Date/Time: Sun, 19 May 2024 23:32:54 +0000
IB exchange code change
View Count: 492
[2022-10-28 14:28:56] |
Chad - Posts: 231 |
Hi SCE, just a heads-up here, per an email I received from IB a moment ago: "Please note that Interactive Brokers is completing an effort to update and consolidate exchange names where appropriate. When this effort is complete, the following updates will be in effect: GLOBEX and CMECRYPTO will be consolidated to a single exchange, ‘CME’ ECBOT will be updated to ‘CBOT’ COMEX listed metals (previously reflected as NYMEX) will be updated to exchange ‘COMEX’ NYMEX, no change Given the wide breadth of products involved, we are migrating in four waves based on underlying products: Wave 1 - October 30, 2022 - GLOBEX: ZAR, LB, DA, IXE Wave 2 - November 6, 2022 - GLOBEX: EMD, BRE, CHF, SOFR3, E7, NKD; CMECRYPTO: BTCEURRR, ETHEURRR, MET Wave 3 - November 13, 2022 - GLOBEX: All remaining products; CMECRYPTO: All remaining products; ECBOT: ZO, ZR, 2YY, 30Y; NYMEX: ALI, QI, QC Wave 4 - TBD - ECBOT: All remaining products; NYMEX: All remaining "Metal" products Note: After each migration, GTC orders will be retained. These orders will show the updated exchange name but remain active." |
[2022-10-31 09:44:11] |
Sierra_Chart Engineering - Posts: 14423 |
Thank you. We will work on these changes. However, you will need to change the symbols in the charts at the appropriate time: Changing the Symbol of a Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-31 09:44:40
[2022-11-11 15:20:38] |
We are working on this. First batch of changes are going out this evening. Over the weekend perform the following procedure:: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
