Date/Time: Fri, 13 Nov 2026 21:56:39 +0000
Error when working with Standard Deviation in Spreadsheet
View Count: 1043
| [2022-11-07 11:23:03] |
| User718690 - Posts: 18 |
Hello, I am trying to learn and work with the spreadsheet. When I use the standard deviation function I get the same result for every row no matter what parameters I enter. Please review the attached files. I would greatly appreciate some help on this case. |
| [2022-11-07 16:05:58] |
| Sierra_Chart Engineering - Posts: 25422 |
The formula does not look correct to us. Use a range reference to all of the values you want to calculate the standard deviation for: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#STDEVS_Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
