Date/Time: Tue, 07 May 2024 22:37:47 +0000
problem with Crosshair
View Count: 941
[2014-05-23 15:30:45] |
User22153 - Posts: 46 |
Hello Support, This might be a basic question but I can't seem to have free movement with the crosshair. Its locking on to the prices on the right. Anyway to stop it from locking onto price? Regards |
[2014-05-23 16:50:00] |
Yes. Disable Chart >> Chart Settings >>Adjust Tool Values to Tick Size.
