Date/Time: Mon, 16 Nov 2026 14:06:21 +0000
Simulated Futures Trading Service on sub instance
View Count: 724
| [2022-10-14 12:39:23] |
| User61576 - Posts: 458 |
I would like to run a sub-instance to be connected to Simulated Futures Trading Service although the main instance be connected to Denali live feed. in here Simulated Futures Trading Service i could not find how to do this as the sub instance Global Setting--> Data/Trade Service settings don't allow to change the feed type pls advice thanks |
| [2022-10-14 14:27:36] |
| John - SC Support - Posts: 48527 |
You can not do this using the sub-instances (File >> New Instance). You would need to install a second Sierra Chart and then have the one connected to your main trading service and the other connected to the Simulated Futures Trading Service. As long as both installations are on the same computer, you will get the Denali data to both installations without any trouble, or any additional cost. Refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart And then follow through the steps to setup the Simulated Futures Trading Service at this link: Simulated Futures Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
