Date/Time: Tue, 07 May 2024 08:52:18 +0000
OEC not connecting now
View Count: 909
[2014-05-21 16:38:15] |
Willson - Posts: 176 |
here is last group of log entries; OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-05-21 11:29:27 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-05-21 11:29:27 The network socket is connected. | 2014-05-21 11:29:27 Starting SSL connection on the socket. | 2014-05-21 11:29:27 SSL socket is connected. | 2014-05-21 11:29:27 OEC FIX Trading: Sending the Logon message. | 2014-05-21 11:29:27 OEC FIX Trading: Received a Logout message. | 2014-05-21 11:29:27 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-05-21 11:29:27 SSL shutdown indicates not able to send 'close notify'. | 2014-05-21 11:29:27 The SSL socket was shut down. | 2014-05-21 11:29:27 The SSL socket object has been freed. SSL state is now disconnected. | 2014-05-21 11:29:27 Socket has been shutdown and closed. | 2014-05-21 11:29:27 OEC FIX Trading: Logged out and disconnected. | 2014-05-21 11:29:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-21 11:29:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-21 11:29:27 Disconnected from Open E Cry. | 2014-05-21 11:29:27 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-05-21 11:29:27 Any suggestions |
[2014-05-21 16:47:19] |
We will let OEC know about this.
