Date/Time: Fri, 13 Nov 2026 22:08:42 +0000
Error when loading number bars?
View Count: 948
| [2022-11-04 17:44:04] |
| User624812 - Posts: 1 |
Hello, I recently renewed my account. I connected the account with rithmic for an evaluation account with Bulenox. It is connecting fine and I can open candlestick charts; also, Bulenox checked on their end and told me everything is fine on their end. Can someone please check if there is a reason I cant load the number bars? Note: When I change the connection to the sierra all data, the number bars populate. When I switch back to rithmic, the number bars dont load. I will try and attach a screenshot of the error message. incase the screenshot does not go through, it is a red box and the message ends with "permission denied" (or "access denied"). Thank you very much for your help |
| [2022-11-04 18:07:05] |
| John - SC Support - Posts: 48527 |
You are getting a "Permission Denied" error from Rithmic. Refer to the following: Rithmic Trading Platform Service: Permission Denied Resolution Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-04 18:09:13] |
| Sierra_Chart Engineering - Posts: 25422 |
That permission denied error is related to historical data. Refer to: Rithmic Trading Platform Service: Rithmic Support Policy You really need to use the Denali Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-04 18:09:52
