Date/Time: Fri, 13 Nov 2026 22:08:42 +0000
ES Mini Chart showing no price candles from 19.00 2 Nov to 13.00 3 Nov UK time
View Count: 721
[2022-11-03 14:59:43]
User181655 - Posts: 64
When I opened the ES mini 1 hour chart it was showing price candles from 19.00 2 Nov and the next candle was when I opened the chart at 13.00 today Uk time.
So in between there was a massive gap.
Why have the candles gone missing from the above times...this is also true for all the other timeframes?
[2022-11-03 16:58:26]
Refer to the following for how to redownload the missing data:
Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method)
[2022-11-03 17:14:13]
I right clicked and deleted and downloaded data and it worked.
All time period candles are showing now,
[2022-11-03 18:08:46]
Just so you are aware, there is an issue with historical data downloading. We are working on the issue.
As noted, you can fill in the missing data by redownloading it.
