Date/Time: Mon, 29 Apr 2024 16:48:15 +0000
Copying all configurations from TA to Sierra
View Count: 1016
[2014-05-21 23:13:51] |
Ronin - Posts: 35 |
Hi, What files do I need to copy and backup from my TransAct Sierra folder to a new sierra installation folder ("Original" setup that's not combined with TA) Is it the same backup procedure as u explained here - http://www.sierrachart.com/index.php?l=doc/helpdetails15.html thank you |
[2014-05-21 23:23:57] |
You do not need to copy any files if you want a completely new set up. What exactly do you want to be the same between the two installations?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-21 23:24:10
[2014-05-22 07:38:26] |
Ronin - Posts: 35 |
What I mean is.. after I install the new setup - which files do I need to copy in order to restore my entire configurations and settings - I don't want to loose any of the charts/configurations I have on the TA setup
Date Time Of Last Edit: 2014-05-22 07:44:15
[2014-05-22 07:55:36] |
Help topic 15 describes just what to do: http://www.sierrachart.com/index.php?l=doc/helpdetails15.html In particular step 4. If you just follow that step-by-step you should be fine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
