Date/Time: Sat, 27 Apr 2024 07:30:30 +0000
[User Discussion] - New chart studie
View Count: 1380
[2014-05-23 17:31:43] |
User52247 - Posts: 26 |
Hi all, I found a new indicator that detects the output flat range : "moindre carré" Would someone kindly translate it for sierra? example chart attached : http://hpics.li/d4f9ba6 Thanks FORMULE CHART STUDIE "MOINDRE CARRE" PeriodL=50 PeriodS=20 del=4 MMEL=exponentialaverage[PeriodL](close) MMES=exponentialaverage[PeriodS](close) y1=(MMES[del]+MMEL[del])/2 y2=(MMES+MMEL)/2 coeff=((y2-y1)/del)*1000 return coeff |
[2014-05-23 18:12:55] |
crazybears - Posts: 314 |
hi looks interesting and easy to code i'll try to code |
[2014-05-23 18:57:51] |
OK thanks
[2014-05-23 19:56:24] |
try |
MOINDRE_CARRE.cpp - Attached On 2014-05-23 19:56:08 UTC - Size: 2.03 KB - 411 views |
[2014-05-23 20:27:31] |
MOINDRE_CARRE.cpp -> C: -> SierraChart ->ACS_Source -> What do I need to do to put it on the graph ?
[2014-05-23 20:54:05] |
1) Select-> Analysis -> Build Custom Studies DLL 2) on Window open click on Select file(s)button 3) select MOINDRE_CARRE.cpp click open located in C: -> SierraChart ->ACS_Source 4) click Build Custom Studies DLL button 5) should be no mess. error :) 6) click on studies -> Add Custom studies have fun :D |
[2014-05-23 21:02:59] |
Wonderful, everything is ok. THANKS A LOT You're the best :) |
