Date/Time: Wed, 01 May 2024 08:38:21 +0000
Detaching Chartbooks?
View Count: 938
[2014-05-21 11:49:41] |
User51760 - Posts: 108 |
Hello Support Team, working on a multiple monitor system I wonder if it is possible (or maybe a planned feature) to detach not only single chart windows but a complete chartbook as well? Thank you for your consideration, Best, Chris |
[2014-05-21 18:08:33] |
Chartbooks are documented here: http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html Only one Chartbook can be visible at a time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
