Date/Time: Sun, 28 Apr 2024 12:03:11 +0000
Chart oddness
View Count: 951
[2014-05-21 23:43:13] |
toews&kane - Posts: 209 |
I tried to change the intraday to seconds Is there no tick chart for TT feed for emini? It crashed when I tried to do the change. When I reload SC, the chart will not go past April 17th, I deleted and redownloaded data it still won't get past 4-17? Need this fixed asap, thank you, appreciate all your help. |
[2014-05-22 00:47:58] |
Since you are using TT FIX, you need to update to the current version of Sierra Chart for updated historical data support. Update Sierra Chart with Help >> Download Current Version. In regards to the crash issue, refer to help topic 17 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails17.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
