Date/Time: Mon, 29 Apr 2024 12:06:29 +0000
Filtering trade data
View Count: 934
[2014-05-21 19:03:25] |
Daniel1957 - Posts: 3 |
Is there any way to set up a numbers bar chart that shows the cumulative trades at each price level for the bid and the ask for trades over 150 contracts in size? In other words it would not count a trade unless it was equal to or greater that a minimum block size. If not in a numbers bar chart, then perhaps as an indicator? Thank you |
[2014-05-21 19:10:58] |
This is supported. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#VolumeFiltering However, we strongly question this method of analysis. We have information about this here: http://www.sierrachart.com/index.php?l=doc/doc_ChartDataFiles.html#LargeVolumeTrades Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
