Date/Time: Mon, 16 Nov 2026 14:06:21 +0000
Keep title bar hide even when i click on the chart
View Count: 1753
| [2022-10-14 07:31:42] |
| oliviermo75 - Posts: 19 |
Hi folks i found on your website how to Auto Hide Charts Title Bar and Scrollbar and it works however i would want to do one more stuff and i don't fins anything about that. General Settings Window: Auto Hide Charts Title Bar And Scrollbar (Global Settings >> General Settings >> GUI >> Application GUI) i would want to keep Charts Title Bar and Scrollbar hiden when i click on the chart because otherwise he resize all the time i click on it and it annoying me. Is it possible ? |
| [2022-10-14 14:04:18] |
| John - SC Support - Posts: 48527 |
You do not want to use the option you reference above. Rather just deselect the options to display the Title Bar, Scroll Bar, and Menu Bar from the Chart menu for the charts on which you do not want to see these items. This way they are always hidden. Refer to the information starting here: Chart Menu: Show Title Bar (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
