Date/Time: Sat, 04 May 2024 22:45:02 +0000
How do I reduce decimal places in watchlist volumes
View Count: 400
[2022-10-25 18:20:03] |
drmike_dxb - Posts: 6 |
Final question: is there a may to reduce decimals in watchlist? it shows as 7689251 instead of just 7,7M? thanks |
[2022-10-25 18:29:54] |
Sierra_Chart Engineering - Posts: 14224 |
We will look into this. We may need to add an option for this.
[2022-10-28 21:32:06] |
User90125 - Posts: 715 |
+1
[2022-11-18 02:17:33] |
We will add support for this.
[2022-11-21 03:19:30] |
Hi, any updates? Thamks |
[2022-12-26 21:03:49] |
Has this been added?
[2022-12-29 09:44:57] |
I think @Sierra Chart Engineering could update us? It has been a while Date Time Of Last Edit: 2022-12-29 09:45:11
[2022-12-29 23:02:14] |
This is controlled through the Quote Board menu in newer versions. It is Settings >> Use Large Number Suffix.
