Date/Time: Fri, 13 Nov 2026 22:08:43 +0000
Dev / SIM Account for developMent
View Count: 654
| [2022-11-03 09:38:16] |
| User694231 - Posts: 3 |
Hello, as discussed earlier with Carsten, I do need an SierraChart Accunt for development only. I created a Account, as you can see and I am unsure what I have to book. I have to develop a function on the DTC Protocol to get Information from. I do not need real time data and no real Trading. I do not want the possibility of real trading. thanks for help |
| [2022-11-03 15:29:19] |
| John - SC Support - Posts: 48527 |
To begin with, we have activated your account for our 15-day trial. During the trial you have the full capabilities of the system available to you (equivalent of Package 12). When the trial ends, it sounds like you would just need our lowest priced package (Package 3). Refer to the information on our packages here: Description of Service Packages and Pricing: Packages You will need to follow the instructions at the following link to add funds to your account and set it up such that it will automatically renew to Package 3 after the trial: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-03 15:35:59] |
Hello, thanks and after funding I can not do something. All what I am doing without real trading? thanks |
| [2022-11-03 17:08:45] |
Package 3 gives you access to the basic functionality of Sierra Chart. There are some studies that you can not use, such as TPO Profiles and Numbers Bars, and it does not allow you to connect to an external trading service or get real-time data from our Denali Exchange Data Feed. Otherwise, you have general accessibility and can definitely use all the development tools we have available. If there is something specific you need for your development in terms of data, or a study, then let us know and we can tell you if you need a different package. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-04 08:01:12] |
perfect, thanks
