Date/Time: Fri, 03 May 2024 11:17:10 +0000
Replay and Auto trading
View Count: 1802
[2013-04-30 07:23:15] |
Outlander - Posts: 91 |
When sim auto trading or replay it uses only 1 contract. If I change it to 2 or more in the trading window it changes back to 1 contract as son as the first order shows up in the chart. The spreadsheet is set to 1000 contracts. Any other settings that I have missed? Regards Outlander
[2013-04-30 07:46:34] |
How did you set the Spreadsheet trading study to 1000 contracts? And what version of Sierra Chart are you running. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-30 07:59:13] |
It was set by default in the sheet.I can see it under settings and inputs. Version 965
[2013-04-30 18:29:49] |
Please update to the current version of Sierra Chart which is 969. We have run a test and the Order Quantity is set properly at the time of the order and is set through Cell J26. Please refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#CellJ26 The functionality has changed and the documentation explains how it currently works. You cannot set the quantity through the Trade Window any longer. There were problems with that. It must only be set through the spreadsheet now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-30 18:32:12
