Date/Time: Mon, 29 Apr 2024 07:11:42 +0000
lost drawings
View Count: 994
[2014-05-21 08:30:02] |
AKR - Posts: 523 |
I unintenionally closed a chart. how can I get it back inkl the drawings I had in there?
[2014-05-21 08:37:43] |
You cannot.
[2014-05-21 08:40:25] |
AKR - Posts: 523 |
fantastic ;-) I thought this is saved when pressing "save all" |
[2014-05-21 09:12:35] |
Now that you mention that you have used Save All, it is saved is part of the Chartbook. You could close the Chartbook without saving it and then reopen it . This assumes that the closed chart was already saved in that Chartbook.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-21 09:12:59
