Date/Time: Fri, 13 Nov 2026 21:56:54 +0000
Sessions
View Count: 881
| [2022-11-07 01:43:52] |
| User72965 - Posts: 116 |
I did what you sent It started 4 p.m. Sunday night It left N&O on Fri. afternoon Started Sun > "R" ~~ I'm going to see What happens Mon. afternoon Should start at 4:00 p.m. ??!!!~~ https://www.sierrachart.com/image.php?Image=1667785365517.png Gene :) |
| [2022-11-07 22:49:14] |
| John - SC Support - Posts: 48527 |
We really do not know what you are trying to say, but we think you are trying to tell us that the start times for your TPO profiles are not what you are expecting. If this is the case, then you need to look at your Session Times. The times for the TPO profiles are based directly on the Session Times, so you would need to adjust your Session Times to what you want for your TPO profiles. Refer to the following: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-07 23:25:12] |
Screen on what happened:Did not Split off ON Ashttps://www.sierrachart.com/image.php?Image=1667863416811.png you can see.Started with R :) |
| [2022-11-07 23:28:13] |
Started with R O&N on Session yet~~ Gene:) https://www.sierrachart.com/image.php?Image=1667863618676.png |
| [2022-11-08 17:07:04] |
The only option within the TPO to control the what letters start when is the following: Time Price Opportunity (TPO) Profile Charts: Letters Always Start at Primary Session Start Time Note that this only applies to the Primary session (day session) TPO. If you have an evening session separate from the day session, then only the day session will start at A and the evening session will follow the letters from the end of the day session. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-08 19:19:10] |
Prior board <> I did mean :) A stared @ 7:30 > Sharp +Asit was supposed to~~ Yes we have a time of understanding one Another ~~ HOWEVER :) :) >>> It's looking like we got it whipped I'll post Screens Thx for your patience&input Gene :) { Hope I need not to come back on the same manner !! https://www.sierrachart.com/image.php?Image=1667934828979.png https://www.sierrachart.com/image.php?Image=1667935121109.png |
