Date/Time: Wed, 18 Nov 2026 14:58:04 +0000
Exporting data to CSV
View Count: 8614
[2022-10-14 18:35:07]
User956955 - Posts: 3
How can I export raw historical data to treat it afterwards in python?
Thanks.
[2022-10-14 21:42:17]
John - SC Support - Posts: 48570
The Daily Historical data is already in an ASCII format, so you can just open the .dly files directly.
The Intraday data can be exported in three different ways.
1. If you just want to do the export occasionally, but you want the entire contents of the intraday data file, then use Edit >> Export Intraday Data to Text File. Refer to the following:
Exporting and Importing Intraday Data Files: Export and Edit
2. If you just want to do the export occasionally, and you want the data that is loaded in a particular chart, then use Edit >> Export Bar Data to Text File. Refer to the following:
Edit Menu: Edit >> Export Bar Data to Text File
3. If you want to continuously get the data exported, then use the study called Write Bar Data to File. Refer to the following:
Date Time Of Last Edit: 2022-10-14 21:42:50
