Date/Time: Fri, 13 Nov 2026 21:56:35 +0000
Replays on DOMs not smooth
View Count: 636
[2022-11-07 21:11:55]
User449884 - Posts: 237
trying to replay the current or past days with my DOMs and it very choppy and slow.
Are there any settings that need to be adjusted?
[2022-11-08 16:33:53]
There is nothing you can do that is specific to a replay to "improve" performance. The only things are the same things you would do in general. Therefore, refer to the following:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
