Date/Time: Fri, 03 May 2024 16:13:15 +0000
how to draw a vertical line instead of color bar?
View Count: 1007
[2014-05-23 05:30:22] |
User35749 - Posts: 32 |
Dear Sir or Madam: How to draw a vertical line on the chart instead of a color bar in the study of "color bar based on alert condition"? Thanks, Van |
[2014-05-23 06:16:25] |
Sawtooth - Posts: 3992 |
You are limited to the available Draw Styles. A vertical line is not one of them, but Background might suffice.
[2014-05-23 06:33:24] |
Instead use the Color Background Based on Alert Condition study.
