Date/Time: Fri, 13 Nov 2026 21:56:27 +0000
Banknifty Number bar chart squished
View Count: 743
[2022-11-06 04:00:14]
User644077 - Posts: 5
I m trying to apply number bar and see the imbalances and/or aggressive buying on Banknifty (NSE India). THe charts I get are extremely squeezed and I cannot make it legible on a okayish scale. It may be because the price range of each bar is huge ( which is inherent problem of banknifty). Is there any way I can fix it and usefully use sierra charts number bar for banknifty?
I use S&P futures with this setup and have no issues at all.
I have a 4k screen so real estate is not an issue.
p.s. I am using Global Data Feeds for India.
What I see->
Regards,
Anup
Date Time Of Last Edit: 2022-11-06 04:02:24
attachment2022-11-05 22-55-57.mp4 - Attached On 2022-11-06 03:58:10 UTC - Size: 3.36 MB - 373 views
[2022-11-06 15:40:11]
Yes refer to the instructions here:
Numbers Bars: Adjusting Volume at Price Multiplier For Larger Increment
