Date/Time: Wed, 08 May 2024 09:41:51 +0000
Rithmic data feed and Sierra chart historical daily data
View Count: 1191
[2014-05-21 19:32:18] |
User94199 - Posts: 13 |
Hello, My broker is canceling TT feed. I have an option to choose between Rithmic and CQG It says that Rithmic provides historical data only to 1min level, which is not satisfying Right now there is a problem with TT data feed. When I open charts, charts will load data from Sierra chart server except for last 10min. After connection to feed, Sierra collects data from TT feed into file. I have a 10min gap, but it is not a tragedy My question is whether such method is applicable for Rithmic feed. That means I do download all data to tick level from Sierra chart, and then connect to Rithmic and continue recording new data. Thank you in advance for your response |
[2014-05-21 19:39:44] |
In the case of when using Rithmic, the historical Intraday data will be downloaded from Rithmic and this is in 1 minute units. However, expired futures contract data is downloaded from the Sierra Chart server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-21 20:39:53] |
Ok, thx Can I have additional question about CQG? It says "Historical Intraday Data: Provided by the Sierra Chart Historical Data Service. This data is 10 minutes delayed. To avoid the 10 minute delay, you need to use the Sierra Chart Real-Time and Historical Exchange Data Feed." So this would be the exact situation I have with TT at this moment. I load graph, data from Sierra chart is downloaded, except last 10min, after connecting to data feed server, I'm getting live stream data, and I only have 10min gap Correct? Thanks |
[2014-05-21 20:42:24] |
Yes.
