Date/Time: Sun, 28 Apr 2024 07:10:21 +0000
Is it possible to see MAX Volume in combine mode at Time and Sales?
View Count: 1044
[2014-05-21 06:22:32] |
User79347 - Posts: 23 |
For example, if several deals by same price is blocked, inside this block was a maximum volume, is it possible to save this information on other column of someting like that? Thank you! |
[2014-05-22 03:10:36] |
No. And there are no plans to add this.
