Date/Time: Fri, 13 Nov 2026 22:08:42 +0000
Not receiving real time data for AAPL-NQTV
View Count: 870
| [2022-11-03 14:20:43] |
| User693547 - Posts: 3 |
I sent a copy of my message log to support, as it doesn't appear I'm getting real time data for AAPL-NQTV via Denali.
| [2022-11-03 16:37:39] |
| John - SC Support - Posts: 48527 |
You are not signed up for real-time data from our NASDAQ TotalView exchange. Are you having trouble getting delayed data? If you want to get real-time data, then follow through the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-03 16:56:48] |
Apologies for not fully understanding the instructions before posting. I thought that the Total View real time data was included with Denali. It appears there is an additional monthly fee of $16 for this, correct?
| [2022-11-03 18:06:15] |
Yes, that is correct. You have to select the exchanges for which you want the real-time data within the Denali Exchange Data Feed and pay the exchange fees (which go to the exchanges, by the way). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
