Date/Time: Fri, 13 Nov 2026 22:08:54 +0000
Market profil, slowly with latence and can't delete draw volume profile
View Count: 817
[2022-10-31 16:15:43]
Crystal77 - Posts: 28
Hi, i put tools to draw profil volume in my market profile but cant delete him anymore, .. i try everythings... not works.... how i can do ??
Look the screenshot thanks
imagemarket problem.png / V - Attached On 2022-10-31 16:14:32 UTC - Size: 64.65 KB - 290 views
[2022-10-31 17:37:46]
You can always delete Volume by Price profiles, whether they were Drawn Profiles, or added through the Analysis menu, but going to the Studies window and removing them from the right side. Refer to the following:
Chart Studies: Adding/Modifying Chart Studies
[2022-10-31 22:47:20]
Noooooo,,, is not volume by price .. i know how can delete this... is not this in screenshot i send...
i mean you can choice option DRAW volume profile in TOOLS.
so i DRAW, but can't delete....
[2022-11-01 14:06:34]
Yes, we are understanding. If you are having trouble selecting the Drawn Volume by Price profile in order to delete it, then you can delete it through the Studies window. When you draw the Volume by Price, it is actually creating the study for it. So this gives you an alternative way to delete the profile.
[2022-11-02 19:41:03]
YESSSSSSS Working well now.
Thanks you so much John .
