Fri, 13 Nov 2026 21:56:29 +0000
market statistics
View Count: 699
[2022-11-09 01:49:36]
clibanez - Posts: 10
Hi, I'm trying to find what these 4 symbols would be in sierrachart. I think I'm missing these 2
(UVOL-DVOL)
(ADVN-$DECN)
imageinternals.png / V - Attached On 2022-11-09 01:45:21 UTC - Size: 227.94 KB - 253 views
[2022-11-09 14:59:38]
UVOL - DVOL is "NVOL"
We do not have a direct statistic for ADVN - DECN (Advance - Decline). There is a Ratio that is the "ADR".
You would have to create the chart by having the ADV (Advance) and DECL (Decline) statistics and then subtracting one from the other using the Bar Difference study. Refer to the information here:
Bar Difference
Also refer to the information on the Market Statistics at the following link:
Sierra Chart Market Statistics
