Date/Time: Fri, 03 May 2024 06:36:18 +0000
Duplicate Toolbar?
View Count: 935
[2014-05-21 11:44:15] |
User51760 - Posts: 108 |
Hello Sierra Chart Support Team, since I am working on a multiple monitor system I wonder if it is possible to duplicate the toolbar (or opening more than one instance) having it close to the active chart without dragging it around and loosing it? Thank you for your Support, Best, Chris |
[2014-05-21 16:30:45] |
There are 8 Toolbars available. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_WindowMenu.html#ToolBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-21 16:30:57
[2014-05-21 19:46:25] |
Thank you for you pointing me in the right direction - I was not aware it is possible to show more than one toolbar simultaneous. Finding new features every day makes using Sierra Chart fun... Best, Chris |
